Had an occasional hesitation from the tranny...
Discussion in '2nd Gen. Tacomas (2005-2015)' started by hogeyphenogey, Mar 25, 2013.
  1. Mar 25, 2013 at 3:59 PM
    hogeyphenogey
    hogeyphenogey [OP] Back in a Tacoma
    Dave
    Agawam, MA
    Lunar Rock 2023 TRD Sport 6spd
    So we called toyota and got the fluid to perform a transmission flush today. The trans fluid was black. 06 sport with 50100 miles. Now, when I accelerate, I get up to 6000 rpms and then BANG I drop into drive an slowly get moving and it stays in the high rpms. I was doing 3500 rpms at 35 mph and trying to keep a constant speed on a flat road. When I come to a stop, the rpms start at 750 and then they rise and it sounds like I'm in neutral then the truck lurches forward. This sucks.
  2. Mar 25, 2013 at 4:02 PM
    ST3VE
    ST3VE IG: @fishsohard
    MD --> SC
    Tint, car seat, baby wipes
    I don't know much about transmissions but you title of the thread brought me here. haha
  3. Mar 25, 2013 at 4:04 PM
    ajohnson
    ajohnson Glamour Shot
    Andy
    Charlotte, NC
    07 DCLB TRD Sport Prerunner 4x4
    Things and stuff and such
    Yea the title made me think of something totally different
  4. Mar 25, 2013 at 6:23 PM
    hogeyphenogey
    Dave
    Agawam, MA
    Sooo..... Any ideas before condemning the transmission?
  5. Mar 25, 2013 at 6:31 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Black fluid isn't good.
  6. Mar 25, 2013 at 6:51 PM
    Sje1124
    Sje1124 Well-Known Member
    Sean
    Louisiana
    2010 DBL Cab TRD OR 4x4
    Just a few
    Did they replace the fluid? Might want to check it.
  7. Mar 25, 2013 at 8:16 PM
    luka
    luka Well-Known Member
    Kailua, HI
    Prerunner -> 4WD Converted
    Pelfreybilt, Warn, BAMF, DTRL toggle on/off, FJ OEM Fog/Aux Light switches, 2012 lower center console swap, wired in auto-dimming rear view mirror, Wet-Okole inside, Weathertech , Rigid, Tint, Roto-Pax, Bestop, OME, Extended SS brake lines, TRD TX Pro/Baja Graphite 16" Rims
    black = burnt
    maybe some of the internals bonded via high heat making things stick?
  8. Mar 25, 2013 at 8:36 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    Did you do the work yourself, or did the dealer do it?
    If you did it, did you follow the procedure outlined here?
    http://www.tacomaworld.com/forum/2nd-gen-tacomas/63851-how-drain-refill-automatic-transmission.html
    If not, these transmissions are picky about fluid level. If you didn't get it right, it will run poorly, and what you describe it sounds like the level is very low.
    Also if they sold you T-IV and not WS, it will cause problems.
    Do NOT continue to drive it until this is resolved. The slamming into gear will destroy the transmission.
  9. Mar 25, 2013 at 10:30 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    " Now, when I accelerate, I get up to 6000 rpms and then BANG I drop into drive ".
    As stated by Rich it seems you have too low of fluid in the transmission. I would get it towed and have a professional look at it.
  10. Mar 26, 2013 at 7:11 AM
    dwsyab
    dwsyab Old Man
    David
    Sturbridge MA
    2012 TRD Offroad
    TRD Exhaust, rear diff breather mod, CB Radio
    My auto tranny has been acting a little sloppy when I come to a stop. A couple of seconds after I brake to a stop, there is a soft thunk and it feels like someone has bumped into my rear bumper. My truck only has 25 K miles on it, is this normal?
  11. Mar 26, 2013 at 7:21 AM
    UTMOST
    UTMOST Well-Known Member
    Josh
    Huntington Beach / San Diego
    11 ProRunner
    TRD exhaust, AFE stage 2 SI CAI, 2.5 RR Fox Coilovers, TC UCA's, 2.0 Piggyback Rear Fox Shox's, Icon AAL, TRD Fake beadlocks, 285/75/R16 BFG A/T, HID headlights/fogs, Foglight anytime mod, kenwood DDX 419, Scanguage II, Custom LED Interior, Debadged, Plastidipped front grill and rear bumper
    I have this same problem!! what is it! I have a 2011 TX pro auto
  12. Mar 26, 2013 at 7:40 AM
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    Sounds like not enough fluid. How did you measure ? You can add 8 oz and see if it helps.
  13. Mar 26, 2013 at 5:40 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    Common complaint, I feel it also. IMO it is the rear suspension and drive line settling after the braking.
  14. Mar 26, 2013 at 5:46 PM
    07 sport 4x4
    07 sport 4x4 Well-Known Member
    Blake
    Southeast
    2017 Duramax
    Grease the slip yolk.
  15. Mar 26, 2013 at 6:32 PM
    tacomarandy
    tacomarandy Well-Known Member
    Central FL
    '13 Prerunner SR5
    I have a 2013 that does that too! The first time it happened--I thought the car behind me tapped my rear bumper--
  16. Mar 26, 2013 at 6:35 PM
    Justus
    Justus fucks not given
    Nabisco the kid
    In ur toolbox
    stockish
    its axle wrap
  17. Mar 26, 2013 at 7:27 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    This.
    And if you have lift blocks, it'll be worse.
  18. Mar 27, 2013 at 12:11 PM
    dwsyab
    dwsyab Old Man
    David
    Sturbridge MA
    2012 TRD Offroad
  19. Mar 27, 2013 at 6:54 PM
    cheech1
    cheech1 Well-Known Member
    Kaneohe, HI
    08 PreRunner Off Road
    OP, your problem does sound like improper fluid level, but if the fluid was black, that indicates a lot of abuse, especially if you only have 50k on it. Could be your tranny is toast.
    For you thread jackers who mentioned the thunk after coming to a stop, yes it is axle wrap, or your A/C compressor cycling on & off.
  20. Mar 27, 2013 at 8:30 PM
    WilsonTheDog
    WilsonTheDog Kylie's dad
    Eric
    Myrtle Beach SC
    07 Prerunner SR5 DC/SB V6
    Magnaflow 12576 muffler & chrome tip, Westin step bars, 27% tint, Pop N Lock, AFE ProdryS, bed mat, Husky liners, D-rings added, Access Literider tonneau, Pioneer 4-ways all around, GY Wrangler Duratracs 265/75/16, 5100's @ 1.75", 1.5" AAL
    I concur, low trans fluid.
