Had my e brake cables replaced and now my brake light is on
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Dakota Red, Jun 30, 2015.
  1. Jun 30, 2015 at 10:11 AM
    Dakota Red
    Dakota Red [OP] Well-Known Member
    Topped off the brake fluid amy ideas?
  2. Jul 1, 2015 at 2:18 AM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    There is a switch on the parking brake actuator that turns on the light when the brake is set. Make sure that the brake is fully released. They could have the cable adjusted too tight which would prevent the actuator from going to the fully released position.
    I think since the cables were just replaced that they are adjusted too tight.
  3. Jul 1, 2015 at 3:08 AM
    Kemosabe
    Kemosabe Little bitty life
    Louis
    Western Quebec, Canada
    2010, 2.7l, 4x4, M/T
    URD STS, Spidertrax spacers, AFE Pro dry
    There is adjustment under the center console if your e brake is an handle on the right side of the steering wheel. Don't know about the pedal for the automatic.
  4. Jul 1, 2015 at 8:07 AM
    Dakota Red
    Where is that switch?
  5. Jul 1, 2015 at 4:29 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    Get down there and dig around. Do you have a manual transmission ( Pull Park Brake ) or automatic ( Foot Pedal Park Brake )?
    Automatic is on top of the pedal assembly at the rotation point.
    I'm not sure on a manual exactly where the switch is. Look you should be able to locate it.
    Did you check to see if the cables are too tight? I'd bet they are.
