gutting rear cats?
Discussion in 'Performance and Tuning' started by justin14200, Sep 15, 2010.
  1. Sep 15, 2010 at 10:05 AM
    justin14200
    justin14200 [OP] frequent reader
    justin
    baton rouge
    2010 prerunner sr5 bsp
    stock
    anyone have a how to? i wanna keep the look of having cats on the truck...
    anyone have any ideas of an easy way to gut the rear cats without firing up the torch and cutting up my new truck?
  2. Sep 15, 2010 at 10:27 AM
    justin14200
    justin
    baton rouge
    stock
    do they bolt on?
  3. Sep 15, 2010 at 10:41 AM
    Chachie
    Chachie Well-Known Member
    Justin
    Nor Cal
    '06 TRD OR, 4x4, Auto, 6" Fabtech, 35's
    Locker mod, Anytime fog mod, always 400w mod.
    Better yet, get a set of DT short tubes and stay legal and have more power.
  4. Sep 15, 2010 at 10:47 AM
    OH-MAN
    OH-MAN Well-Known Member
    Sunny Az.
    10 4X4 O.R. White
    TRD skid painted black,
    I am using a set of URD pipebomb pipes.
    They have a big round thing on each side that looks like a cat.
    The o2 sensors are in front of them so no codes have shown.
    So I have a better flowing exhaust and still save the planet while getting 18 mpg!!!!!
  5. Sep 15, 2010 at 7:47 PM
    justin14200
    justin
    baton rouge
    stock
    Well, inspection isn't a big deal. I've seen people cut them off before... I've also Sean people cut them open... And take a hammer and prybar to them...
  6. Sep 16, 2010 at 7:49 AM
    macgyver
    macgyver Well-Known Member
    Brad
    Canton, GA
    '13 Tundra double cab SR5 4x4
    Pointless on a tacoma.
    Now on a high performance vehicle...Yes.
    I used to have a turbocharged honda accord before my tacoma and I actually didn't run a cat on it. 2.5" exhaust from the turbo back to the muffler. Surprisingly I was able to pass legitimately without one, gotta love OBD2 and the guy not doing a visual inspection because the car was too low to look under.
  7. Sep 16, 2010 at 8:12 AM
    Toyotacrawler
    Toyotacrawler She's got the jimmy legs
    Cusseta/Opelika AL
    2010 Tacoma DC TRD Sport
    5100's set to 1.75" Wheelers 3 leaf progressive AAL & 5100's for the rear Konig Countersteer Offroads K&N Drop in WeatherTech's Bed Mat Blacked out Badges Rear leaf TSB
    I use to own a 01 Tacoma. I live in alabama where there are little if any laws on emissions. So after I installed the header from downey I cut the first one off. No real issues other than the check engine light was always on. The code read backflow pressure below threshold in bank one. Well, I got use to that and could deal with it. A few years later I had issues with the second cat and ended up cutting it completely off. I noticed NO power gain whatsoever. All I noticed was that the truck was ridiculously loud!! If I had to do it all over again I would have never cut the first one off in the first place. Leave it on, it's there for a reason, not mention it helps protect the environment. Spend the money and get a high flow cat. Thats just my $0.02 anyway. :)
  8. Sep 16, 2010 at 10:24 AM
    justin14200
    justin
    baton rouge
    stock
    im also planning on doing a volant intake. if i did cut them off, would the intake make more backpressure on the exhaust to make it like the same pressure if they were there?
    i know another guy on here cut his off and did an aeroturbine 2525xl and it sounded great, idk if he had problems with backpressure or not... what problems would u have if backpressure was incorrect?
  9. Sep 16, 2010 at 10:51 AM
    memario1214
    memario1214 Hotshot Offroad Moderator Vendor
    Colton
    Missoula, MT
    SOLD - 05 Dub Cab TRD Sport 4x4, CURRENT - '21 Tundra MGM Limited
    Justin, you may be talking about me. I did in fact remove my rear cats and put in an AT as well as a resonator. I did lose some low end torque, but the truck runs quite a bit better now though.
  10. Sep 16, 2010 at 10:59 AM
    Toyotacrawler
    Cusseta/Opelika AL
    I had an injen intake (see pics in my gallery if you like :) ) and my check engine light still stayed on. I never had any mechanical issues with the backpressure below threshold, nor do I know if I was creating any problems for the future. I was told by a shop that I could have the computer reprogrammed but I never did any of that mess. I shoulda left it the way it was or bought a high flow.
  11. Sep 16, 2010 at 1:07 PM
    justin14200
    justin
    baton rouge
    stock
    Yea, I think it probobly was you. How did you gut your cats? You lost power when you did it? If I just put on the muffler, will I get the same deep sound as if I cut the cats out?
  12. Sep 16, 2010 at 1:27 PM
    memario1214
    Colton
    Missoula, MT
    I didn't gut the cats though... I cut them clean out! Haha and you should get about the same sound if you were to add in like a 10 or 12 inch resonator. Don't go for the xl, you will find yourself paying $100 for a $30 part.
  13. Sep 16, 2010 at 5:45 PM
    justin14200
    justin
    baton rouge
    stock
    what is your exact setup? your truck sounds amazing.
    do you have pictures of the underside of your truck that you would share?
    the 2525xl is only $120 on ebay. whats the purpose of the resonator, whats it do?
  14. Sep 16, 2010 at 7:39 PM
    memario1214
    Colton
    Missoula, MT
    Here is my thread that tells everything about my build up to this point. Except I don't think that I have my resonated videos in there, they are in my sig. Pictures and everything should be in there though. If not, they lie in my gallery. Aero Turbine Thread
    What a resonator does is eliminate some of the "wild" sounds that come from the engine. It muffles the sound waves that are coming at it. In my case, I used that resonator to take out the little bit of rasp that I was experiencing at about 2300RPM
  15. Sep 17, 2010 at 11:07 AM
    justin14200
    justin
    baton rouge
    stock
    soo u have a 2525 and a resnator? not a 2525xl?
    wouldnt a 2525xl be the same as a 2525 and a resonator?
  16. Sep 17, 2010 at 11:23 AM
    memario1214
    Colton
    Missoula, MT
    Essentially the same thing yes. But you don't get to pick the length of the resonator.
  17. Sep 17, 2010 at 4:12 PM
    justin14200
    justin
    baton rouge
    stock
    which size resonator do youo have?
  18. Sep 17, 2010 at 5:41 PM
    memario1214
    Colton
    Missoula, MT
    I have an 18 but if you were to keep the cats, I would suggest somewhere in the vicinity of a 12
  19. Sep 17, 2010 at 5:45 PM
    justin14200
    justin
    baton rouge
    stock
    Where does the resonator go? On the aeroturbine website they only have a 3 inch? I need 6 of them?
  20. Sep 20, 2010 at 9:52 PM
    memario1214
    Colton
    Missoula, MT
    Haha no. The resonator lies directly before the muffler. On their website, they list a 3" resonator. All that means is that the resonator is made for an exhaust setup with 3" piping. The resonator itself is not in fact 3" long. The resonator is actually 10" long. If you had 3" exhaust on your truck, you could use this. You could also flange your piping to fit this resonator to fit this but I don't suggest it. I suggest a 10-12" resonator with 2.25-2.5" ends (aka pipe diameter) so that it would sit flush with the rest of the system, and also give you the sound that you desire.
    -Colton
