Haaaalp! Map and dome lights don’t work.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by DeusVult77, Nov 25, 2019.
  1. Nov 25, 2019 at 12:21 PM
    DeusVult77
    DeusVult77 [OP] Member
    Nahamsha
    2015 Taco TRD OR
    Red LED dome and map lights, overland mods coming with time.
    First off, hi everyone. FNG here... this is my first Taco even though I’ve wanted one since I saw Marty McFly’s. I just bought my 15 Taco TRD OR a month ago. I bought the LED map and dome light kit from Tacoma Beast. I figure it was $15 so why not. Now my map and dome lights don’t work. I’ve checked and replaced all the fuses and nothing. I 180’d the led’s figuring polarity, nothing. I tried putting the original bulbs back in... nothing. Any help would be greatly appreciated. Thanks!
  2. Nov 25, 2019 at 6:07 PM
    Muddinfun
    Muddinfun Well-Known Member
    Did you replace this one?
  3. Nov 27, 2019 at 11:59 AM
    DeusVult77
    Nahamsha
    2015 Taco TRD OR
    I did, but didn’t pay close enough attention. It’s supposed to be a 7.5 and it had a 5 in it. How the lights were working I don’t know. The 5 I put in popped. I just switched it out with the correct 7.5 fuse and they work now. Thank you!
    Muddinfun likes this.
  4. Nov 27, 2019 at 12:59 PM
    rphillips
    rphillips Well-Known Member
    Rick
    Norene TN.
    2013 Reg. cab 4x4
    none
    That seems odd, I'm no electrician, but I'd have thought with changing to LED bulbs a 3A should work fine. The LED's should use less than half the current of the orig bulbs. Heck the LED.s create nearly no heat
    TRDSport10 and DeusVult77[OP] like this.
  5. Nov 27, 2019 at 1:07 PM
    DeusVult77
    Nahamsha
    2015 Taco TRD OR
    Agreed. Which concerns me, but... it’s working now and nothing electrical is on fire. Which is a nice change, since I’m a Ford guy. ‍
  6. Nov 27, 2019 at 1:36 PM
    rphillips
    Rick
    Norene TN.
    2013 Reg. cab 4x4
    none
    A Ford Guy??? Oh God, I hate it for you......You should be real easy to convert. Oh yeah, Welcome
    TRDSport10 likes this.
  7. Nov 27, 2019 at 1:42 PM
    DeusVult77
    Nahamsha
    2015 Taco TRD OR
    As much as I love and can’t wait to mod my Taco, as soon as Yota builds something that can beat the ‘05 Excursion I have now or the ‘77, ‘86, and ‘95 Bronco’s I owned in the past (can’t fit four kids in one) I’ll be a full convert.
  8. Nov 27, 2019 at 3:47 PM
    rphillips
    Rick
    Norene TN.
    2013 Reg. cab 4x4
    none
    An 05 Excursion???..... isn't that what Blue Bird painted yellow & called a school bus, I know they are about the same size.
    DeusVult77[OP] likes this.
  9. Nov 27, 2019 at 3:52 PM
    TXinAK
    TXinAK Member
    Andrew
    Anchorage, AK
    2013 DCSB TX TRD
    Excursions rock. But so do Tacomas. Welcome to the cult forum!
    Thuguon2.7 likes this.
  10. Nov 27, 2019 at 6:34 PM
    Muddinfun
    High pinion Dana 60. :bowdown:
  11. Nov 27, 2019 at 9:19 PM
    DeusVult77
    Nahamsha
    2015 Taco TRD OR
    Yeah it’s still the reigning champ for total size. :) Glad to be here, can’t wait to start having fun with my new “toy”. Yeah, that Dana’s a beast. Two years ago I picked up a part time winter job plowing snow. I slid on snow covered black ice and got stuck. The wife pulled a Chevy 2500 dually flatbed w/ 10 foot plow and full sander out in 4hi going up a slight incline. I’ll be modding both trucks so I’ll post pics of them as I go.
  12. Nov 27, 2019 at 9:35 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Usually, yes, LEDs consume less energy but depending how high power those lights are they may actually draw a total of more amperage than the fuse is capable of handling over the stock bulbs.
    Rule of thumb for fuse ratings are to run double the regular amperage draw of the circuit. If the entire dome and map lights are drawing more than 2.5 amps on the 5 amp fuse then the fuse is at the threshold and will pop eventually or potentially immediately. If the circuit now draws over 3.75 amps while on with the 7.5 amp fuse you replaced it with then you would need to step up to a 10 amp. So on and so forth until the wiring becomes the bottleneck.
    I hope that explains things a little better.
  13. Nov 27, 2019 at 10:02 PM
    DeusVult77
    Nahamsha
    2015 Taco TRD OR
