H9 Lamp Heat Question
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Axe78th, Oct 28, 2024.
  1. Oct 28, 2024 at 3:37 PM
    Axe78th
    Axe78th [OP] Member
    Greetings All,I did some searching thru the forum here but haven't found much info I'm looking for on this. I'm planning on putting some Phillips H9's in my low beams, 2016 Tacoma. I'm concerned the extra 10 watts might melt my stock harness/connector over time. Any of you folks that have done the conversion had any issues with the extra "heat/watts" of the H9? Thanks in advance
  2. Oct 28, 2024 at 4:09 PM
    chuam
    chuam Well-Known Member
    Marcus
    San Diego
    2017 Tacoma SR5 DCSB 4x4
    Icon Stage 3 - 2.5 & UCAs front, Icon 2.0 rear Icon RTX Stage 2 leafs Icon 700lb springs RSI Smartcap Evo Sport KDMax Pro tune BAMF Hybrid front bumper Warn VR EVO 10s winch ARB Rear Locker Revolution 5.29 regear RCI Engine Skid RCI Trans skid RCI Transfer case skid RCI Diff Skid RCI Cat guards RCI Rock sliders RCI roof rack R4T LCA Skids DRT Fabrication Hitch Skid Exhaust reroute ARB Dual Compressor w/ Slee Mount OR Black Fenders Diode Dynamics SS3 Pro fog lights Rigid D-SS Pro Ditch lights Rigid SR Amber PRO Edition 30” light bar Rigid SR-Q floods A/C drain mod Differential Breather Mod Supralee Traction Board mount Liftd Gas cap holder Taco Garage DMM 2.0 Total Chaos bed stiffeners TRD SEMA Pro 17" wheels Falken Wildpeaks 275/70r17 TRD Pro Grill Gecko shell lighting Ecological Bumper shells Fumoto valve Toyota aluminum oil filter cap DesertDoesit Seat Jackers Waterport Day Tank - Rago Fab bed mount Yakima Double Haul OVS 270 Awning Wet Okole seat covers Overland Equipped/Blueseas Bracket/fusebox Toyota OEM tailgate lock Rogue Offroad poly body mount bushings ZPrecision cup holders H9 headlight bulb upgrade Lambtek innovations winch switch
    Been running H9 bulbs for almost 2 years. Zero issue with them
    BC Hunter and Smacky2020 like this.
  3. Oct 28, 2024 at 4:18 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Ran H9s for several years. At least four with no issues. Had a problem on a bike where a hotter bulb melted some parts.
    I would love to recommend a HID kit if you want to throw controlled light. Cheap kit from Amazon has been killer. Way better than H9s.
    atc250r likes this.
  4. Oct 28, 2024 at 4:20 PM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    no problem with H9s, myself and many others have used them for years.
    Barsoom, musicisevil and BC Hunter like this.
  5. Oct 28, 2024 at 4:51 PM
    eurowner
    eurowner Duke Sky
    Scoty
    No problems! Do it!
    musicisevil likes this.
  6. Oct 28, 2024 at 8:30 PM
    Smacky2020
    Smacky2020 Well-Known Member
    Bristol, VA
    2020 TRD ORDC - Cement
    Stock wheels and suspension. Random "utilitarian" mods featured on this great forum.
    Same as everyone above. Been running without issues for over 2 years and plenty in the sticky light thread doing the same. One of the cheapest upgrades you can do.
    BC Hunter likes this.
  7. Oct 29, 2024 at 5:42 AM
    Axe78th
    Axe78th [OP] Member
    Thanks so much for the quick replies all!!
  8. Oct 29, 2024 at 7:26 AM
    Molina67
    Molina67 Well-Known Member
    Ken
    2022 Tacoma SR5
    Same here been running them for over 2 years no issue
