had an oh crap moment today.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by skiergd011013, Feb 19, 2015.
  1. Feb 21, 2015 at 3:39 PM
    #81
    JBecker
    JBecker Well-Known Member
    Virginia
    2015 AC SR 4X4 2.7 Manual
    Is that like a high school auto tech class?
    Downshifting vehicles is a widely used practice. Even automatics do it.
  2. Feb 21, 2015 at 3:41 PM
    #82
    AeroCooper
    AeroCooper Half the strength of ten (microscopic men)
    NH
    2018 Barcelona Access Cab Off Road
    Remote start, tailgate inserts, nifty key fob case, Husky X-Act floor liners, AVS vent shades, bed mat, MX4 Tonneau cover, Tyger step rails
    Tech School
  3. Feb 21, 2015 at 3:42 PM
    #83
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
  4. Feb 21, 2015 at 3:49 PM
    #84
    AeroCooper
    NH
    In that case, it is ok to downshift. I also agree that rev matching will greatly reduce the wear on the clutch. Practice makes perfect. Then again, why not just use the brakes for their intended purpose? As I said, I'd much rather pay for brake pads than a clutch disc.
    I get it though, no one is going to change the way they've always driven based on a random internet post, so I'll let it go as agree to disagree. :)
  5. Feb 21, 2015 at 3:51 PM
    #85
    Green Jeans
    Green Jeans 6MT AC TRD OR 1GR-FE FTMFW
    Oregone
    '13 TRD Off-Road
    $10 you own an auto trans
  6. Feb 21, 2015 at 3:54 PM
    #86
    OZ-T
    Peter North
    British Columbia
    You're doing the same thing in both instances
  7. Feb 21, 2015 at 3:59 PM
    #87
    Clearwater Bill
    Billy
    Largo Florida
    If you do it wrong, I can agree. Re-read post 17 on how to do it right.
    What you want to do is take advantage of engine braking, at least in certain situations.
    In city driving it's not needed, unless you just want to practice. You can brake until RPM gets down to a level that you'd not accelerate in whatever gear you are in, put it in neutral, and finish your stop with the brakes.
    In racing it's brake only, before your turn, select gear to come out of turn with, rev match, engage clutch and hit throttle. Engine braking in racing is a time killer.
    In a panic stop, 'both feet in' is the order of the day.
    But on those long grades, where the sign says 'use lower gear', it's a brake overheat/fail precaution, using the engine as the main braking. And to get in that lower gear does not require clutch damage, again, see post 17.
    And no, it does not put 'undue strain on the engine' as you comment in in another post. Well, again, not if done properly. If you pick the wrong gear to downshift to, and over rev the engine, yep.
    And for those of you who might be going to jump me re ECU rev limiter protection, unless Toyota is different, it doesn't work on an unloaded motor downshift. The limiter is a fuel cut, and when you lifted out of the throttle, you already did that. Seen more than a few motors over revved by going from 5th to 2nd when they meant to hit 4th.
  8. Feb 21, 2015 at 3:59 PM
    #88
    JBecker
    Virginia
    Even the 5 speed autos downshift for you to control speeds on hills. Though they don't do it quite like an Allison transmission does.
    Whenever someone says downshifting a manual is bad I immediately know two things. They never have driven a performance car or motorcycle, and they've never driven a big truck with a heavy load.
    When you rev match on downshifts you are matching engine and transmission speeds, so the clutch and driveline can mesh smoothly. There are even manual transmission cars and motorcycles that rev match for you know.
    This is not a harmful practice when done correctly.
    tgear.shead likes this.
  9. Feb 21, 2015 at 4:23 PM
    #89
    stractman
    stractman Well-Known Member
    Colorado
    07 DCSB TRD sport, 4x4
    i like lurking around. have followed the main abs thread for a while. did the mod a long time ago because i experienced this on a regular basis. just like royden, i could duplicate the abs acting up.
    i have michelin ltx/ms2 shoes. on a completely dry road, i can drive over a crack (you can feel the tires dropping off the higher part of the road, over the crack, to the lower part) and the abs kicks in. it pulses and i continue to roll forward, able to steer, but unable to brake. completely impotent and flaccid braking. non-existent at that time, and dangerous.
    exactly this. after installing the mod, i've been fine and can stop easily. now i don't have to shit my pants while flying through the intersection without braking power. thanks, abs mod!
  10. Feb 21, 2015 at 9:04 PM
    #90
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    So that is why the clutch in my last truck only lasted 20 plus years. It may be longer as I sold it and it was still going strong and not slipping. I was down shifting and using the engine to brake.
    I'm sorry, but I have been driving since I was 14 years old, I'll be 60 next month. In all that time I have been using the engine and down shifting before ever touching the brakes. It doesn't hurt the clutch or engine at all. Anyone that says different just doesn't know what they are talking about.
    Now if you keep your big old foot on the clutch pedal while doing it is a whole other story and subject all together.
  11. Feb 22, 2015 at 8:27 AM
    #91
    kg5ie
    kg5ie Well-Known Member
    Bill
    Tx
    '14 PreRunner
    UltraGauge
    Meanwhile, back to the OP topic, I believe the ABS system has a little to be desired. At my age I've owned several different makes of cars with ABS. Toyota's design is one of the worst. J.M.H.O.
  12. Nov 21, 2015 at 8:07 PM
    #92
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    Back in the other ABS Thread I mentioned how hypersensitive ABS was in my old 08 with the Original Rugged Fail Tires and swapping them out made a huge difference. But after thinking about that for a few days I remembered a situation when I was approaching an intersection while the road was just slightly damp, clutch in and brakes on, as I got closer to the intersection my right front tire went into a slightly dropped down manhole cover, ABS kicked in and the truck just rolled forward a good 25 or 30 feet stopping just before going out into traffic. Anytime I ever went that way after that I always steered left or right to go around that manhole cover
  13. Nov 21, 2015 at 8:30 PM
    #93
    fjrmurph
    fjrmurph Well-Known Member
    you need to go back to class "just saying"
  14. Nov 21, 2015 at 8:36 PM
    #94
    4WD
    4WD cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    2004 DC TRD 4x
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    & ABS strikes again....I absolutely hate that shit & has no place in the automotive industry as far as I'm concerned & for sure around here it's caused more wrecks than it ever prevented (if it ever did) Offroad it's a nightmare as well, maybe even a bigger issue. Nothing sucks like hitting the brakes & actually gain speed..fuck that shit...
  15. Nov 21, 2015 at 9:04 PM
    #95
    hmsailor
    hmsailor Well-Known Member
    Florida
    2015 DCSB 4X4 TRD spORt
    my 02 has abs and still locks up.
  16. Nov 21, 2015 at 9:13 PM
    #96
    Doggman
    Doggman Well-Known Member
    Alabama
    2017 TRD OR MT
    So in a situation where you could have died due to possible malfunctioning brakes, why not get out and check if there was black ice? Could have confirmed or denied this entire debate (with respect to your specific incident) in a matter minutes.
  17. Nov 21, 2015 at 9:38 PM
    #97
    shakerhood
    Southern Ohio
    I have no idea about the other guys, but strictly in my case it happened in Late Spring, Early Summer so there was no Phantom Black Ice around.
  18. Nov 21, 2015 at 9:48 PM
    #98
    4WD
    4WD cRaZy oLdmAn
    Doug
    2004 DC TRD 4x
    Then you're lucky , it's malfunctioning ......;)
    We very rarely have black ice here but from what I've been told & have read most people don't know it until their in it...
  19. Nov 21, 2015 at 10:15 PM
    #99
    Ridgeline001
    Ridgeline001 Well-Known Member
    Oregon
    2014 DCLB Sport 4wd
    The ABS is total shit on this truck and the local master mechanic here agrees. Owned for 1.5 years now and had 9 situations since new. 7 at complete stock. All with no snow and 2 with wet pavement at stock. ABS has kicked in while cornering which takes away throttle control and wants to send you straight. Obviously a bad thing in corners.
    And before you question my driving ability, I have 0 accidents on road, have been driving for 29 years, CDL owner/ op for log trucks driving during foul weather in WA,OR, and CA. I've seen it and driven in it with a couple million miles experience. Computer control is bullshit. Even have the college degree on mechanical electronics that tells me if it is electronic, it is designed to fail. If you question that.....why does your tv, washer, toaster,microwave, etc not last even half the life that your mothers did?
    ETA: Not saying the truck is shit cuz I love it, but I've never had a computer try to control my driving before this. And that is what is bullshit.
    4WD likes this.
  20. Nov 21, 2015 at 10:31 PM
    #100
    4WD
    4WD cRaZy oLdmAn
    Doug
    2004 DC TRD 4x
    Exactly, also known as "planned obsolescence ".. & I'll add that when I decide (not a computer) to hit the binders ,I want to look in my rear view & see 4 skids, oddly , the only time my brakes are working as they should is when the ABS light is on.
