Guys with rcd lifts 4.5" need ur input fast
Discussion in 'Suspension' started by K1992f, Feb 22, 2011.
  1. Feb 22, 2011 at 3:25 PM
    K1992f
    K1992f [OP] Well-Known Member
    Kanon
    Dirty Hanover pa ...
    2012 tacoma TRD sport fully loaded
    6" fabteck 20" fuel hostage 33" nitto MTs
    Ok I have the rcd lift .. And ready to order rims now I'm not off-roading at all. The lift say 33/12.5 tire will fit with 4.5"BS rim the rims I'm looking at are 20"-10" will this still fit with the 4.5"BS even knowing it's a 10" wide rim .. Or will in rub bad ??
  2. Feb 22, 2011 at 3:27 PM
    08pretaco
    08pretaco Well-Known Member
    az
    2014 Tundra 4x4 CM 5.7L SR5
    what tire do they give you those specs for? 8,9"???
  3. Feb 22, 2011 at 3:29 PM
    K1992f
    Kanon
    Its up to a 9" but some guys say it will be ok just long as I have the 4.5"BS just trying to here from the guys that do have this lift
  4. Feb 22, 2011 at 3:32 PM
    08pretaco
    az
    why not just go with what you want and add a wheel spacer :eek: did i just recommend that?? since you said no wheeling just do it that way.
  5. Feb 22, 2011 at 3:37 PM
    K1992f
    Kanon
    Well the wheel I want come in 4.5" backspacing ?? And that's what the lift calls for I just don't with that 10" wide would do anything. I see you have 4" lift do u think u can get a 20"-10 to fit ??? With the right backspacing ??
  6. Feb 22, 2011 at 3:47 PM
    08pretaco
    az
    See the thing is on a 10" rim 4.5 bs does not mean the naive goes on the hub the same distance as on a 9" with 4.5 bs. You might need to look harder and find a 10" with 4.5 bs with some number of offset to set the naive a little further forward. Or also look into a 10" with 4" bs, that might be about right but do the research dont do by my word lol
  7. Feb 22, 2011 at 3:54 PM
    K1992f
    Kanon
    The wheel is 20"-10" with offset -24 with a BS 4.53
  8. Feb 22, 2011 at 4:01 PM
    08pretaco
    az
    the -24mm will add just under 1" of extra space...im thinking you should be fine with that honestly but im not 100%. How about giving RCD a call?
  9. Feb 22, 2011 at 4:08 PM
    jrobson
    jrobson Well-Known Member
    Mobile, Alabama
    09 DC 4x4
    Ultimate lift kit, LR UCA's, Bi-xenon 8000K headlights, Xenon 8000K foglites, (4) KC slimlites on N-Fab light bar, Extang trifecta toneau cover
    Ask Hbtacoma. He's running 20's on his rig. Mine jut has 17x9's and doesn't even come close to rubbing. Solus migh be able to help as well although he's running 18's. Solus knows his stuff though. That's where I'd start. Hope you like the RCD as much as I do.
  10. Feb 22, 2011 at 4:14 PM
    K1992f
    Kanon
    Man I trying talking to hbtacoma so maney times and i can't get anything out of him it's funny you bring him up cuz thats where I'm getting my idea from and I can't get anything out of him. I don't think he gets on here anymore
  11. Feb 22, 2011 at 4:48 PM
    TexasTacoma37
    TexasTacoma37 Well-Known Member
