H9 harness with an extra hot wire
Discussion in 'Lighting' started by a2lowvw, Jun 1, 2021.
  1. Jun 1, 2021 at 4:42 PM
    a2lowvw
    a2lowvw [OP] Well-Known Member
    Justin
    Bothell, Wa
    2019 DCSB Limited
    Stuff and things
    Wondering if anyone has a H9 male to female extension harness? Looking to modify the harness that came with my DD Stealth so it triggers off the high beam without using a wire tap.
  2. Jun 1, 2021 at 4:53 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
  3. Jun 1, 2021 at 5:04 PM
    daveeasa
    daveeasa FBC Harness Solutions
    David
    PNW
    2016 Tacoma OR DCSB 6MT, 2005 RC 5MT PreRunner, 2002 Tundra SR5 RCLB 4x4
    There are various options. You might want a rocker for on / off / auto (on with high beam). And to some degree it depends on the harness for your light, does it have a DRL / backlight, does it have relays, etc.
    I’m on the hook for some rough country light bar harness stuff already, this sounds a little similar, though those ones are requested with direct switch control.
    But for just a T tap male and female on halogen or led connector to grab the high beam positive, easy peasy. Hit me via DM and/or post up on the custom harness thread linked in my sig.
    Tacospike likes this.
  4. Jun 2, 2021 at 7:36 PM
    caribe makaira
    Caribbean, Puerto Rico
    If you only need ON with high beams, then you could run a small gauge wire to C11_headlight stalk switch connector. @Puppypunter could supply you a no cut T harness for that. You could place an switch for ON with high beams or OFF with high beams. Inline relay required and fused power also.
    daveeasa likes this.
