Guys, help a noob improve the performance of his new truck!
Discussion in 'Performance and Tuning' started by AxxSxxB, Sep 1, 2009.
  1. Sep 1, 2009 at 9:29 AM
    #41
    AxxSxxB
    AxxSxxB [OP] Oblivious and Ignorant
    Amarillo, Texas
    09 4x2 PreRunner 4.0L V6 5-S Auto TRD Sport
    Then that sounds fun :)
  2. Sep 1, 2009 at 9:54 AM
    #42
    mjp2
    Milton Juevo Portimous II
    NJ
    Current: '21 Bronco Badlands. Previous: '06 TRD Access Cab, v6, 6-speed
    That doesn't really answer the question. Performance in what way? Street performance? Offroad performance? Rock crawling? High-speed offroad stuff?
    Performance is relative. My truck will work wonders offroad but will 3-wheel and damn near flip going around a corner on the street.
    How will you use your truck?
  3. Sep 1, 2009 at 9:59 AM
    #43
    AxxSxxB
    Amarillo, Texas
    Street performance/jack around at the track.
  4. Sep 1, 2009 at 10:02 AM
    #44
    98tacoma27
    Ben
    Not Beech Creek
    Well, the truck you purchased has a 4x4 suspension under it. You should rip it all off and start new if street performance is what you are after.
  5. Sep 1, 2009 at 10:04 AM
    #45
    mjp2
    NJ
    Much clearer now. URD supercharger, lower the truck, fatter front sway bar, custom rear sway bar, wheels and sticky tires, torsion bar to reduce axle wrap and hop. That limited slip differential will serve you well on the road.
  6. Sep 1, 2009 at 10:05 AM
    #46
    98tacoma27
    Ben
    Not Beech Creek
    Add an X-brace.
  7. Sep 1, 2009 at 10:10 AM
    #47
    AxxSxxB
    Amarillo, Texas
    Service aside, how much would all of this run for? 25k?
  8. Sep 1, 2009 at 10:12 AM
    #48
    98tacoma27
    Ben
    Not Beech Creek
    $10k-$12k maybe (high side)
  9. Sep 1, 2009 at 10:13 AM
    #49
    AxxSxxB
    Amarillo, Texas
    Bro, the stage 1/2 SC is 8k by itself. I thought I was heading up to stage 3 lol.
  10. Sep 1, 2009 at 10:15 AM
    #50
    98tacoma27
    Ben
    Not Beech Creek
    My bad. I was thinking TRD.
  11. Sep 1, 2009 at 10:17 AM
    #51
    AxxSxxB
    Amarillo, Texas
    Ah.
  12. Sep 1, 2009 at 10:32 AM
    #52
    AxxSxxB
    Amarillo, Texas
    Anyways. After all 3 stages of the URD SC, there arent any other performance parts I could get my hands on to that would help even a bit? Just what you previously mentioned, to help handle the new power?
  13. Sep 1, 2009 at 10:35 AM
    #53
    mjp2
    NJ
    Call URD. They know more than pretty much anybody about getting power from the 1GR.
  14. Sep 1, 2009 at 12:53 PM
    #54
    drew02a
    drew02a Rocking your mom's world Since 1997
    San Antonio, TX
    2006 Regular Cab 2.7L 4x4
    At stage 3 you'll have already replaced almost all of the intake and exhaust components.
  15. Sep 1, 2009 at 1:04 PM
    #55
    vbibi
    vbibi Well-Known Member
    san fransisco bay area
    2009 4door long bed
    Hi,
    If "Money is not an issue here" you should of bought a 4x4.
    take care
    vbibi:(
  16. Sep 1, 2009 at 4:42 PM
    #56
    XrunnIT
    XrunnIT Well-Known Member
    Austin, TX
    1GR-GZE X-Runner
    Built Motor by LC Engineering Boosted by TRD
    Boost = Power
    Custom turbo (or twins) with forged internals is the way to go if you are wanting to make ridiculous amounts of power.
    Other then that, your next best option is TRD S/C, intake, headers, exhaust, custom tuning (Map ECU 2), and some nitrous. Throw in built internals to hold the extra power and up the n2o shot.
    The URD S/C is not compatible with the 09 or 010 models.
    For the 09s, tuning is going to be much more custom as the APR X-1 ECU controller is not currently compatible.
  17. Sep 1, 2009 at 4:56 PM
    #57
    AxxSxxB
    Amarillo, Texas
    Awesome. So how is the turbo (or twins, if you can even do that in the tacoma) with forged internals better than stage 3 URD SC? And what do you mean by forged internals?
  18. Sep 1, 2009 at 5:08 PM
    #58
    XrunnIT
    Austin, TX
    1GR-GZE X-Runner
    With turbos you don't really have a limit on how much boost you can make. In most cases more boost = more power. The URD Stage III s/c is limited because of the size of the rotex s/c. It is belt driven, and can only spin so fast. You would burn out the s/c before you come close to making the boost levels possible with a turbo setup.
    Twins will fit. Just find a good shop to make the kit. You get what you pay for.
    Forged internals (rods, pistons) are MUCH stronger then the powdered rods/pistons in the stock block. Ideally, you would get pistons with a lower compression ratio (stock is 10:1) that is more boost friendly (anywhere from 8.5:1 to 9.5:1 depending on how much boost you want to run).
  19. Sep 1, 2009 at 5:15 PM
    #59
    AxxSxxB
    Amarillo, Texas
    I did say money was not an issue... but im still a bit concerned about how high this would run. Ive been hearing about 11 second tacos; is this a realistic goal with, say $60k put into the truck? Friend is mentioning that getting the best possible turbo would be +40 grand.
  20. Sep 1, 2009 at 5:15 PM
    #60
    AxxSxxB
    Amarillo, Texas
    Just want the fastest truck possible whilst keeping it a tacoma lol.
