Gussets for LT on an overlanding build?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by nautical__nonsense, Jul 28, 2018.
  1. Jul 28, 2018 at 4:02 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Do you mean topping out? There's no more risk of topping out with a shorter coil+preload vs a longer coil. At least I don't think so. Besides, limiting straps could be added for cheap, and you'll need those with LT anyways.
  2. Jul 28, 2018 at 4:03 PM
    nautical__nonsense
    nautical__nonsense [OP] Well-Known Member
    Jimmy
    Long Island, NY
    2017 Inferno Tacoma TRD Offroad
    I'd love to do the ball joint but Toyota sucks and doesnt sell the ball joint alone. Neither does moog or anyone else. I had TC uppers for a while and didnt mind spraying the balls much. Never got to a point of squeaking. It's been worth considering. Instead of replacing a stock control arm once every couple years, just get the best quality I could afford and take care of it.
  3. Jul 28, 2018 at 4:05 PM
    nautical__nonsense
    Jimmy
    Long Island, NY
    I mean maybe, I haven't heard of that being done, but maybe someone else could shed some wisdom on that. It's not my big issue here, but maybe something to try down the road.
  4. Jul 28, 2018 at 4:06 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    I've heard of people doing it before. IIRC the stock length king coils are 12" and people will swap them for 14" coils. Just more stuff for you to research haha
    eccracer104 likes this.
  5. Jul 28, 2018 at 4:08 PM
    nautical__nonsense
    Jimmy
    Long Island, NY
    Yay more research!!!!! I already have a damn headache lmao
    EatSleepTacos[QUOTED] likes this.
  6. Jul 28, 2018 at 4:49 PM
    erok81
    erok81 Well-Known Member
    Imposter
    Coming from someone who has had multiple brand lifts and now has full LT, reading your first post, you are wasting money going to LT. For the type of wheeling it sounds like you do, you won’t notice ride difference at all from your current set up to LT.
    And as others have said, it doesn’t drive the same (mine is 3.5 front w/ bypasses and sua rear with 37’s). It sways a lot. Squeals. Rattles. Very expensive.
    But hey...it’s your money. I didn’t need LT either. In fact I think in the last year mine hasnt gone off road once. Just my daily driver. :rofl:
  7. Jul 28, 2018 at 6:09 PM
    Sacrifice
    Sacrifice Motorcycle Goon
    KS
    DCSB OR 4X4 LT
    Pelfreybilt Front Bumper,BAMF sliders, Airflow Snorkel,Mini D2S Retrofits, ADS Rear Shocks, Deaver U402 Leafsprings, 35s, AllPro +2LT
    i get it but there is definitely some recoup when swapping suspensions. i will use mine also though.
    not at all, still very comfortable
    getting longer springs and lowering actual preload wont change ride quality. its still the same spring rate.
    you dont have to lube them every month. i stopped and my squeaking stopped as well.
    again dont need gussets unless you really beat ob it at speed
  8. Jul 28, 2018 at 6:12 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Preload affects ride quality, that's not even a question.
  9. Jul 28, 2018 at 6:16 PM
    nautical__nonsense
    Jimmy
    Long Island, NY
    Can confirm, my kings ride MUCH different than they did before I leveled.
    EatSleepTacos likes this.
  10. Jul 28, 2018 at 6:18 PM
    nautical__nonsense
    Jimmy
    Long Island, NY
    Yeah, these shocks have about 10k on them. They could still command over 1k in resale. That's a big chunk out of the LT cost for sure. SPC UCAs, old trdor rims I still have will all chip away at the total
  11. Jul 28, 2018 at 6:20 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Could always work the corner too. Though you might have some stiff competition there in LI
  12. Jul 28, 2018 at 6:21 PM
    nautical__nonsense
    Jimmy
    Long Island, NY
    :rofl: I'm in the bug killing game, I'll tell ya there are plenty of bugs to keep me going out here.
  13. Jul 28, 2018 at 6:36 PM
    Joe23
    Joe23 Canuckistikian
    The Great White North
    2017 TRD Off-road DCSB
    You could just do stock length lower control arms from dirt kings or total chaos and remove the ball joint but but do Lt.
    I don't see why you need to do LT.
  14. Jul 28, 2018 at 6:38 PM
    Joe23
    He doesn't even need longer coils just heavier ones. Kings cone with 600lbs no? Try 700lbs. Won't need to run as much pre load
  15. Jul 28, 2018 at 6:40 PM
    #35
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    That's assuming he's sagging from the weight of the added stuff, then yeah, stiffer would be the solution to gain height. And I think they come with 650 but don't quote me on that. It's all too rich for my blood.
    Joe23[QUOTED] likes this.
  16. Jul 28, 2018 at 6:45 PM
    #36
    Joe23
    Could be right I just assumed they were like fox and cane 600lbs.
    But regardless if he's not prepared to do the rear LT as well I don't see a point in doing it.
    And I wouldn't run it without gussets.
    Fuck I'm not even LT and I'm considering gusseting the spindles and buckets . Cam tabs no doubt I'm definitely doing.
    But then again my truck is just about overweight without any camping gear. So I'm just thinking make shit stronger.
  17. Jul 28, 2018 at 6:47 PM
    #37
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Yeah agreed on pretty much all points. Have to match the rear to the front otherwise it's pretty pointless IMO. There are still benefits but you're nowhere near using LT to it's full potential that way. I have cam tab gussets and would like to get gusseted spindles at some point.
  18. Jul 28, 2018 at 6:47 PM
    #38
    Joe23
    I think the idea to go LT just because you blew a ball joint is kinda fucked when you can ditch the ball joint by just getting stock length LCA from DK or TC.
    eccracer104 and EatSleepTacos like this.
  19. Jul 28, 2018 at 6:49 PM
    #39
    Joe23
    You can but you sacrifice so much in daily drivability going LT.
  20. Jul 28, 2018 at 7:57 PM
    #40
    Sacrifice
    KS
    DCSB OR 4X4 LT
    not in the sense of a longer spring with less preload. a spring rate of 700lbs/inch compressed 1 inch or two inches has the exact same spring property. the only things that change are your uptravel/downtravel ratio when cranking on a coilover down which then in turn effects ride quality. a 10inch spring with 20 turns showing versus a 12inch spring with 16 turns (unrelated theoretical ratio number) has zero effect. changing to a longer spring causes spring block height to change and thats where a limitation can come into play.
