Guys with Pro Comp 7089's
Discussion in 'Wheels & Tires' started by samhain, Mar 23, 2011.
  1. Mar 23, 2011 at 8:37 AM
    samhain
    samhain [OP] Well-Known Member
    Brandon
    Hilton Head, SC
    05 Tacoma SR5
    Ever since I mounted my 7089's I'm getting a vibe at around 45mph that come and goes. I know this could be a ton of different things that are causing it, but one that I would like to rule out is if hub centric rings are necessary for 7989's.
    Next question everyone will ask is, "Are the wheels hub centric or lug centric?"
    I honestly don't know. There are no fitment issues that I can see. I am using the provided center cap and I am using the shanked spline lugs that are necessary because of our short wheel studs and Pro Comps thick hub walls.
    If anyone can comment on whether or not their setup up needed hub centric rings I would appreciate it.
  2. Mar 23, 2011 at 2:55 PM
    mikesdoublecab
    mikesdoublecab LT Chase Truck
    Mohawk Mike
    Glendale, CA
    01 Tacoma DoubleCab V6 Prerunner
    Engage Offroad long travel front and rear with some fat tires.
    i think the Pro Comp hub centric wheels are drilled out to the Chevy center bore which is smaller than the tacoma, so you likely have lug centric wheels...
    don't quote me on that one though...
    im sure someone rolling the wheels wil chime in...
  3. Mar 23, 2011 at 3:10 PM
    HuntnTruk
    HuntnTruk Tacohead
    Kevin
    New York-not the City
    Indigo SR5 4x4
    I have the 7089's and I think they only only come in lug centric configurations. I could be wrong. But if you do in fact have lug centric wheels then you need special lug nuts with the extra tall shank. Wheelers has them
    NVM: read your post more clearly and you have the right nuts.
    So since you have extra tall nuts I think your wobble is something else.
  4. Mar 24, 2011 at 5:51 AM
    samhain
    Brandon
    Hilton Head, SC
    05 Tacoma SR5
    Thanks for the reply, how does yours drive and are you using the provided center caps?
  5. Mar 24, 2011 at 9:50 AM
    HuntnTruk
    HuntnTruk Tacohead
    Kevin
    Indigo SR5 4x4
    To be honest I havent put them on yet. There is still snow on the ground and it sux to work on the truck when its 20 degrees outside. Ill have them on in a couple weeks probably
  6. Apr 19, 2011 at 9:51 PM
    907taco
    907taco Alaskan Assassin
    Bobby
    Alaska
    2010 BlackSandPearl 4x4
    ultimate lift kit ( toytec ) ome dakar leaf pack , w/ extended length billies, LR uca's, Pro comp 7089s, KM2's 285 70 17, neoprene seat covers, weather techs, CBI sliders w/kickout, URD ss, cab mount chop, VHT night shade tint>tails,3rd B-light. Debadged. Grillecraft grille, rear diff breather mod. CBI Moab front bumper, warn M8000 winch, HID kragens 7", Hella's micro fogs. retrofit headlights HIDS, LED solutions maps/license! 886 back up light mod,
    i am running these wheels with Km2's with no issues. I too bought some lug "nuts" from wheelers. hopefully you figured this out. i get some vibrations when i get in the mud but a quick fix with garden hose is key. are you lifted in rear and what set up do you have. drive shaft carrier bearing drop kit might help or some shims, sounds like its random so these might not help.
  7. Apr 20, 2011 at 6:45 AM
    samhain
    Brandon
    Hilton Head, SC
    05 Tacoma SR5
    I have the helper spring in the rear providing the extra lift. I still am having the same issues, and the vibes are in the steering wheel, not the seat. I'm going to be replacing my pads and rotors soon, then I'm going with the LR upper control arms to get my alignment perfect.
  8. Apr 21, 2011 at 11:06 PM
    kumaWRX
    kumaWRX Well-Known Member
    Jase
    Oahu, Hawaii
    04 Prerunner TRD Offroad
    SAW 2.0 Coilovers, Wheeler's 3-leaf AAL, Toytec 1" lift shackles, Bilstein 5100 rear shocks, aFE Stg. 2 intake, Doug Thorley headers, Magnaflow muffler, 16x8 ProComp 7089 wheels, Toyo Open Country A/T tires, Pamalu bedliner, Bakflip G2 bedcover
    I have 7089s with Toyo A/T tires and i have zero vibes since I got them. I have the extended thread Gorilla lug nuts which I was told is a must.
  9. Apr 23, 2011 at 11:01 AM
    samhain
    Brandon
    Hilton Head, SC
    05 Tacoma SR5
    What size tires did you put on?
  10. Apr 23, 2011 at 10:45 PM
    JeenyusSB
    JeenyusSB Well-Known Member
    These wheels are being shipped to me right now. Could you post a link to were you got the Gorilla lugs. Did you get the black ones?
  11. Apr 23, 2011 at 10:52 PM
    907taco
    Bobby
    Alaska
    wheelers < they are a vendor here and they do not come in black.
  12. Apr 23, 2011 at 10:59 PM
    kumaWRX
    Jase
    Oahu, Hawaii
    I have LT265/75R16 Load Range C tires.
  13. Apr 24, 2011 at 3:52 PM
    JeenyusSB
    I couldnt find the extended lug nuts on their site. Just acorn style. I dont want to order the wrong ones
  14. Apr 24, 2011 at 5:19 PM
    907taco
    Bobby
    Alaska
    give them a call and let them know what you have and they will hook you up and don't worry they know what they're doing as long as you let them know what you have you will get the right part. Talk to Dan and he'll know what you need.
    i went with GOR 21138ET 12mmx 1.5 small diameter lug nut E/T style and 1921SD-key and i believe you can get regular style
