H4Low and rear diff lock help
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 106Tacoma, Dec 23, 2008.
  1. Dec 23, 2008 at 8:43 PM
    106Tacoma
    106Tacoma [OP] Well-Known Member
    Debadged 06 Black Sand Pearl 4x4 Every option.
    I felt like trying 4x4 low today and my rear differential lock, had truck in first gear and neither would work? Am i doing something wrong?
  2. Dec 23, 2008 at 8:47 PM
    jhodge83
    jhodge83 They all float down here... Moderator
    SC
    17 XLT Sport
    3rd gen forum caused me to get a Ford
    i think u need to be in neutral, then put it in 4hi, then 4 lo, then the locker...but i dont have a locker, so i dunno....but i think thats how i did my 4lo
  3. Dec 23, 2008 at 8:48 PM
    TRD4x4858
    TRD4x4858 Taco Traitor!
    San Diego
    95 Jeep XJ
    BONE STOCK! lol
    Put the truck in neutral, switch to 4wd or 4lo, put shifter in low, press diff lock button and have fun! make sure your in loose terrain
  4. Dec 23, 2008 at 8:48 PM
    106Tacoma
    tried that too, 4 low only blinks and makes a beeping sound and the locker only blinks. Followed the directions in the manual too , nothing.
  5. Dec 23, 2008 at 8:49 PM
    TRD4x4858
    San Diego
    95 Jeep XJ
    BONE STOCK! lol
    hmm sounds like you got a problem
  6. Dec 23, 2008 at 8:50 PM
    jhodge83
    SC
    17 XLT Sport
    definately gotta get it into 4lo before the locker....but once ur in 4hi, put it in neutral, turn it to 4lo, then puit it in D and slowly move while turning the wheel
  7. Dec 23, 2008 at 8:50 PM
    106Tacoma
    ARG! Guess its the dealer again for me. Maybe they can figure out why my truck is so bad on gas, im guessing i need to change plugs? It only has 22,000 miles.
  8. Dec 23, 2008 at 8:52 PM
    106Tacoma
    Also the other day when i was driving around 40 mph in 4x4 high the truck seemed like it was fighting itself to move, jerking the whole time.
  9. Dec 23, 2008 at 9:10 PM
    nvdeserted
    nvdeserted Well-Known Member
    Reno, NV
    2009 Tacoma TRD OR Access Cab
    Electric Dynolock tailgate, TrailGear Slides, , 285/75-16 Yoko Geolanders on Wheelers Type B, SAW 2.0 front and back, Camburg b/j UCA, 1.5" AAL, Ubolt flip, ARB bump.
    Hmmm, sounds like a problem, I'm assuming you've never had this work successfully before?. It must be in Neutral (foot on the brake) to engage the 4Lo (give it a second) once the 4Lo is engaged, put it in Drive, then push the locker button while under 5mph.
    Also, your last two comments sound like an engine issue, not a 4x4 (drivetrain) issue. The truck requires a bit more power to run 4x4 than it does 4x2, so if your engine is crapping you will definitely feel it in 4x; also concurrent with the MPG loss.
  10. Dec 24, 2008 at 1:15 AM
    Krazie Sj
    Krazie Sj Resident Jackass
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    Borla Catback Exhaust, Snorkel, 33s on either 16's or 18's, ARB Bumper, All Pro LT w/Walker Evan Shocks front and back, All Pro expedition leaf pack, 10,000lb Superwinch, Intake Manifold Spacer, Bed Rack with ARB RTT, Rotopack and Hi Lift mounted, Husky Liner mats and an air freshener from 1995.
    Sounds like he's using 4WD on dry pavement.
  11. Dec 24, 2008 at 4:39 AM
    106Tacoma
    dry payvment has not been seen in buffalo in around 4 weeks. at least 4 inches of snow on the ground every day. Im taking it to the dealer soon.
  12. Dec 24, 2008 at 9:30 AM
    106Tacoma
    Ah it works today yay.
  13. Dec 24, 2008 at 9:31 AM
    Krazie Sj
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    Any idea what caused it?
  14. Dec 24, 2008 at 9:39 AM
    106Tacoma
    I dont know, but my front end vibration is back with full force now that the roads are just wet today, this happend after the dealer worked on my truck, suspension tsb, now it vibrates like a pos!
  15. Dec 24, 2008 at 10:07 AM
    311offroad
    311offroad Stock Taco For Now
    Milledgeville, GA
    2005 TRD OffRoad SR5 4x4 Short Bed Debadged
    20% tint, Debadged, Pioneer AVIC-Z110BT, Infinity component door speakers, MagLite mod
    to get into 4lo I put it in nuetral while the truck is still rolling very slowly... click it in 4lo and move the steering wheel back and forth for just a few seconds. usually clicks right in :)
  16. Dec 24, 2008 at 11:09 AM
    steviestyles
    steviestyles The "Search" tab is your friend!!
    Colorado Springs
    07 DC 4x4 TRD Off Road
    Bone Stock
    Sometimes you have to drive a few feet before the Diff kicks in; especially if you haven't used it in awhile.
  17. Dec 24, 2008 at 11:45 AM
    jrws6
    jrws6 Well-Known Member
    Western North Carolina
    07, Dodge Ram 35004x4 Cummins Turbo Diesel 6M
    If you have a manual tranny the CLUTCH has to be pushed through the floorboard it seems like the entire time the switching and blinking is goin on. (Unless you unhooked the clutch safety wire. HEHE)
  18. Dec 24, 2008 at 1:54 PM
    nvdeserted
    Reno, NV
    They are supposed to re-align the front-end after the suspension TSB. They probably either didn't do it, or they did it wrong. Raise hell.
  19. Dec 24, 2008 at 11:08 PM
    106Tacoma
    They did do it wrong when i showed them after goodyear did it right they just said oh. I dont know how i can get anything from it! My tired are screwed up and my truck has vibrated since the tsb.
