GVRW
Discussion in 'Towing' started by mac84, Nov 11, 2022.
  1. Nov 11, 2022 at 11:09 AM
    mac84
    mac84 [OP] Well-Known Member
    Alabama
    2015 Tacoma TRD Sport 4WD MGM
    Just thought I'd share my experience with weighing my 2015 DCSB while looking at a few travel trailers.
    I have an ARE shell, Prinsu rack on the shell, and a low profile winch bumper with 10k Evo Warn winch.
    Didn't think too hard about GVRW when trailer shopping, just the trailer weight. I thought I wanted to keep the trailer weight under 5k and I'd be fine.
    Weighed the truck at the CAT scale with me (168 lb), my wife (120 lb) and a full tank of gas.
    5020 lbs.......
    Once I added the tongue weight of the trailer I'm over.... we were thinking 500 tongue weight but I've learned that most of the time the published number isn't real life.
    I love my Tacoma, but as most have said on here..... it's not meant to tow 90% off the TT's out there.
    moral of the story is that stuff adds up on these trucks!
    Got my trailer deposit back and will be figuring out plan B.
    Not even and room for dog or cargo!
  2. Nov 11, 2022 at 11:12 AM
    Clearwater Bill
    Billy
    Largo Florida
    Pretty common.
    But good for you in checking it out and backing off.
  3. Nov 11, 2022 at 11:13 AM
    mac84
    Alabama
    Yeah, Bill. We loved the trailer but just knew the numbers don't lie. Better safe and enjoyable than white knuckle. Been there and done that.
  4. Nov 11, 2022 at 11:40 AM
    muddog321
    muddog321 Well-Known Member
    FL
    09 Tacoma DCSB 4wd TRD Off-Road w/e-locker Pyrite Mica
    TW 1-piece driveshaft with 1310 u-joints All Pro and Budbuilt skid plates OME Dakar rear springs 3" with 5100 5100 front set at 1.75" (3rd groove up) with stock springs Falken Wildpeak A/T3W 265/70R16 2018 TRD Offroad wheels 16x7J with +25mm offset Powerstop rotors with Z36 pads and rebuilt with OEM caliper kit Complete rebuilt rear brakes drums, shoes, springs, wheel cylinders Rebuilt rear diff with Yukon 3.73 ring/pinion Denso 130A rebuilt alternator AGM 24F Battery New OEM idlers and tensioner assembly New AC compressor New PS hose and flushed Walker SS Quiet Flow muffler Denso Iridium long life plugs #3421 (SK20HR11) OEM coolant, cap, and thermostat NAPA CV axles and new seals ECGS bushing Rhino front guard Shortened mud flaps Alziria Black Tail Lights Nilight Headlights X-Bull Traction Boards Maaco full single stage paint job 2023 Nat CV to Knuckle seals 710573 New SKF wheel bearings/hubs BR930978 New Moog stabilizer links K80946 & 948 New MOOG K80819 Suspension Stabilizer Bar Bushing 28mm New Dorman rear wheel bearings using complete axles 926-139 & 140 New Radiator support bushings Dorman 924-267 (front body mounts)
    I've been there!! Smart man.
    There are some 19 ft trailers in the 3000 lb dry weight range out there even a few bunkhouse (BH) types with 2 bunks, a dinette and a full or queen single axle.
    I had (note past tense) a 26 ft that loaded went up from 4500 range up to 6000. Would pull it but ate my rear bearings. Not that fun of a tow. Then my 3000 boat was a cake walk.
    For some stupid reason I was looking at trailers again in 3000 lb range then did some calcs and a really bad move dollar wise.
    You will double your gas use so half the mpgs hear that sucking sound. Then when not in use storage fees for most people. Lots of fees now some up near $100 when on the road/night and even Walmarts are stopping all rigs from staying. Then that initial 10-15k at a minimum up to mid 20s. I loved dumping the pooper too. If you visit anyone on your trip at their home lots do not allow trailers in the street overnight even. Then in summer you need that AC on as you are in a metal can/box so a plug in or generator. So add it all up and hotels sure are cheap and the driving easier and faster. I go off on lots of forest service roads/trails so when I get way back in there (trailer would never make it anyway) my old tent for a day or 2 works.
    Bottom line for others is trailer rentals are very cheap starting at $100/night so rent a few times before you drop all that money and find it was not really what your expectations thought. You can rent close to where you are going also and save all that gas too. Then sit down and do the math! Soon there will be a ton of used trailers hitting the market sold in 2020-2021 but many paid close to double the price as before the pandemic which inflated the hype and price.
  5. Nov 11, 2022 at 11:43 AM
    mac84
    Alabama
    Muddog, you're so right!
  6. Nov 12, 2022 at 6:02 AM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    It's the accessories that are hurting you. A stock Tacoma should be able to tow 4500 lbs, 5000 if you load carefully. But not the advertised 6500 lbs.
    It's not just Tacoma. I hang out at the F150 forum. There will be someone posting there about once a week trying to figure out why their 1/2 ton truck is struggling to pull their new TT. Payload is almost always what bites you in the butt and when that is factored in virtually none of the mid-size and 1/2 ton trucks will actually tow what they are rated for. FWIW, some Tacoma's will tow more than some 1/2 tons.
    Even 3/4 tons run into the problem. I have a buddy who bought a 3/4 ton F250 with the 6.7 diesel to pull a 10,000 lb box trailer. The engine would move the load at 80 mph without breaking a sweat, but his truck was way over payload with 3 adult men in the cab. He pulled it a few times before deciding he could make do with a smaller trailer.
  7. Dec 13, 2022 at 8:53 AM
    GBourne
    GBourne Just a regular guy
    Grant
    Surprise, AZ.
    23 Ram 1500 Classic
    Dumped the Tacoma, that's all it needed.
