H4: icon is blinking, H4 doesn't want to engage
Discussion in '2nd Gen. Tacomas (2005-2015)' started by sernv99, Feb 12, 2010.
  1. Feb 12, 2010 at 3:23 AM
    sernv99
    sernv99 [OP] Member
    northern VA
    2010 Tacoma TRD Sport
    With all the snow in the DC area, I have been using my H4 mode in my 2010 Tacoma. I just shift on the fly, under 60mph.
    Yesterday, I parked my truck and left it in H4 considering the parking lot where I park is still full of snow and ice. This morning I start up the truck and the green 4wd icon on my dash is blinking. So I dis-engage the H4 back to H2 and re-engage H4 again and is still blinks.
    any thoughts?
  2. Feb 12, 2010 at 3:36 AM
    kanelakos
    kanelakos Well-Known Member
    Binghamton, NY
    16 DC LB Sport
    sometimes you have to move a little to engage/disengage. Try going forward some and then back some. If moving down road or highway under 62mph and you switch from 2wd to 4H or vice versa, usually I have to let off gas for a second or so then resume and tranny will switch up to what you want.
  3. Feb 12, 2010 at 3:36 AM
    swise
    swise TRIFECTA!!!
    ohio
    08 4x4 dbl cab, TRD offroad
    Thats odd. I leave mine locked in while the truck is off alot with no problems.
    did you drive the truck to disengage and start over?
  4. Feb 12, 2010 at 3:48 AM
    sernv99
    sernv99 [OP] Member
    northern VA
    While driving out of my parking lot, I tried to engage H4 and the icon was still blinking, even putting the car in N to see if some quirky way the H4 was acting like L4 (where you have to be in N to engage). I am work now so as soon as I get off from work, I will try engage H4 again and see what happens.
  5. Feb 12, 2010 at 4:16 AM
    MattN03
    MattN03 Well-Known Member
    Bluegrass State
    SOLD: 07 DC 4x4 TRD Off-Road
    20% window tint, beep mod, hardwired V1, TSB springs, AVS Bugshield-21803, USA Spec PA15, OEM Tacoma scuff plates, Weathertech mats, Truxedo LoPro, TRD skid, GY Duratrac's 265/75/16 C Range, locker mod (switch method)
    I've left mine in 4H overnight w/o any issues, so that is odd. At least you should be under warranty if you have an issue.
  6. Feb 12, 2010 at 4:35 AM
    Simon's Mom
    Judy or Jude :)
    NEK Island Pond VT
    24 Tundra Trd Sport former 13 TRD OR
    Stock for now
    If it keeps up after all the tricks (neutral, reverse, pulling fwd slowly, letting it sit, warm up, cool down, praying while turning the knob). take it to the dealer to get it checked out.
    Mine did the same thing out of the blue & it was the 4WD actuator covered under warranty. No problems since.
  7. Feb 12, 2010 at 9:23 AM
    David K
    David K Well-Known Member
    Pala Mesa, California
    2010 4WD Off Road DC
    Leave it 4WD... overnight, 10 days, makes no difference. When the snow melts and the roads are dry, then go back to H2.
