guys with pelfrey front bumpers
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 12taco12, Nov 24, 2019.
  1. Nov 24, 2019 at 12:32 PM
    12taco12
    12taco12 [OP] Well-Known Member
    rochester NY
    2012 TX Pro
    Billy 5100s OME 886 Billy remote resi 5125 rear General hd packs TImbren superbumps/flipkit Pelfrey steel full hoop front SOS bolt on sliders Baja squadron amber fogs Baja 20" bar Aux fuse panel and switches custom 10 sub box double din
    so i noticed today with my steel front that the stock skid is like wedged between the frame and the bumper and doesn't loo like ill get off the skid with the bumper on? common? am i crazy? any else run into it
  2. Nov 25, 2019 at 6:03 PM
    old55guy
    old55guy Well-Known Member
    mike
    2011 dcsb trd white
    none
  3. Nov 25, 2019 at 6:16 PM
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    Yes i have the same problem on mine. I had to cut and bend the tabs that hold the front of the stock skid in place off to get the bumper to sit flush on the frame
  4. Nov 25, 2019 at 6:17 PM
    geekhouse23
    geekhouse23 The "Liftman" - @DrFunker
    2GMGMDCSB4WDTRDFTMFW!! TL;DR
    mostly stock, grocery gettin' Prius
    I don't have a problem. But I have aftermarket skids.
  5. Nov 25, 2019 at 6:17 PM
    Hobbs
    Hobbs Anti-Lander from way back…
    Yep…
    Rock Bangen', Desert Tamin', Gold Findin' Machine!
    Ask the dude that installed it.
  6. Nov 25, 2019 at 6:19 PM
    markus30
    markus30 Well-Known Member
    mark
    Florida
    2009 tacoma dcsb trd
    king 2.5 coils with resi in the front, dirt king lca, TC uca, archive towers, 14" rear kings, shackle flip, dakars HD. pelfreybilt front bumper, sliders and skids, brute force rear bumper, method nv 17" wheels, 35" ko2s, 4.56 gears locked, EBC brakes,TC spindle gussets, dual batterys, arb fridge, bunch of other crap..... more to come
    pretty sure it says right in the installation instructions that youll have to tweak the stock skid
  7. Nov 26, 2019 at 7:02 AM
    4WD FTW
    4WD FTW Well-Known Member
    '08 DC LB 4x4
    Icon Suspension Kit Pelfrey Bumper and Skid 4.56 Gears Detroit TruTrac Rear Archive Hammer Hangers Deaver U402 Stage 1
    It does sandwich that little stamped steel skid in there. I just cut the little hooks off since I was going aftermarket anyways. If you care though you can also loosen the bumper.
