H20 in Headlights?? Help
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Shemicals, Nov 1, 2010.
  1. Nov 1, 2010 at 11:58 PM
    Shemicals
    Shemicals [OP] Well-Known Member
    Concord - East Bay CA
    '07 5-Lug Black Sand Pearl Access Cab 2WD
    Build Page
    my projector headlights have some humidity in them. some droplets of water along the inside of glass. a good amount though. any way to get the water out?
  2. Nov 2, 2010 at 3:00 AM
    Turdburglar
    Turdburglar Well-Known Member
    Enola, PA
    '10 DCSB SR5
    Trifecta, AVS Bugflector, TRD skid plate, 45% tint front windows, Gerber carseat lol
    In my last car, the way I would fix it was quite easy. First, park your car so the front end is facing the sun for a few hours. Then remove the lights from the housing. The heat from the sun will cause the moisture to evaporate through the through the empty light holes.
    Of course you need a more permanent fix, but this is how I always got rid of the moisture.
  3. Nov 2, 2010 at 3:58 AM
    Wattapunk
    Wattapunk Stay lifted my friends !
    Uncle K
    TX
    2005 Dbl Cab LB 4x4 TRD
    Toytec CO's, IRONMAN rear leaf pack, All pro front bumper, Body Armor rear bumper, BA steps MB TKO's w/285/75/16 Terra Grapplers, Bakflip tonneau cover, autopage remote start alarm, Ultragauge
    Probably the best fix and prevention is taking it apart like your doing a BHLM. Clean it well, re-install and make sure to silicone the housing well to prevent future leaks. Just letting it sun dry may leave water spots on the inner lens surface.
  4. Nov 2, 2010 at 5:09 AM
    rbeezy
    rbeezy Well-Known Member
    Ron
    Bay Area
    2011 Tacoma SR5
    x2 almost all aftermarket lights need to be siliconed before installation
  5. Nov 2, 2010 at 6:07 AM
    macgyver
    macgyver Well-Known Member
    Brad
    Canton, GA
    '13 Tundra double cab SR5 4x4
    Pull your headlight bulbs out, then tie some silica gel packets to a string, then drop them in your headlight housing through the bulbs holes, also let it sit in the sun. It should get rid of it. You probably also wanna seal the headlights with silicon as mentioned above.
    The permanent solution would be to throw the projector headlights in the trash and install a set of OEM headlights.
  6. Nov 2, 2010 at 10:40 AM
    Shemicals
    Build Page
    Lol
  7. Nov 2, 2010 at 12:44 PM
    textoytaco
    textoytaco Member
    Houston, Texas
    08 Tacoma Double Cab 4x4
    A friend of mine took her Bronco into the dealership because one of the headlights was full of water. They told her it was supposed to be like that. So, she asked him to fill up the other one, since it was dry. :D
