had keys cut...dont work!?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by lwszabo, Apr 22, 2011.
  1. Apr 22, 2011 at 11:12 AM
    lwszabo
    lwszabo [OP] Well-Known Member
    Concord NC
    2009 BSP regular cab
    none yet...regular cab 4cyl X-Runner tribute in the future!
    My 2006 Tacoma only came with 1 key so I wanted to have a couple cut just to open the doors in case i lock the main key inside. I understand the key has a chip in it so I couldnt start the vehicle...I had 2 keys cut at lowes but they wont unlock the truck....do i need a chipped key to unlock the doors? the key goes in the lock it just wont turn!
  2. Apr 22, 2011 at 11:13 AM
    wiscdave
    wiscdave Lets Do It!
    Northern Wisconsin
    Tundra Rock Warrior
    Past ride - 3" OME 885s&Shocks/ TSB 1.5AAL/ AX184 Rims 285 Firestone destination ATs/ 2 Shallow mount P310s in Supercrew Box - Punch 601s, Beefed up Hunter Brush guard, Tint, Fog light mod, AFE Drop in, AC and Fog light mods, scangauge
    Bad cut?
  3. Apr 22, 2011 at 11:15 AM
    lwszabo
    Concord NC
    I wouldnt think 2 would be bad cuts...
  4. Apr 22, 2011 at 11:17 AM
    wmdpowell
    wmdpowell Well-Known Member
    Bill
    Selkirk, NY
    4x4 reg cab, 5 speed
    Better tires Hurcules Terra Track, trimmed front mud flaps, (access limited tonneau-took off) softopper, ats running boards, Piaa fogs, window vents, Wireless thermometer, extra bed rings, valley hitch
    there is a Key Code.
    If you do not have maybe the orginal dealer knows it. They can set the key just right for you.
  5. Apr 22, 2011 at 11:24 AM
    lwszabo
    Concord NC
    used truck that only came with 1 key and key fob...other was lost by po. its the key i use everyday to drive the truck
  6. Apr 22, 2011 at 11:28 AM
    BERTHDZ
    BERTHDZ KF5TUQ
    Bert
    Pharr, TX - RGV
    02 v6 SR5 TRD Off Road
    3" Body Lift, Fabtech 6" Lift, XD Series 17x9" Revolver Rims, 35x12.50r17 Nitto Trail Grapplers
    I had to do this once. I went to the dealer and they where able to do it with just the VIN number it was only $20 or less but I have a first gen with out chip. I remember them saying if I had a chip it be about $80
  7. Apr 22, 2011 at 12:15 PM
    lwszabo
    Concord NC
    yea i dont need one to drive the vehicle just to unlock the door. I have one to drive the truck, i just want an emergency key in case i lock the one i have inside the truck!
  8. Apr 22, 2011 at 12:23 PM
    toyotatacomaTRD
    toyotatacomaTRD Senior Member
    Pacific Northwest
    2018 OR DCSB 4x4
    You can try filing it down a little. In the past when I have had keys made for my house, they have mentioned filing if the key doesn't work.
    It is also possible the person who made it may have done it incorrectly...
  9. Apr 22, 2011 at 12:25 PM
    lwszabo
    Concord NC
    ok i will try another store and see what happens...only out 6 dollars so far!
  10. Apr 22, 2011 at 12:28 PM
    toyotatacomaTRD
    Pacific Northwest
    2018 OR DCSB 4x4
    Take it back to Lowes. I wouldn't try somewhere else until you give them another chance to correct it.
  11. Apr 22, 2011 at 12:30 PM
    iroc409
    iroc409 Well-Known Member
    Washington
    A red one
    Try a dealer. They have better key machines. I have mine done at an Ace store, and it was really tight and didn't work well. I keep a plain key in my wallet in case I lock myself out (no chip).
    Toyota cut me a key, and it works perfectly.
    I tried to get a Mazda dealer to cut me a basic key, but they told me they only do the big chip keys. Derp.
  12. Apr 22, 2011 at 12:42 PM
    Aod
    Aod Ex STi enthusiast www.iwsti.com
    B.
    NorCal/Bay Area
    11 TRD Sport 4x4 DCSB
    Our local ACE hardware actually has the machines and software to cut and program chipped keys for MUCH cheaper than a dealer. May want to give yours a call and see if they do it. They even have a military discount if it applies.
  13. Apr 22, 2011 at 2:11 PM
    maxamillion2345
    maxamillion2345 Leaves the bay but brings all its problems
    Max
    Nevada
    80 series LC
    Tons and 40s
    When I worked at Ace I made myself a (non-chipped) key for this purpose. Worked fine.
  14. Apr 22, 2011 at 2:18 PM
    LGE RAW
    LGE RAW Well-Known Member
    Rob
    Dothan
    PreRunner SR5 TRD Sport
    Bull bar, wet suit seat covers, Accessory meter repair, Fog Lights with stick on, console lock.
    I would let Lowes try it again. You can get your money back for the ones that don't work. The dealer can cut one based on the code or the VIN. Just tell them you don't want a chipped key and you shouldn't have to pay the higher price. I had Walmart cut and code one for my wife's Sequoia, hand no probles with it at all. It was $80 due to the chip. Again, you may can get an un-chipped on there, too.
  15. Apr 22, 2011 at 2:23 PM
    03coma
    03coma Well-Known Member
    New Jersey
    2015 DCSB TRD, SR5
    TRD Pro Grille, Skid Plate, TRD Cat-Back Exhaust System, 2017 Tacoma Rims, ARE Series II Lid,
    Could be bad cut or wrong key # used
  16. Apr 22, 2011 at 2:26 PM
    OffroadToy
    OffroadToy This ain't Dodge City, and you ain't Bill Hickok
    4X4 Offroad
    snugtop, piaa, weathertech, westin, oem bed mat, trd seat covers, avs inchannel vent visors, 2" suspension lift, front diff drop, rear differential breather extension, oil filter drain hose, a/c drain hose extention & reroute, front window tint, cat theft protection plate, tailgate clamp mod, xpel headlight/foglight protecters, oem block heater, bfg 265/75R/16 a/t k/o's, cabin air rodent protection screen, rcbs illuminated 4X4 switch mod
    Ask your dealer about having them cut a credit card key for you. My dealership sent me the card after puchasing the truck back in 07 and I had to take it in to have them cut the key. It's made of plastic about the same size as a credit card with a fold-out key that fits the door for emergecies. I keep it in my wallet.
  17. Apr 22, 2011 at 2:27 PM
    crf69
    crf69 scraping my emblems off my plasti-dip
    Ohio
    06 TRD OR BSP cab'n 1/2
    ummm yeah
    ace took three times to get mine right.....
  18. Apr 22, 2011 at 3:17 PM
    maxamillion2345
    Max
    Nevada
    80 series LC
    Tons and 40s
    Jesus, it really isn't that hard if you have the right key blank. We always had people go out and test them in the parking lot before they went home.
  19. Apr 22, 2011 at 3:34 PM
    Bloodhound
    Bloodhound Space For Rent
    Greg
    East Moline, IL
    '10 TRD O/R DBL-CAB
    Floor-mats, Running Boards, Shorty Antenna, AFE Pro Dry Air Filter, AVS In-Channel VentVisors, Beer cans in the bed
    They probably used one of those machines that you insert the original key into and then put the blank into another one to cut the key. Possibly the blanks they had did not have the correct back-spacing.
    For what it's worth, go to an actual locksmith. They can generally cut keys that work.
    Another option is to try smoking the keys you've had made. You take the keys and "blacken" them with a match, then insert into the cylinder and turn them side to side to get an impressioning. File away where the black residue is removed and you "might" be able to make the key work. Old locksmithing trick.
  20. Apr 22, 2011 at 5:34 PM
    travelingman
    travelingman What would Scooby do?
    Brian
    Ohio
    07lb4x4DC
    ticking eng.mo,ventvisors,locking tailgate,wheelmasters ss spare tire inflation line,weathertech mats
    Ace made me an unchipped one that worked perfect-the first time.
