Had my first part failure today
Discussion in '2nd Gen. Tacomas (2005-2015)' started by macgyver, Jun 8, 2012.
  1. Jun 8, 2012 at 5:56 AM
    macgyver
    macgyver [OP] Well-Known Member
    Brad
    Canton, GA
    '13 Tundra double cab SR5 4x4
    Besides a battery and Brake pads, My taco had its first part failure today at 111k miles :(. The middle U-joint on the rear driveshaft is toast. Even greasing every 30k miles with Mobil1 synthetic grease.
    Yesterday on the way home from work, I noticed a clicking sound from my driveline at slow speeds and by the time I was close to home I noticed a lot of driveline vibration and humming in 1st gear. I suspected it was a U-joint going bad so I rolled around under the truck on the creeper inspecting the u-joints and checking the cv joints in case. All the CV's looked good but I noticed a bit of slop in the middle u-joint on the rear driveshaft, I could see exposed shiny metal which isnt normal.
    Then on the way to work this morning it was clicking really bad at almost any speed and I was getting a lot of driveline vibration at any speed. Even though I can change it myself, I decided to drop it off at my next door neighbor's repair shop since I have a super busy weekend and won't have time to fix it. It needs to be fixed asap before the u-joint breaks and I'm stranded. Fortunately I made it to his shop this morning.
    He's gonna replace it with a Moog heavy duty greasable u-joint and I'll pick it up this afternoon.
  2. Jun 8, 2012 at 6:02 AM
    brutalguyracing
    brutalguyracing BIG DADDY
    F.U> GUYZ
    broken mods
    woot
    for not exploding on parkway
  3. Jun 8, 2012 at 6:07 AM
    macgyver
    Brad
    Canton, GA
    Why do we park on a driveway and drive on a parkway? :p
  4. Jun 8, 2012 at 6:09 AM
    brutalguyracing
    F.U> GUYZ
    broken mods
    my parkways here are just that we park on them and roll at slow speed:D
  5. Jun 8, 2012 at 6:20 AM
    shweller
    shweller Well-Known Member
    Corona
    2010 Tacoma TRD Sport SB 4x4
    PoP 'N' Lock Satoshi Grill (Did it Myself) DSM UCA's (Desert Products) FXR 1.1 w/Gatling Gun Shrouds Phillips 85122 Method Racing Wheels HID Hella 500's behind Satoshi grill Fog Light Anytime Illuminated 4x4 Switch Ultragauge PIAA 510"s King Coilovers w/resi's Rear TSB Leaf Packs All Pro Sliders Bolt on sliders 255/75 R17 BF Goodrich Mudders Spidertrax wheel spacers Neoprene arm rests Weathertechs Wet Okoles w/TRD Allpro Ofrroad Apex bumper and IFS skid plate
  6. Jun 8, 2012 at 6:24 AM
    macgyver
    Brad
    Canton, GA
    Here's a completely unrelated pic :D... Happy now?!
  7. Jun 8, 2012 at 6:34 AM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    2011 taco, sport 4x4
    oil change...
    I had to have a u joint replaced on my 07 taco at 34k miles. It started squeeking really bad and would increase as my speed increased. luckily I was still under warrenty at the time.
  8. Jun 8, 2012 at 7:39 AM
    2004TacomaSR5
    2004TacomaSR5 Nemesis Prime
    Jon
    Montana
    2004 Tacoma DCSB & 1980 Toyota Pickup 4WD
    Tacoma is stock and staying that way, Pickup is TBA as of now.
    Normal wear and tear it sounds like, thats quite a lot of miles for a u-joint.
  9. Jun 8, 2012 at 8:04 AM
    PSJ
    PSJ Prerunners Work
    Sebastian Inlet
    09 Access Cab Prerunner
    Rear Leaf spring TSB, Bilstein 5100's all around w/ front set at 1.75", 265/75R/16 Mickey Thompson Baja STZ's, Trailer hitch w/custom wiring, AFE drop in dry filter, Rear Diff breather mod, Debadged truck, customized stock TRD wheel center caps, added factory fog lights, bed mat, door sills, tinted windows
    If your doing lots of what is pictured with your truck I am sure you can chalk this up to normal wear and tear...:cool:
  10. Jun 8, 2012 at 10:06 AM
    Maticuno
    Maticuno Resident Pine Swine
    California High Deserts
    03 F250 CCSB
    Gibson stainless headers, custom free-flow Y-pipe, Magnaflow muffler, 285/75R16 KBro2's, Pioner AVH-2300NEX w/backup camera, SCT X4 Tuner.
    Maybe it's because I wasn't there, but it sure looks like if you would have just stayed to the far right, you wouldn't have needed to straddle that gully.
  11. Jun 8, 2012 at 10:19 AM
    mynewtoy
    mynewtoy assassinating the president of the Jberry fanclub
    greg
    Mississippi
    09 double cab 4x4
    Detriot locker rear ARB air locker front 4.56 gears OME 3" lift, SPC uca's , moto metal 951 wheels 315/75/r16 Treadwright guard dogs, homemade front plate bumper with smittybilt 9.5k winch, homemade skids, homemade Bed bars, Mobtown offroad high clearance rear bumper with tire carrier, Homemade rock sliders , U-bolt flip, Wheeler's super bumps, BORA 1" wheel spacers , Black headlight mod , black tail lights, Satoshi Grill , autoPage C3 RS-665 alarm with remote start, flowmaster 40 series exhaust, cruise control,bed/ground effect lights, wet okole seat covers, tinted,windows, weather tech floor mats, AVS vent shades, debadged, hidden cobra 19 cb, 7" offroad lights behind grill, rear diff breather relocate, abs kill switch
    what? you are macgyver you should have fixed that u-joint with a piece of bubble gum and a toothpick in 30secs.:D
  12. Jun 8, 2012 at 11:06 AM
    macgyver
    Brad
    Canton, GA
    Nah there wasn't enough room. There is a tree line right at the left side edge of the picture.
    Just picked up the truck from the shop. It's all better now. $51 for the repair.
    I would have fixed it myself because I do all my own work (I'm macgyver after all ;) ) but I don't have time this weekend to fix it. It needed to be fixed ASAP.
    He said when he took the old joint out, it was cracked. It was vibrating really bad on the way to the shop regardless of speed and continuously clicking and popping.
  13. Jun 8, 2012 at 11:47 AM
    shweller
    Corona
    Thanks for the heads up OP. I developed a little vibration after the last off road trip and am going to look into this.
