Had my transmission replaced and know its leaking fluid
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Dakota Red, Nov 2, 2015.
  1. Nov 2, 2015 at 7:52 AM
    Dakota Red
    Dakota Red [OP] Well-Known Member
    Wanted to get some opinoins on this. I had the transmission replaced about 2,000 miles ago and i noticed a spot of fluid (red) on the garage floor about the size of a basketball. The shop said they are not sure if its the transmission or the transfer case thats leaking. They said its a big job to remove it to find out whats leaking. They will cover it if its the transmission but if its the transfer case i am resposible. Is the transfer case fluid red? I thougt it was more like motor oil color.
  2. Nov 2, 2015 at 8:34 AM
    Dakota Red
    Thats what i thought.
  3. Nov 2, 2015 at 8:41 AM
    127.0.0.1 AKA ::1
    /etc/hosts
    2013 NBM AC 4.0 4x4 Auto OR
    transfer case oil could be red as some brands of gear oil is red
    Take off fill bolt on t-case
    and stick a Q-tip in and fetch
    some oil, see what color it is. probably honey but double-check
    if it is not red, go get yer tranny fixed again
  4. Nov 2, 2015 at 9:36 AM
    Dakota Red
    Thats a great idea. Its at the shop now so I wont be able to do that.
