HackD's ongoing 5-lug armored-slug build.
Discussion in '2nd Gen. Builds (2005-2015)' started by HackD, Mar 29, 2015.
  1. Oct 4, 2017 at 10:11 PM
    #201
    HackD
    HackD [OP] Marching to the Beat of a Different Drum
    William
    Hamilton, Ontario, Canada, eh?
    2010 Base 4x2, 2.7L, 5 speed manual 5-lug Slug
    Gone over the Top for a 5-lug..
    Good job on that .. I was looking at doing that also, with my Nexus 7 at one point. I decided instead to use a removable mount below the stereo instead, and can run Dash Commander and Torque through it.
    I've been into that dash more times than i care to admit. Each time that i do it, it scares the hell out of me in terms of potential for letting the smoke out of the wires. I still have to re-work under the hood, with a Blue Sea fuse block/electronics shelf for relays etc.
    I went through my lists this afternoon - that Joying 10.1" has been sitting on my computer room floor since February. I've been seriously slipping, in terms of getting things done. Since i took that photo in-truck, the void has been semi-filled and the Joying tested. I just have to go back in and install the steering wheel controller (aftermarket Joying specific.. not a Tacoma upgrade replacement), and i can button it up again for good (I hope).
    Then, i can focus on the roof. Sound insulation to install, and getting ready for fitting of the console and supports. I continue to be working on the console (lots of stuff i want to do with it, most of it useless!), concurrently.
  2. Oct 5, 2017 at 12:19 PM
    #202
    HackD
    William
    Ok, so this wasn't so difficult. 10.1" Joying Android head unit installed. Provided steering wheel remote does not work, not really worth messing with further.
    Dash cam, GPS, rear view camera all working fine. Sound quality and amplification very decent.
    Onwards and upwards to the roofline.
    ChadsPride likes this.
  3. Oct 5, 2017 at 3:38 PM
    #203
    Early B.
    Early B. Well-Known Member
    Brad
    metro Atlanta
    2014 2.7L, 5 lug Tacoma
    18" tires and rims, 2.75" Procomp lift, Fox shocks in rear.
    Man, that Joying Android head unit is extremely badass! That's gotta be a 2018 project for me.
    I can't be certain from the photos, but is the back of the unit flush with the dashboard?
    And is this a "it's easy to figure out" DIY project or do you recommend enlisting the services of a pro installer?
  4. Oct 5, 2017 at 4:01 PM
    #204
    HackD
    William
    I took photos for someone else who asked the same thing about flush-mount. It is not. I reused my Metra kit that held the Kenwood in place. As such, the Joying unit is drilled for bracketry that there is a wide range of positioning that you can achieve. The very front face of the box, upon which the screen clips in place, is also adjustable for angle (downwards from default position) by 8 degrees.
    The screen stands out, and off of the Joying double-din box, by about 1/2". I have the Joying box itself, protruding outside of the dashboard surface by another 1/3", give or take - keeping in mind that there does need to be stand-off spacing, because of the curvature of the dash.
    I've installed a few car stereos over the past 30 years - so, what might be simple to me, might be daunting to others. It wasn't any more difficult than installing a conventional car stereo, EXCEPT that the Joying Double-din dimensions are out of spec height and width wise, by less than 1/8" .. as i did not care to break out the dremel, i left the Metra trim frame entirely off.
    I bought the Toyota adapter harness from Joying, which made the job pretty much plug and play. It took me longer to pull the dash apart (again), than to actually plug the unit in, and do three splice/solders to existing wiring add-ons in the dashboard. The most fiddly bit, was getting the Metra brackets on the Joying double-din chassis "Just so".
    I don't have any additional components like a sub or anything else fancy to complicate matters.
    I'd rate it as dead easy (for me) .. just have to be methodical, and make sure that you get the dash apart with minimal fuss and wiring routed to where you want it to go, in terms of the accessories needing to be routed to the roof (dash-cam, microphone, GPS antennae).
  5. Oct 6, 2017 at 9:59 AM
    #205
    HackD
    William
    Related to above earlier post image, this is how this portion is turning out.
    Inside of console - in the radio tray, there is nothing really rigid to mount to, in terms of structural support - just a big hardened rubber tray. The above faceplate has been reshaped to fit inside of the radio tray extremely tightly. I'll tie it in with some small brackets to hard plastic.
    Sprayed the faceplate front with a good coating of black enamel, for good contrast.
    Larger view of the console with changed-out lighting switches, and the PA insert.
    Navelfunk and ChadsPride like this.
  6. Oct 6, 2017 at 11:04 PM
    #206
    bagleboy
    bagleboy Well-Known Member
    Scott
    Norcal, Santa Rosa
    2014 5-lug AC 2.7L VVTI
    Snug top Rebel, Thule tracks, ditch tracks, Bagged rear suspension, F/R anytime camera, intermittent wiper switch...
    Looking good!
  7. Oct 9, 2017 at 5:23 PM
    #207
    HackD
    William
    Some night-time shots of the centre-stack as it is now with the Joying 10.1". My 7" tablet is along for the ride, because it already has the Dash Command OBD2 App bought and paid for. The 7" tablet is easily addable/removable within seconds, including mount.
  8. Oct 12, 2017 at 3:35 PM
    #208
    Crooked Beat
    Crooked Beat Well-Known Member
    GTA
    2021 Tacoma DCLB SR
    I have to replace a bulb behind the HVAC controls.
    Any tips on a easy way to do this? Did you have any trouble taking that all out?
  9. Oct 12, 2017 at 3:44 PM
    #209
    HackD
    William
    The HVA control module is literally just pried out from the dash mount clips on the lower front face. Be careful of using a non-mar tool, to prevent marking up your lower dash. Careful in 'tugging' it out.. they are on a shortish wiring loom leash. Disconnect the wiring loom connections. There are two bulbs, surface mount (twist counter-clockwise to release with small screw driver in slot). These are surface mount 'grain' bulbs that you have to swing by the Toyota counter for - $13.86 CDN a pop.
    Edit: Just replaced a bulb last week - there is sometimes a cost to giving the upper console a "Fonzie slap" to un-stick a hazard button.
    Navelfunk, 5 Lug Fury and ChadsPride like this.
  10. Oct 12, 2017 at 5:42 PM
    #210
    Crooked Beat
    GTA
    2021 Tacoma DCLB SR
    Thank you!!
  11. Oct 12, 2017 at 5:54 PM
    #211
    bagleboy
    Scott
    Norcal, Santa Rosa
    Painter's 4-in-1 tool works great, it's thin on the leading edge but smooth and thicker back from the edge so it's still stiff. The panel is in a recess so you have to go straight in ~1/4" before you get behind it. Slip it in on the bottom and pry down while pulling down on the knobs and it pops out. Make sure the clips are on the panel and not the dash when you go to reinstall.
  12. Oct 14, 2017 at 1:24 PM
    #212
    HackD
    William
    Thought I'd grab a photo before I proceeded further. I stripped out the headliner in the past week, in prep of wiring routing and rubber mat sound proofing. I also have to install a wiring loom pass-through on the roof.
    There is also an exposed electronics box that I think communicates with the tire sensors.. I'm going to disconnect that and see what happens.
  13. Oct 18, 2017 at 12:26 PM
    #213
    HackD
    William
    Insulation is now pretty much done, and i've squeezed a fair bit of "Great Stuff" EPS foam into the hollow windshield support beams.
    I also installed a roof wiring pass-through bulkhead onto the roof, and ran additional power/grounding wiring through, for 'future needs'.
    The wiring bundle running down the driver's side A-Pillar is somewhat impressive - and i still need to run an additional harness down for the console wiring.
    Moving onto figuring out how to mount up the new Arb console... a compact switch pod arrived today, that i hope to be able to adapt in part or whole, into my Arb console changes/customization.
    20171018_145832[1].jpg 20171018_145842[1].jpg 20171018_145930[1].jpg 20171018_152143_001[1].jpg
  14. Oct 26, 2017 at 7:05 PM
    #214
    HackD
    William
    I don't need no stinking water-jet...
    This is the tedious phase of the one-off console project - putting bracketry in place, and fabricating faceplates, frames and support structures into place. I need to get all this stuff made first, before i actually take the dremel to the overhead console.
    All done with a Dremel, hand-filing, and lots of patience.
    20171026_213729_001.jpg 20171026_213625.jpg 20171026_211802.jpg 20171026_213523_001.jpg
  15. Oct 26, 2017 at 10:44 PM
    #215
    bagleboy
    Scott
    Norcal, Santa Rosa
    As a friend once said' "I don't know what you're doing, but it sure looks cool".
  16. Oct 30, 2017 at 4:57 PM
    #216
    HackD
    William
    Another small photo-dump of project progress photos on the console.
    Small 'cage' fabricated to hold the switch box in position, once support brackets are put into the overhead console drawer.
    As they are going to appear in the console drawer, once support brackets are put into the overhead console drawer. Aluminium frame cut and pop-riveted to the drawer exterior, and the extra plastic routed out.
  17. Oct 30, 2017 at 5:02 PM
    #217
    Navelfunk
    Navelfunk Well-Known Member
    Phyllis
    WA
    '03 DC SR5 V6 4x4
    Cap, incorrect rims & tires, stereo...
    I see you've been busy. Nice work!
    ChadsPride and HackD[OP] like this.
  18. Nov 1, 2017 at 12:23 PM
    #218
    HackD
    William
    First major bracket done. Tedious as all heck - and i had to undo some of my work when i pop riveted some of it together backwards.. :annoyed:
    20171101_151515[1].jpg 20171101_151624[1].jpg 20171101_151739[1].jpg 20171102_004152_001[1].jpg
  19. Nov 2, 2017 at 11:44 AM
    #219
    bagleboy
    Scott
    Norcal, Santa Rosa
    Wow, impressive DIY fabrication. That aluminum bezel would look real nice wrapped in vinyl.
  20. Nov 8, 2017 at 5:45 PM
    #220
    HackD
    William
    Not as fancy as that, LOL. The rest of the truck is flat black and grey, so i painted the home-made bezel flat black, after filling and sanding the rivets, it looks great as it turned out, IMO.
    This aspect of the console is physically done, and done with surprising little in the way of fitting complications.
    Navelfunk likes this.
