gwolff's Cargo Trailer Camper Conversion
Discussion in 'Other Builds' started by gwolff, Dec 9, 2017.
  1. Mar 8, 2018 at 9:32 AM
    #141
    Gnote
    Gnote Member
    Grant
    Ontario Canada
    2015 DCLB SR5 4x4
    885 coils 5100's Dakar med leaf pack ECGS Bushing Lear cap WeatherTec mats BF Goodrich Ko2 265/75/16
    Nice work so far!
    sub'd
  2. Mar 8, 2018 at 9:37 AM
    #142
    gwolff
    gwolff [OP] Well-Known Member
    In case anyone ever wants to do a bed like this... The tricky part is figuring out the dimensions.. particularly the length of each slat. You have to use a little algebra. The goal is to make it the desired width when opened and the minimum width when closed. I put together this document to help someone if they want to make their own. If you're doing something with a different width bed, you could easily replace 54" width with any other width and use the same process.
    You can plug in the dimensions of your wood and the formulas will tell you how long to make your slats
  3. Mar 8, 2018 at 2:35 PM
    #143
    Slashaar
    Slashaar Trail Limo Supreme & Certified Hole Massager
    Josh
    Kansas City, MO
    2015 Tacoma TRD-Sport DC LB
    Coastal HC Front, 6112s+650lb King Coils, JD 62 Swap + 14" Fox 2.0s
    There is a 6x12 on craigslist for really cheap... But I can't fit all of our stuff into the trailer xD Maybe if it was a gooseneck.
    You've made me rethink my bed design. I was going to just build a permanent queen sized frame wall to wall(whenever I actually start this project...). This is a way better idea!
    gwolff[QUOTED][OP] likes this.
  4. Mar 9, 2018 at 5:41 AM
    #144
    CanisLupus
    CanisLupus Member since 2011
    Stokesdale | NC
    ‘19 Honda Civic Hatchback
    That sliding couch/bed frame is super slick! Looking great.
    Slashaar likes this.
  5. Mar 12, 2018 at 9:34 PM
    #145
    gwolff
    Check it out... See anything new?
    If you look close.. you'll see... a door handle! Now my trailer door can function like a normal door. I never want to put a door handle in another trailer again. Huge pain in the butt to cut out the slots for the door to function. The metal is very thick and there's not much room to work. However, now that it is all said and done, it works perfect.
    In the pic below, you can see how I had to mount the strike plate. Because of how the door lines up, the latch didnt reach the strike plate. So the strike plate is mounted protruding a bit, but it works perfectly.
    Video where you can see how perfect the door handle works:
    https://youtu.be/niPw9TG079o
  6. Mar 12, 2018 at 9:45 PM
    #146
    Shmellmopwho
    Shmellmopwho Well-Known Member Vendor
    Lomita CA
    2013 White DCLB TRD sport
    Bunch of stuff
    This thing is coming along so awesomely!!! Great work dude
  7. Mar 12, 2018 at 9:47 PM
    #147
    gwolff
    I heard you know a guy named Todd, a family friend of mine who has a taco. He happened upon my thread by accident without knowing it was my trailer!
    Shmellmopwho[QUOTED] likes this.
  8. Mar 12, 2018 at 9:54 PM
    #148
    Shmellmopwho
    Lomita CA
    Bunch of stuff
    Todd who?
    Is he on here?
  9. Mar 12, 2018 at 9:56 PM
    #149
    gwolff
    He is apparently on here but I don't know if he has an account. I don't want to post his personal info but he says you installed sliders for him
    Shmellmopwho likes this.
  10. Mar 12, 2018 at 10:19 PM
    #150
    Shmellmopwho
    Lomita CA
    Bunch of stuff
    That’s awesome!! I’ve done over 100 sets of sliders in the last couple years so it’s hard for me to remember everyone’s names haha.
    The only Todd that I can remember right off the top of my head is KTM Todd
  11. Mar 12, 2018 at 10:24 PM
    #151
    gwolff
    Well that is understandable, I don't think he'd be KTM Todd (I'm assuming that's a user here)
  12. Mar 12, 2018 at 10:34 PM
    #152
    Shmellmopwho
    Lomita CA
    Bunch of stuff
    Yeah that’s a member named Todd that I’ve done sliders for haha
  13. Mar 13, 2018 at 12:12 PM
    #153
    Slashaar
    Josh
    Kansas City, MO
    Dude! This thing is sick. I'm so :jellydance:. I keep looking at trailers to buy lmao
    So when I buy one, wanna help me install a door handle? :devil:
  14. Mar 13, 2018 at 12:15 PM
    #154
    gwolff
    No, I will gladly sit back with a beer and read your posts about it though. Lol.
    What made it so tough was that the door edge is made up of steel tubing AND a heavy duty piece of steel angle back to back. I screwed up the weather stripping while trying to drill out metal. It was a really tough space to work in and try to remove such thick metal. I had to cut through a huge section for the latch and deadbolt to fit through.
    bdbrown and Slashaar[QUOTED] like this.
  15. Mar 13, 2018 at 1:47 PM
    #155
    Slashaar
    Josh
    Kansas City, MO
    I figured. Did you use a center drill first or just full metal drill bit straight in?
  16. Mar 13, 2018 at 2:02 PM
    #156
    gwolff
    I drilled it out with progressively larger bits. I used a pneumatic cut off wheel to try and connect the holes, but I couldn't fit it close enough to the lip of the door. I basically used my cordless drill and drill bits for most of it.
    Slashaar[QUOTED] likes this.
  17. Mar 14, 2018 at 6:29 PM
    #157
    gwolff
    I just got back from test driving the trailer. The fenders rub the tires. How could I F*** up so bad. Kill me now.
  18. Mar 14, 2018 at 6:43 PM
    #158
    Old School
    Old School You are ignoring covfefe by this member.
    Move the fenders up on the body, fill the old holes, spray the wheel wells to cover, done...
  19. Mar 14, 2018 at 6:50 PM
    #159
    gwolff
    Sounds good, but not that simple .. they are welded to the underside of the frame. It can be done, but also have to consider moving them up, they start to interfere with the door. There's also only a couple inches between the spare and the fender and the clearance light is mounted on it. They rub the back slope of the fender only. I have two weeks to finish everything and solve this.
    I am thinking I'm going to fender off the trailer in the rear, cut the miter of the fender and then try to stretch it out to open the fender more.
    Old School[QUOTED] likes this.
  20. Mar 14, 2018 at 7:18 PM
    #160
    jptheriot
    jptheriot Meso Investor #5
    Jp
    St. Louis
    3rd Gen TRD Sport DCSB 4x4 / previously owned 1st and 2nd Gen
    Step Bars / BakFlip FiberMax Tonneau Cover /5% Tint Rear 20% Front / Reverse Cam Anytime / Coin Holder / LED Interior and reverse lights / Katzkin Leather Interior / Hondo knobs / TRD Pro Wheels / Black badges / Pro grille / @mesojdm designed Ultimate LED side mirror turn signals, BTLM, BD 3rd Brake Light, GASSHOLE, Ultimate Dome Light, Ultimate Map Lights, Custom Fuse Cover, Custom OEMeso Headlights / In-dash Universal Mount with iOmount
    :sawzall::sawzall::sawzall::sawzall::sawzall::sawzall::sawzall::sawzall:
