H4 in gear 1 or 2
Discussion in '1st Gen. Tacomas (1995-2004)' started by zuhlio, Dec 7, 2019.
  1. Dec 7, 2019 at 10:43 AM
    zuhlio
    zuhlio [OP] Member
    On an automatic first gen, I'm wondering if you can shift into H4, then shift into 1st or 2nd as an alternative to going into L4.
    It might be nice to do on the fly if encountering a steep, snowy hill.
    TacomaJunkie8691 likes this.
  2. Dec 7, 2019 at 10:48 AM
    eon_blue
    Azusa, CA
    You can shift into 4hi on the fly and then shift into any gear you want no problem. Of course don't shove it into 1st If you're going 30mph but you wouldn't do that in 2wd either. If you do go into 4lo though you have to be at a complete stop to get it into low range.
  3. Dec 7, 2019 at 10:51 AM
    coopcooper
    coopcooper certified youtube mechanic
    alberta canada
    black on black on black 05 trd off road
    stickers and sticker accessory's
    Or just put it in 4hi and let the truck do the rest.
  4. Dec 7, 2019 at 10:53 AM
    Indy
    Indy Master of all I survey.
    1st in 4hi is the same as 1st in 2wd.
  5. Dec 7, 2019 at 10:56 AM
    zuhlio
    zuhlio [OP] Member
    This would mainly be for the situation when you are driving along something snowy/rocky/icy and come across a steep downhill and would prefer to let the engine help out with the braking.
    So no damage would be done?
  6. Dec 7, 2019 at 10:58 AM
    eon_blue
    Azusa, CA
    Nope, nothing about being in 4hi would make downshifting any different than being in 2wd. As long as you're using it in the right conditions (ie not on dry pavement).
  7. Dec 7, 2019 at 11:01 AM
    zuhlio
    zuhlio [OP] Member
    Follow up question, how is H4 in 1st different than L4?
  8. Dec 7, 2019 at 11:05 AM
    Indy
    1st is identical, as is every gear. There's no change in the transmission. The tcase, low range affects everything. Hi range affects nothing. All it does in hi is turning the front driveshaft.
  9. Dec 7, 2019 at 11:39 AM
    zuhlio
    zuhlio [OP] Member
    I'm not very knowledgeable on how transmission mechanics work. Could you explain this in a different way?
    BassAckwards likes this.
  10. Dec 7, 2019 at 11:45 AM
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    The transfer case is what dictates whether youre in high or low range, so the trans would not affect this. The transfer case and transmission are separate so it sound like your issue is the transfer case not going into 4high
  11. Dec 7, 2019 at 11:46 AM
    coopcooper
    alberta canada
    4lo changes your gearing ratios so every gear is low range or something
  12. Dec 7, 2019 at 11:57 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    Source a copy of the owners manual for your truck .
    I never learned how to rebuild or drive a Automatic so not much help
