Had a 2020 Taco as a loaner, question for the group
Discussion in '3rd Gen. Tacomas (2016-2023)' started by CaptDubi, Aug 14, 2020.
  1. Aug 14, 2020 at 10:03 AM
    CaptDubi
    CaptDubi [OP] I do what the voices tell me.
    NH
    '23 SR5 Double Cab, grey
    Greetings all, I had the frame rust recall voodoo spray done on my '17 this week and they gave me a 2020 as a loaner. My question is this: It seemed significantly more peppy than my '17. I don't believe they made any changes to the motor/tranny for '20. A few people I've spoke to said this is another Taco thing, different trucks having their own personality powerband wise. Has anyone else experienced this?
    This is most certainly not a complaint, I am fine with the power my truck has, I just found the difference to be quite noticeable. My truck only has 35,000 miles on it so I doubt anything is getting tired.
  2. Aug 14, 2020 at 10:07 AM
    hyper15125
    hyper15125 Headlight Retrofitting Hobbyist Vendor
    NJ (609)
    I believe your truck computer learns your driving style. If you reset it and drive more spirited you should notice a difference.
    I remember reading the procedure somewhere.
    obviously That one is new and hasn’t adapted to anyone yet.
    CaptDubi[OP] likes this.
  3. Aug 14, 2020 at 10:10 AM
    rocky_mountain_dave
    rocky_mountain_dave Well-Known Member
    David
    2009 Tacoma Access Cab 4x4 4cyl 5spd
    ^^^ what hyper said. It's also possible they changed the throttle response tuning
  4. Aug 14, 2020 at 10:11 AM
    mrtonyd
    mrtonyd Well-Known Member
    Tony
    Colorado
    2019 TRD OR DCSB cement
    Maybe it was a difference in the suspension too? Stiffer suspension feels more peppy?
  5. Aug 14, 2020 at 10:15 AM
    Harmon
    Harmon Well-Known Member
    Jacksonville
    2020 Tacoma SR V6 4X4
    265/75/16 BFG KO2's Front ARB Air Locker
    Your '17 could just need a tuneup.
    Based on the miles crud buildup on plugs and stuff.
    /shrug
  6. Aug 14, 2020 at 10:19 AM
    Grossomotto
    Grossomotto Complete 3rd Member
    39.9526° N, 75.1652° W
    2017 4WDV6LB6MT
    It could be you're driving the loaner like the rental that it is.
  7. Aug 14, 2020 at 10:19 AM
    rustyfromskowhegan
    rustyfromskowhegan Well-Known Member
    2013 AC 4x4
    Damn they gave you a Tacoma as a loaner? I got a Camry...
  8. Aug 14, 2020 at 10:22 AM
    Grossomotto
    2017 4WDV6LB6MT
    If it's the 3.5L camry it's over 300hp, they're awesome. If it's the 2.5L not so much.
  9. Aug 14, 2020 at 10:22 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Have you had the ECU TSB applied? If not, ask them to hit it with TSB-0058-18 or TSB-0062-18. There's a small power bump there.
    If they won't help you, then you can do it yourself:
    https://www.tacomaworld.com/threads/ecu-tsb-update.562550/
  10. Aug 14, 2020 at 10:24 AM
    Clearwater Bill
    Billy
    Largo Florida
    2020 with Tundra v8
    Its Friday, right?
    tonered likes this.
  11. Aug 14, 2020 at 10:35 AM
    rustyfromskowhegan
    2013 AC 4x4
    I’m not sure what it was, but I’m pretty sure it was a 2.5L. I feel like I would have noticed it when I stepped on it if it had 300hp
  12. Aug 14, 2020 at 10:38 AM
    Grossomotto
    2017 4WDV6LB6MT
    It was probably a 2.5L you pretty much have to order the 3.5L in TRD and XSE.
  13. Aug 14, 2020 at 10:42 AM
    Xer0 SiN
    Xer0 SiN Well-Known Member
    Hilo, HI
    19 TRD SPORT TACOMA / 21 LIMITED RAV4
    this and that...
    i do believe every vehicle has a variance in hp/tq that its advertised at. meaning my truck stock for stock, and dynoed at the same time and same place might dyno differently than yours, or hers, or his. another thing could be because its a 2020 its probably up to date with all the tsb and revisions and what not. OR! maybe you said it yourself. its 35k. but we dont know if it was babied miles or rough miles. so many variables.
  14. Aug 15, 2020 at 7:31 AM
    CaptDubi
    NH
    I told them I couldn't be without a truck for a week and they didn't even argue. I think its their regular loaner, it was set up with normal plates and had about 2500K
  15. Aug 15, 2020 at 7:33 AM
    CaptDubi
    NH
    I asked if it was up to date at the first servicing and they claimed to have checked, but now I can be more specific!
    tonered[QUOTED] likes this.
  16. Aug 15, 2020 at 8:00 AM
    SSMTRDOR
    SSMTRDOR Well-Known Member
    2020 TRD OR 4X4
    In 2020 Toyota recalibrated the transmission logic.
    I traded my 2017 for a 2020. Definitely a noticeable difference.
    CaptDubi[OP] and MelyMel like this.
  17. Aug 15, 2020 at 8:02 AM
    Taco1701
    Taco1701 Well-Known Member
    William
    GA
    2020 DCSB TRD Sport 4x4 Cement
    If I recall correctly, I think there were some tweaks to the transmission programming and maybe throttle mapping, but nothing major. Same engine/transmission combo, but I'll admit my 2020 drives better than my 2017 did. Like others have said, if you get the latest ECU TSB, you'll probably notice a bit of a difference.
