gwolff's Cargo Trailer Camper Conversion
Discussion in 'Other Builds' started by gwolff, Dec 9, 2017.
  1. Mar 14, 2018 at 7:35 PM
    #161
    gwolff
    gwolff [OP] Well-Known Member
    Yeah dude. Here is what I'm going to try first. I did some calcs and I think it will move the point of contact away from the tire by about 1.5". Not sure if the drawing makes sense but basically I will open up the angle of the fender on the rear. It's going to take lots of cutting, grinding, and filling. Dunno if I'm even going to be able to do it.. to get the paint off in the corners to reweld. FML
    Jh5370, Drainbung and Slashaar like this.
  2. Mar 14, 2018 at 8:23 PM
    #162
    POOLGUY
    POOLGUY Well-Known Member
    JEFF
    ALABAMA
    2008 TRD Sport 6sp, 2015 TRD Offroad 6sp
    Dobinsons suspension
    Looks like it should work. When I use to weld back vaults together, we sometimes had to turn up the heat on the weld to burn off left on paint and other impurities. Good luck
  3. Mar 14, 2018 at 8:25 PM
    #163
    Slashaar
    Slashaar Trail Limo Supreme & Certified Hole Massager
    Josh
    Kansas City, MO
    2015 Tacoma TRD-Sport DC LB
    Coastal HC Front, 6112s+650lb King Coils, JD 62 Swap + 14" Fox 2.0s
    Just start from scratch and make some sick fenders. Might as well.
    :welder::itllbuffout:
  4. Mar 14, 2018 at 8:58 PM
    #164
    rebelchem
    rebelchem Well-Known Member
    Kevin
    Long Island, New York
    '14 DBL LB TRD Sport 4x4
    Just getting started
    Great stuff! Thanks for letting us into your world!
    gwolff[OP] likes this.
  5. Mar 15, 2018 at 8:04 AM
    #165
    gwolff
    I made these ones from scratch.. it took me a lot of time and around $300 worth of material. I only have two weeks before I'm supposed to take it out, I can't even work on them this week because I don't have access to the lift to take of the tires.
    I'm so screwed. I can't believe how bad I messed up. Honestly super down about this whole thing. If I modify the fenders they look like shit. If I make them from scratch then I don't have enough time and I lose a bunch of money
    Slashaar[QUOTED] likes this.
  6. Mar 15, 2018 at 8:07 AM
    #166
    Martyinco
    Martyinco Well-Known Member
    Any reason you cant modify the timbren suspension?
  7. Mar 15, 2018 at 8:09 AM
    #167
    gwolff
    I don't know of any way I could modify it. Each one is bolted through the frame in 3 places. I wouldn't want to mess with it anyways.
  8. Mar 15, 2018 at 8:10 AM
    #168
    Martyinco
    Add a spacer, weld spacer to existing frame, rebolt through new "frame" easy peasy
  9. Mar 15, 2018 at 8:11 AM
    #169
    gwolff
    So you're saying to raise the trailer another 3 inches? lol. I dunno, not the most practical
  10. Mar 15, 2018 at 8:12 AM
    #170
    Martyinco
    2" or 3" whatever you feel would give you enough tire clearance.
  11. Mar 15, 2018 at 8:17 AM
    #171
    gwolff
    It would have to be high enough to move the suspension to an area where new mounting holes could be located. It would also mean that the piece of tubing I welded in the frame to resist torsional forces of the suspension would not work as well. I think it would be safer from a structural standpoint to just rebuild the fender
  12. Mar 15, 2018 at 8:19 AM
    #172
    StOrMyThEtAcO
    StOrMyThEtAcO @stormythetaco
    Cody
    CO
    18 TRD Sport mom bus
    All of them
    Is your name garret by chance?
    Not being a creeper but I saw your face in a picture an you look hella framiliar.
    Used to work with the Scrivens in upland for waterhammer?
  13. Mar 15, 2018 at 8:22 AM
    #173
    gwolff
    Lol yeah, are you Natalie's boyfriend Cody?
  14. Mar 15, 2018 at 8:25 AM
    #174
    StOrMyThEtAcO
    Cody
    CO
    All of them
    Lol noooo I was zacks buddy was a year younger than him lived basically across the street. My last names Turner.
  15. Mar 15, 2018 at 8:28 AM
    #175
    gwolff
    Ohhh I know who you are. Man you're the second person to recognize me from my pictures, I should have known the repercussions! I still hang out with Zack all the time
  16. Mar 15, 2018 at 8:39 AM
    #176
    StOrMyThEtAcO
    Cody
    CO
    All of them
    Crazy how small the world is, that's good! He seems like he's doing well.
    Anyway, bad ass trailer I showed it to my wife an said we need one.
    Shmellmopwho likes this.
  17. Mar 15, 2018 at 8:40 AM
    #177
    gwolff
    Just make sure you don't fuck up the fenders like I did or you'll want to jump off a cliff for a while. Lol
    Drainbung likes this.
  18. Mar 15, 2018 at 10:54 AM
    #178
    gwolff
    I think I might try to go to a 33 inch tire. If that would solve my problem it would be worth it. I currently have 315/75 R16 Toyo Open Country tires. Not sure what the width of the rim is right now, so I don't know what tires to be looking for
  19. Mar 15, 2018 at 11:02 AM
    #179
    Shmellmopwho
    Shmellmopwho Well-Known Member Vendor
    Lomita CA
    2013 White DCLB TRD sport
    Bunch of stuff
    You could buy mine, wouldn’t be the first one you’ve bought from me :D
  20. Mar 15, 2018 at 11:03 AM
    #180
    fatfurious2
    David
    Ashburn, VA
    2010 TRD OR Access Cab
    Ill buy. Will your daughter go to college because of me?
    Shmellmopwho[QUOTED] likes this.
