Gy6.35 HIR 921 reverse light upgrade (vs high power LEDs)
Discussion in 'Lighting' started by crashnburn80, Feb 11, 2017.
  1. Mar 22, 2021 at 6:09 AM
    #521
    se7enine
    se7enine MCMLXXIX
    Reno, NV
    You can complain about them but you should get used to them, they aren't going away.
  2. Apr 7, 2021 at 1:20 PM
    #522
    crashnburn80
    crashnburn80 [OP] Vehicle Design Engineer
    Kirkland, WA
    2003 DCSB TRD OR
    stbear likes this.
  3. May 17, 2021 at 5:43 AM
    #523
    daveeasa
    daveeasa FBC Harness Solutions
    David
    PNW
    2016 Tacoma OR DCSB 6MT, 2005 RC 5MT PreRunner, 2002 Tundra SR5 RCLB 4x4
    Specifically regarding disabling of the license plate lights while in reverse:
    DIY thread
    BST thread
    NOTE: Third Gen specific at this time.
  4. Aug 27, 2021 at 7:37 AM
    #524
    Toy_Runner
    Toy_Runner Well-Known Member
    99 4Runner SR5
    3" OME lift, heavy coils f/r 3/16" steel skids Modified Coastal Offroad diy bumper 5spd swap ('98 donor)
    So I'm just reading through this thread... is there an equivalent anyone has found for 7440 reverse lights? Or a base adapter from the T6 wedge to the gy6.35?
  5. Aug 27, 2021 at 8:58 AM
    #525
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Covered in the original post, copied below. At least one member had some lens melting from the adapter putting the bulb too close to the lens, I do t recall which type of vehicle it was. So use caution and check for adequate clearance in your application.
    7440 bulbs
    I get many messages from non-Tacoma owners about reverse light upgrades. If you have a common 7440 reverse light, you may be able to use a 7440 to 921 base adapter to still run this mod,
    $15 PA 2x T10 168 194 to T20 (7440) Bulb Base Converter …
    like this one.
    Toy_Runner[QUOTED] likes this.
  6. Aug 27, 2021 at 9:36 AM
    #526
    BenMara
    BenMara That Asian RedNeck
    Ben
    Belton, SC
    2011 DC 4x4 SCed
    TRD Blower, Ham Radio, DBA T2 Rotors
    Just make sure it doesnt have a canbus that looks at resistive values of the Reverse bulbs...... you will be in for a spin.. LED bulbs Low resistance..... 921 Wedge Too HIGH resistance... SMH... gave up for the moment to get these to work in DD
  7. Aug 27, 2021 at 10:28 AM
    #527
    Toy_Runner
    99 4Runner SR5
    I need to take my own advice and start reading threads from the *Beginning* instead of working backwards. I had made it back past page 20...
    Thank you for the links, Crash.
    I will definitely check for clearance. I've been waiting for a set of LED 7440 bulbs to ship from Amazon, so I have a backup (pun intended) if the adapter addition ends up making it not work.
  8. Sep 26, 2021 at 3:59 PM
    #528
    Hayrider
    Hayrider Over the hill & going down fast...
    Hey You…
    Convection Oven AZ
    15 DCSB & X-cab SOLD for more than new‼️ Now 05 & 07
    Reg Cabs, 5 lug, 5 spd, Magnuson & LS Swap, StopTech’s, Yada Yada Yada…
  9. Sep 26, 2021 at 4:13 PM
    #529
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    I haven’t tried them myself. The 1000 lumen rating is raw, meaning actual will be much less. The 35w HIRs are 860 lumens actual, so they will be higher output. However in running those type of aux lights you typically have your standard reverse lights as well, so it isnt a direct comparison.
    Note that the DD Pros offer a flush mount flood as well, with significantly higher output than the Rigids, while also optionally having the 4000k color temp:
    https://www.diodedynamics.com/stage-series-c1-white-pro-flush-mount-led-pod-pair.html
  10. Oct 15, 2021 at 3:48 AM
    #530
    afgixxer
    afgixxer Well-Known Member
    Tennessee
    2021 Tacoma TRD-Off Road (Cement)
    I had these on my previous truck, was going to replace the same ones in the Tacoma but it seems they aren’t as good as the IR ones. They were super bright though.
    Alla Lighting Brightest T15 912 921 CANBUS LED Back-Up Reverse Light Bulbs, 6000K Xenon White 16W W16W 194 922 921KX 912KX 2400Lm CSP SMD Replacement for RV, Cars, Trucks https://www.amazon.com/dp/B078WY6DVS?_encoding=UTF8
  11. Oct 19, 2021 at 8:15 PM
    #531
    Steelhead Bum
    Steelhead Bum Well-Known Member
    Mitchell
    Eastern WA
    13 DCLB Sport 4x4, 92 AC MT 4x4
    Sorry if this has been covered. 27 pages is a lot to read through at once. I have a 2013 with oem led taillights. The passenger side is busted and has a small hole in it. It was sealed with a dime sized dab of clear silicon and has held up great for 3 years. It started to fail this summer and the “chrome” inside of the taillight started to oxidized. Now the entire thing is black. Looks like a BTLM if that was a thing. Time to replace the assembly. Originally I planned on replacing with these assemblies and preforming this mod.
    https://www.ebay.com/itm/1320935037...,osub=osub,crd=crd,segname=segname,chnl=mkcid
    I know these are nowhere near oem quality and you “get what you pay for” but the oem taillights leave a lot to be desired with the chrome and all. I think the solid red housing of the above taillights look better (super white truck). I know you can install 09 Assemblies, retain oem quality and achieve red lenses but I would like to retain the LED features. I know based off of the ultimate HL mod and most of your responses in that thread oem is king of assemblies when it comes to the headlights. Does the same apply to the taillight assemblies in terms of output/reflection? Should one be concerned with running higher temp bulb in an aftermarket assembly? Basically looking for you guys to talk me out of making a decision I might regret. Again apologize if this has been covered and apologize for the winded post.
  12. Oct 19, 2021 at 10:08 PM
    #532
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    First concern with those units would be the LEDs themselves. You are definitely looking at cheap china product, which doesn't tend to last for LEDs. I cannot tell you how many aftermarket LEDs taillights I see where part of the panel has failed or several emitters have failed. They will not last like OEM. The there is the question if they are as bright as OEM. Brake lights are a safety feature, they should be bright enough in direct mid-day sunlight to easily be seen. Reflector optics on the rear are essentially a wide-angle flood, even if output took a minor hit I wouldn't consider it a deciding factor for a reverse/tail light. Seals also tend to not last as long on aftermarket units. Hard to say how they would handle the higher temp bulb, but assuming they are the same dimensions (the bulb isn't closer to the outer lens) I wouldn't be too concerned. I think the big deciding factor is lower quality and shorter life, with the potential for lower LED performance.
    Steelhead Bum[QUOTED] likes this.
  13. Oct 20, 2021 at 4:32 AM
    #533
    Too Stroked
    Too Stroked Well-Known Member
    Tom
    South shore of Lake Ontario
    2021 4Runner SR5 Premium
    Why not buy a used set of OEM tail lights and be done with it? I have a set off a 2014 that I could part with pretty cheap. If interested, PM me.
  14. Oct 20, 2021 at 5:20 AM
    #534
    Steelhead Bum
    Mitchell
    Eastern WA
    Thank you both for the replies. Exactly the two guys I was hoping to receive some advice from. I’ve searched for some used oem assemblies and found a couple “locally” however the sellers are pretty proud of their prices. I’ll send you a pm to see what you want for them. What assemblies did you replace them with?
  15. Oct 20, 2021 at 5:39 AM
    #535
    Too Stroked
    Tom
    The ones I have area spare set I bought for my Tacoma with OEM LED tail lights. They never ended up going in.
  16. Oct 30, 2021 at 6:49 AM
    #536
    Wood Butcher
    Wood Butcher Well-Known Member
    2015 Pyrite Mica Tacoma TRD OR DCSB
    I f*ckin’ love this place! Finally got around to installing these bulbs. Couldn’t find bulbs a while back so I sat on this. Install was really easy. I didn’t have to bend the legs; just tightened up the receptacles and the bulbs are tightly seated. Illumination is so much better than stock and visibility with my topper isn’t as bad now. C&B for the win!!
    Thanks man!
    rimfire7 and crashnburn80[OP] like this.
  17. Dec 29, 2021 at 5:41 PM
    #537
    DuffyBank
    DuffyBank Well-Known Member
    I have an aftermarket rear bumper for my 3rd Gen being installed in 10 days. There are cutouts to fit BD S2 flush mounts, wondering if it would be better to enlarge the cutouts and fit DD SSC2 aux backup light kit with red backlight? Leaning towards the DD but input is appreciated.
  18. Dec 29, 2021 at 5:48 PM
    #538
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    The backlight really doesn’t add much for functionality, so I’d likely opt for the plug and play Bajas. But if you want DD instead, best to do the mods before the bumper install.
    DuffyBank[QUOTED] likes this.
  19. Dec 29, 2021 at 8:23 PM
    #539
    mynameistory
    mynameistory My member is well known
    Tory
    Redondo Beach, CA
    4Runner
    If they have a way of cutting the pattern easily, go for it. Widening holes that are already cut into the bumper would require some finesse with a cutoff wheel, and you'd want to make sure you don't overlap bolt holes and make them oblong.
    For what it's worth, the SSC2 flood pattern is much more diffused than the Baja equivalent. I used to have a single Baja S1 wide cornering in the trailer hitch (Hitchpod) and switched to two SSC2s in the bumper (sport flood, 4000K). Granted the WC may not be the right optic, but it was so bright that everything within the "cone" was blinded and nearly impossible to see in the backup camera. I much prefer the overall gentler and widespread illumination from the SSC2s.
  20. Dec 29, 2021 at 9:15 PM
    #540
    daveeasa
    David
    PNW
    Yesterday I ordered pros in flood w red backlight for my bumper. Probably be many months before I get them operational unless @AY_ARONTRD helps me fast track that stuff. I’m on slow boat truck mod speed these days. Stockpiled a bunch of gear though.
