H11 halogen fog light bulbs not fitting
Discussion in '3rd Gen. Tacomas (2016-2023)' started by HottNikkels, Dec 5, 2017.
  1. Oct 7, 2021 at 4:57 PM
    #41
    Tacomaryan18
    Tacomaryan18 Well-Known Member
    18 Ltd Dbl SB super white
    Just my two cents on this thread. I’m having the same problem where I bought H11’s to go into my 2018 limited fog light housings. The bulb wouldn’t twist in. Plastic housing with H16 bulbs. Back to the store I go..
  2. Jan 16, 2023 at 12:08 PM
    #42
    Otterstuff
    Otterstuff Well-Known Member
    2022 White SR5 Access Cab 4WD V-6
    Tube steps, Vision Turbine wheels, bug deflector, seat covers, and tonneau cover
    I'm having the same problem in my 2022 SR5. The H11 will not fit into the housing. Has anyone cut the tabs and installed H11s without melting wiring or housing? The stock fog lights are worthless.
  3. Jan 16, 2023 at 5:36 PM
    #43
    Toy_Runner
    Toy_Runner Well-Known Member
    99 4Runner SR5
    3" OME lift, heavy coils f/r 3/16" steel skids Modified Coastal Offroad diy bumper 5spd swap ('98 donor)
    They don't fit because your vehicle uses foglamps designes for the H16 bulb. Despite sharing a base with the H11 bulb, they are not cross compatible. And there are no "good/decent/upgrade" H16 bulbs. Its a low plwer, low intensity spec.
    The earlier H11 wide angle fogs are significantly better. Howevevr, for not much more than picking up a set of those, you can grab several much better oerforming LED fog lamps, a ton of which have been tested and compared in the SAE J583 LED fog lamp thread stickied at the top of the Lighting subforum.
  4. Jan 16, 2023 at 5:36 PM
    #44
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Black 4x4 Sport MT 2018
    Some Serious Tires
    I tried on my Canadian taco and h11 did not fit in the stock fog light housings.
  5. Jan 16, 2023 at 5:37 PM
    #45
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Some Serious Tires
    You in Canada?
  6. Jan 16, 2023 at 6:14 PM
    #46
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    All Canadian 3rd Gens are H16.
    Junkhead[QUOTED] and shakerhood like this.
  7. Jan 16, 2023 at 7:05 PM
    #47
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Some Serious Tires
    I thought so, thanks for confirming.
    crashnburn80[QUOTED] likes this.
  8. Jan 17, 2023 at 4:43 AM
    #48
    Otterstuff
    No. Midwest US. I have H16. Not sure if my lenses are glass or plastic but H11 do not fit.
  9. Jan 17, 2023 at 9:40 AM
    #49
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Right, all SR5s got H16s and all 2020+ trucks got H16s.
  10. Jan 18, 2023 at 4:50 AM
    #50
    Otterstuff
    My lens is plastic but I would sure like a brighter bulb so I don't have to replace the lights. I wonder if H11 bulbs would melt the housing, lens, or wiring.
  11. Jan 18, 2023 at 9:20 AM
    #51
    AZPhys13
    AZPhys13 Well-Known Member
    2021 TRD OR DCLB - MGM
    I tried the H11s in my 2021 housings and I wasn't impressed with the heat that was generated on the plastic lens. I ended up getting some older used housing with the glass lens and have been happy.
    Otterstuff likes this.
