HackD's ongoing 5-lug armored-slug build.
Discussion in '2nd Gen. Builds (2005-2015)' started by HackD, Mar 29, 2015.
  1. Sep 13, 2019 at 4:25 PM
    #241
    5 Lug Fury
    5 Lug Fury Well-Known Member
    Kenny
    Knoxville, TN
    V8 Solid axle swapped 5 lug
    Got a lot of stuff lol
    You would need a complete 3rd member from an auto 5 lug or any 2nd gen 6 lug that's not an elocker. You them swap your gears and traction aid of your choice.
    HackD[OP] and erock12390[QUOTED] like this.
  2. Sep 22, 2019 at 5:27 PM
    #242
    HackD
    HackD [OP] Marching to the Beat of a Different Drum
    William
    Hamilton, Ontario, Canada, eh?
    2010 Base 4x2, 2.7L, 5 speed manual 5-lug Slug
    Gone over the Top for a 5-lug..
    If you want to do ANYTHING in terms of modding the final drive, the 3.31 is nothing more than an 80 lb boat anchor.
    The 3.58 is baseline upgradable, to i think 4.30.
    I didn't want 3.58, as my intended tire size was calling for 4.10.
    As i understand it, and as i proceeded - the 2nd gen Base or SR5 4x4 model, is the easiest to pick in terms of upgrade.
    Anything TRD is likely e-Locker, and thus not compatible.
    For the Prerunners, i poked around that a bit, and again, as long as it isn't TRD, it should be good. I was never able to confirm whether 1st or 2nd gen, but some were offered with a 3.73 or 3.90 gearing. 1st Gen T100's, may also be compatible.
    When i went through the process, i simply got the wrecking yard to remove the whole pumpkin, minus axles, minus driveshaft. It comes out as a self-contained unit, all necessary parts included to just plug and play, if you want open axle.
    I didn't, I wanted LSD due to weather conditions, my tendency to be aggressive on throttle. that made the one-wheel tire-fire experience a bit of an annoyance.
    I got the pumpkin shipped in on a small skid, and presented it and the Detroit Tru-trac box to the tech at 4wheelparts, and left it with them for a week. He ordered some replacement bearings for it - standard procedure when opening it up, regardless of mileage. Aside from that, it was a matter of disassembly and rebuild with the Tru-trac.
    Hope that helps to clarify further.
    erock12390[QUOTED] likes this.
  3. Sep 23, 2019 at 5:11 AM
    #243
    erock12390
    erock12390 Member
    Eric
    2005 basic base model, no options at all
    Thanks, that helps a lot
  4. Mar 14, 2023 at 6:44 AM
    #244
    Nomad426
    Nomad426 Well-Known Member
    Austin
    South West Houston Tx
    2019 Trd Off Road
    Ome Lift, Icon Leafs, Safari Snorkel, Bronze trd 4frunner wheels
