Guys with a Leitner long bed rack, could it fit a short bed?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by SkinnyP2, Jun 5, 2019.
  1. Jun 5, 2019 at 5:00 AM
    SkinnyP2
    SkinnyP2 [OP] Millennial Wise Guy
    18 Offroad Chuck Norris Edition
  2. Jun 5, 2019 at 9:55 AM
    Jaque8
    Jaque8 Well-Known Member
    2017 Inferno TRD OR
    Its TIG welded aluminum, gonna be a bitch to weld and likely not worth the effort as you'd have to get it down to millimeters to bolt up properly.
    Just get one made for your shortbed. I'm not even sure where you'd cut it and still be able to use the slot systems already in place, you'd have to be one helluva welder.
  3. Jun 5, 2019 at 9:56 AM
    Jaque8
    2017 Inferno TRD OR
    Side note though the Leitner is worth every penny, fucking love my rack :)
  4. Jun 5, 2019 at 12:25 PM
    stu8319
    stu8319 Well-Known Member
    Stuart
    Oklahoma City
    2018 Tacoma TRD Off-Road in Quicksand
    I agree that it would be too much work unless the thing was free, I don't think tig welding is TOO terribly difficult to do or have done. My shit's never looked pretty on mig or tig, but it's functional and I've seen much worse!
  5. Jun 5, 2019 at 1:29 PM
    Jaque8
    2017 Inferno TRD OR
    TIG is a little trickier than MIG but that’s not the part I consider difficult... it’s that it’s aluminum.
    Maybe I just suck at welding but aluminum kicked my ass whereas steel I actually was pretty good at (for a high school kid anyways)
  6. Jun 5, 2019 at 1:44 PM
    SearArtist
    SearArtist GX poor
    NC
    GX470 & GX460
    Things
    What makes this bed rack so special? Doesn't seem all that different from every other bed rack on the market.
    Buy local and support small businesses.
    Personally I'm a big fan of SOS Concepts, Eddy can customize it however you want and ship it for cheap.
    http://sosoffroadconcepts.com/lp-advantage-bedrack/
    Any questions you can ask @SOS CONCEPTS or myself.
  7. Jun 5, 2019 at 2:20 PM
    Jaque8
    2017 Inferno TRD OR
    The Leitner is the only bed rack available for the Tacoma that bolts to the bedsides AND directly to the frame giving it way more torsional rigidity and strength. Thats what sold me on it as I've already cracked a camper shell on my 1st gen and fucked up the bedsides on my 2nd gen... both from offroading hard with a load on the bed rack/shell. There's a reason none of the other rack manufacturers list a dynamic weight rating, they don't want to be liable if you fuck something up.
    Given its the strongest AND lightest full bed rack on the market (only 70lbs) I'd say its pretty special :)
    Nothing agains't SOS seems like a great deal for what you get, and the Leitner is twice the price so I wouldn't fault anyone for saving some $. But if you need the offroad capability and can afford the Leitner there really is nothing else comparable currently on the market. Leitner is also a small business so I feel good supporting them :)
  8. Jun 5, 2019 at 2:29 PM
    SearArtist
    SearArtist GX poor
    NC
    GX470 & GX460
    Things
    So you have to cut out parts of the bed to tie this rack into the frame? If you are carrying so much weight your bending bedsides and cracking the composite bed, you should consider either a custom flatbed or moving to a full size - IMO
  9. Jun 5, 2019 at 3:01 PM
    Jaque8
    2017 Inferno TRD OR
    Nope no cutting needed it use the factory frame bolt locations in the rear (where bed stiffeners attach to). It also uses torsional stability bars up front that bolt into the factory tonneau holes.
    Its not really about the raw weight and more about the kind of offroading you do. Hitting whoops and 35 degree sideways angles with a 300lbs of gear on the rack and you can fuck shit up quick, don't need a full size for 300lbs and not everyone wants to take it easy offroad :)
    I can def see a custom flatbed in my future though :drool:
    But for the meantime I like the ability to quickly return everything to stock if needed.
    Another plus on the Leitner is the top rails slide forward in like 30 seconds so I can stuff my dirt bike in there and still have my gas/storage cubbies bolted on the sides with all my gear in them.
    Just can't do RTT and motorcycle at same time.
  10. Jun 16, 2019 at 12:26 PM
    Mack411
    Mack411 Well-Known Member
    2017 Quicksand Tacoma Trd-OR
    The quality of the build is what makes it special and the functionality. Also I was a big supporter of Eddie's at one point, good luck getting any communication or customer service tho. I'll have a really good deal on some of his parts very soon if you know someone looking.
    agreed, .I'm looking into these now just concerned about the limitation of coverage to the bed for dry storage.Obviously no option for things like a tonneau cover but I've been planning a camper shell I just really love the looks and style of a bed rack.
  11. Jun 16, 2019 at 8:59 PM
    Rik808
    Rik808 Well-Known Member
    honestly if its a real good deal id say its fine, the only thing that you would have to reweld would be the bed rail part, and you don't "have to" you could just cut it and put extra bolts attachments to the bed track. the top bars bolt in so you shorten them and bolt them in the same way.
