H@LP Me Wire my LED DTRL ! <THANKS>
Discussion in 'Lighting' started by RAD, Feb 15, 2012.
  1. Feb 15, 2012 at 1:52 PM
    RAD
    RAD [OP] RAD Vendor
    THE RAD
    Socal
    2007 | TRD | THE RECHRUNNER
    2012 CONVERSION | TOTAL CHAOS & ICON DYNAMICS |
    Need your HELP with some wiring for my LED DTRL.
    Ok, I don't know where the 2 wires on the outside go. I know the two wires on the inside go to the lights itself. The outside I have no clue. There were no instructions that came with it.
    Thanks in Advance.​
    I know the two middle ones. How about the two outside ones?
    Where do these go?
    Where do these go?
  2. Feb 15, 2012 at 2:08 PM
    Jerez
    Jerez SoCal LED Dash Swap
    Rod
    Diamond Bar, CA
    08 TRD Sport
    Estock
    ok from what i can see, you have:
    2 wires that go to a switch
    2 to the lights
    2 to the battery (or source of power)
    right?
  3. Feb 15, 2012 at 2:10 PM
    knine00
    knine00 Well-Known Member
    Hudsonville, Mi
    12 PreRunner DC TRD Sport
    Stock for now
    Sorry man I am no help but where did you pick those up at?
  4. Feb 15, 2012 at 2:17 PM
    jblaze805
    jblaze805 Well-Known Member
    Ventura/Fresno, CA
    04 trd pre-runner
    2.5" king coilovers, caburg uca, magnaflow exhaust, aem intake
    i say just ditch the wiring harness and tap your led power to the power of the DTRL'S and then connect the ground to the frame that should work unless you need the ballast to power the led's
  5. Feb 15, 2012 at 2:18 PM
    RAD
    RAD [OP] RAD Vendor
    THE RAD
    Socal
    I doubt i can tap them as they probally need the ballast as they're bright
    ^ Ebay. Theyre real nice but they no work right now. LOL
    I suppose. If I knew ROD> I wouldn't have asked. Notice the prongs on each outside wires are the same. . . Didn't get a switch.:confused:
  6. Feb 15, 2012 at 2:19 PM
    jblaze805
    Ventura/Fresno, CA
    04 trd pre-runner
    a way to also test out to see if ur leds will work without that wiring harness is touch the positive to the + of your battery and the ground to the - of your battery. but dont do it if your unsure and that it might ruin the leds juuuuuust in case
  7. Feb 15, 2012 at 2:19 PM
    Jerez
    Rod
    Diamond Bar, CA
    08 TRD Sport
    Estock
    i thought the same thing actually....but if im thinking like ray :p, hes going to want to have a seperate switch to turn them off as he pleases...plus alot of the new led lights out there have there own "ballast" type of relay :cool:
  8. Feb 15, 2012 at 2:20 PM
    Jerez
    Rod
    Diamond Bar, CA
    08 TRD Sport
    Estock
    lol, well im saying there are 6 wire connectors from what i see.....
    my quick guess from the pics is exactly what i said up top...if so, youre going to need a switch to "trigger" them on...
    it doesnt look so hard to wire up....when you free?? so i can go check them out
  9. Feb 15, 2012 at 2:22 PM
    RAD
    RAD [OP] RAD Vendor
    THE RAD
    Socal
    ^ I Just text you.;)
    LMAO. The fact you said I might ruin it puts that UNSURE Feeling in there. LOL
  10. Feb 15, 2012 at 2:25 PM
    jblaze805
    Ventura/Fresno, CA
    04 trd pre-runner
    ooo ok, but dang i didnt think leds would need a ballast to power them up. good to know though. now back to helping ray with these. anyone else got any ideas??????
  11. Feb 15, 2012 at 2:27 PM
    Jerez
    Rod
    Diamond Bar, CA
    08 TRD Sport
    Estock
    some do because of the strong light output they produce :cool: almost as strong as running hids....n some as a precaution so they dont short anything else lol :laugh:
    im going to meet up with RAD in about an hour to look at the wiring :thumbsup:
  12. Feb 15, 2012 at 2:42 PM
    knine00
    Hudsonville, Mi
    Stock for now
    Do you have the link on ebay? I want to check these bad boys out!
  13. Feb 22, 2012 at 8:42 AM
    hotrod45
    hotrod45 Well-Known Member
    paul
    sarasota fl
    16 sr 5 access cab
    send them back. if the source isn't willing to provide a piece of paper to tell you how to instal their product, get some from someone who will.
  14. Feb 22, 2012 at 8:43 AM
    Jerez
    Rod
    Diamond Bar, CA
    08 TRD Sport
    Estock
    i got them to work :thumbsup:
    alot of stuff lately doesnt bring instructions on how to "install/wire up"
  15. Feb 22, 2012 at 5:55 PM
    FFRNDAN
    FFRNDAN Well-Known Member
    Dan
    Edinburg, Oh
    09 Acess Cab 4x4 MGM
    Post up the link where you got these from, and which wire goes to what!
  16. Feb 23, 2012 at 11:14 AM
    three west
    three west Well-Known Member
    JD
    UP MI
    09 DC SB TRD Sport
