Guys, help a noob improve the performance of his new truck!
Discussion in 'Performance and Tuning' started by AxxSxxB, Sep 1, 2009.
  1. Sep 1, 2009 at 5:19 PM
    #61
    XrunnIT
    XrunnIT Well-Known Member
    Austin, TX
    1GR-GZE X-Runner
    Built Motor by LC Engineering Boosted by TRD
    Turbo + forged internals, custom tuned. Done right.. 500, 600, 750hp? sure, why not. :D
    Just keep in mind, as you make more power you will need to reinforce the motor more and more. That much power, and you'll have to watch the crank, the and cylinder walls (they are pretty thin as it is), etc.
  2. Sep 1, 2009 at 5:25 PM
    #62
    XrunnIT
    Austin, TX
    1GR-GZE X-Runner
    A well built twin turbo setup will run you about $10k-15k. You can spend about $3k-5k for a mildly built motor that will hold around 15psi (maybe more).
  3. Sep 2, 2009 at 2:59 PM
    #63
    dysfunctnlretard
    dysfunctnlretard Hi
    Manny
    CA
    2021 Jeep Rubicon
  4. Sep 30, 2009 at 7:32 AM
    #64
    09Tacomania
    09Tacomania Well-Known Member
    Scott
    Little Rhody
    09 Silver Streak Dbl cab 4x4
    Icon CO's, LR UCA's, Icon rear 2.0 rear resi's, Wheelers 1.5" 3 pk aal, blacked out badges, Andre's devil horn's, Extang tonneau. Oem racks
    60k? I'd buy a Corvette and be done with it.
  5. Oct 4, 2009 at 1:13 AM
    #65
    TacoKing
    TacoKing Active Member
    Panama City, FL
    06 TRD Off-Road 4x4 Silver DCab with TLC
    Wow...I'm surprised no one mentioned the STS Turbo Kit. It is the shiznat of turbos. Spend 10 minutes on their website familiarizing yourself with what they do and how it works. It is extremely impressive - and you're not looking at $40 - $60K. More like $4K. Anyway, check it out, it just may tickle your fancy.
    http://www.ststurbo.com/home
  6. Oct 4, 2009 at 6:23 AM
    #66
    WNYTACOMA
    WNYTACOMA Well-Known Member
    Clarence, New York
    09 Metalic Grey TRD OFF ROAD
    Toyota Nerf steps Bugflector 2 Tool box Weathertech floor liners Wet Okole F/R - Bk/Char
    and now you drive a Tacoma, have a mullet, and barely enough cash for gas?...
  7. Oct 4, 2009 at 6:27 AM
    #67
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    I wouldnt call it the "Shiznat" of turbos....More like the Generic bolt on minimal gains of turbos.
  8. Oct 4, 2009 at 10:35 PM
    #68
    AxxSxxB
    AxxSxxB [OP] Oblivious and Ignorant
    Amarillo, Texas
    09 4x2 PreRunner 4.0L V6 5-S Auto TRD Sport
    You think the URD supercharger is better?
  9. Oct 5, 2009 at 5:13 AM
    #69
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Than the STS turbo? Yes.
  10. Oct 5, 2009 at 4:10 PM
    #70
    AxxSxxB
    Amarillo, Texas
    Awesome. The URD supercharger would be better than the TRD as well, right?
  11. Oct 6, 2009 at 5:09 AM
    #71
    XrunnIT
    Austin, TX
    1GR-GZE X-Runner
    That is a VERY debatable topic. Its hard to say one kit is better then the other, as everyone has different tastes.
    When it comes to 1/4 racing, the TRD S/C is faster then the URD.
    When it comes to dyno numbers... you can't believe anything you read. The same truck on a different dyno will vary 10-50hp easy. The same truck on the same dyno but different days will vary 10-50hp, I've seen it with my own eyes. So its bad habit to try and compare dyno's.
    But with that being said, i've seen a URD Stage III S/C dyno only 8hp more then a TRD S/C with bolt ons, lower pulley, and mild tune.
    In the end boost is awesome!! Pick your poison and enjoy it. :thumbsup:
  12. Oct 6, 2009 at 10:50 AM
    #72
    bram
    bram Well-Known Member
    Bram
    belgium
    08 x-runner
    bedlid. custom made intake ... dt shorties and a flowtech warlock mufler lpi install and some music
    just contact tte toyota technical engeneering in japan and they can make the truck fly
  13. Oct 7, 2009 at 3:43 AM
    #73
    AxxSxxB
    Amarillo, Texas
    Explain? Also, is there a such thing as being able to have a twin turbo set-up in the taco? I'm willing to learn... The whine sounds god awful amazing.
