Had one pleasant surprise from yesterday's state inspection
Discussion in '2nd Gen. Tacomas (2005-2015)' started by EdgemanVA, May 29, 2025.
  1. May 29, 2025 at 6:45 AM
    EdgemanVA
    EdgemanVA [OP] Well-Known Member
    Virginia Beach
    2008 X-Runner
    Several
    I have free state inspections for life from the dealer I purchased the truck from, so I still take advantage of that benefit. (I'm probably one of the 10% that keeps vehicles this long...lol) Like always, they give me a long list ($2774) of things that "need to be addressed," and one was repairing a flashing TPMS sensor ($185.99). I turned it down because I'll probably install new tires before my next state inspection and Costco replaces the TPMS sensor batteries when they install new tires. I had quite the shock driving to the gym this morning when my TPMS sensor light turned off normally after I started the car. No flashing, no staying on the rest of the trip. It was back to normal...and I saved $185.99...lol.
    Two of the items they hit me on (Transmission service $425.99 and Brake Fluid Exchange $229.99) I completed last week. Fresh transmission fluid and fresh brake fluid...guess they don't actually check it...lol.
    I do have two things to address: supposedly a leaking steering rack and boots torn on the front sway bar links. I'll inspect both latter today and replace the sway bar links when the parts arrive. (They want $307.39 for that easy job...lol) They also want $1351.80 to replace the steering rack, plus another $169.99 for an alignment. Pretty sure that's a job I can do myself and save a chunk of change, but I'll still have to pay for an alignment... If I need to replace the rack, I'll do it before installing new tires.
  2. May 29, 2025 at 6:48 AM
    six5crèéd
    six5crèéd Be the light
    Southern Virginia
    8 lugs no plugs
    I also live in Va. and when I got my car inspected (new to me daily at the time) the check engine light came on on my way to get it inspected. I ask them about it when I pulled in, they said it doesn't matter in Va. I love living here.
    hinmo24t likes this.
  3. May 29, 2025 at 6:56 AM
    2015WhiteOR
    2015WhiteOR Well-Known Member
    Gainesville TX
    "Costco replaces the TPMS sensor batteries when they install new tires"
    What?
  4. May 29, 2025 at 6:57 AM
    dk_crew
    dk_crew Well-Known Member
    Dave
    Austin, TX
    2005 Tacoma 4x4
    on the steering rack I'd just keep an eye on the PS reservoir -- I replaced my rack several years back and the new rack started leaking 2ish years after that. I top it off from time to time ... I keep Lucas oil PS stop leak in the truck and it's worked for me. I am OK using that in the steering rack b/c it's self contained so that leak is only affecting the rack itself.
  5. May 29, 2025 at 7:12 AM
    EdgemanVA
    Virginia Beach
    2008 X-Runner
    Several
    I know why the TPMS sensor is not a fail. It's because not having them isn't a fail for older vehicles.
  6. May 29, 2025 at 7:13 AM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    I call this false as Most ( I've never seen one that had a removable battery) TPMS Sensors are sealed and the batteries are not removable without cutting the housing open.
  7. May 29, 2025 at 7:34 AM
    EdgemanVA
    Virginia Beach
    2008 X-Runner
    Several
    In that case, they replace the sensors.
    My truck is 17 years old, and I've only had one TPMS sensor die. Either those are phenomenal batteries or Costco is replacing the sensors.
    Jimmyh[QUOTED] likes this.
  8. May 29, 2025 at 8:44 AM
    Tacologist
    Tacologist Well-Known Member
    Bob
    Tenessee
    05 Double Cab Shortbed
    Rear leaf suspension. Home done tailgate re-inforcement.
    Or "telling" you they are replacing them. o_O
    TegoTaco likes this.
  9. May 29, 2025 at 9:26 AM
    Rock Lobster
    Rock Lobster Thread Derailer
    Dee Eff Dub
    I drive a Miata.
    Last time my car was at the dealer, it was for a recall. It just needed a simple firmware update on one of the airbag modules or something. They held it for two hours, making sure to come out every fifteen minutes with a different thing that needs absolute urgent attention. "Your wipers look really worn...," they'd say. No they don't.
    "You are due for a tune-up..." No I'm not. Its a 2016 with ECU-controlled timing. The only tune-up it needs is downloadable from my laptop.
    "You really should get your injectors flushed..." LOL. No thanks.
    "You should change the plugs and transmission fluid..." I did those things a month ago. They aren't due yet.
    "...-oil? brakes?" No and no. I also do those myself.
    "Can we at least give it a complementary wash? We thought we'd ask since you Miata people are soooo particular." Thank you for asking. No.
  10. May 29, 2025 at 4:08 PM
    bananaboat
    bananaboat Well-Known Member
    Just check your receipt - they aren't going to do it for free.
    JohnDoeFasho likes this.
  11. May 29, 2025 at 4:13 PM
    winkel
    winkel Well-Known Member
    Corydon, IN
    2014 Spruce Mica, TRD Off-Road, 6 Spd Manual
    Sliders, Tailgate Liner
    Yeah, I kept my old TPMS sensors when I had them replaced a couple of years ago (Densos from RockAuto) and took one apart. The batteries in mine were potted in epoxy. Replacing them would cost more than to just replace them.
    On the steering rack, I pull the bottom hose on my PS reservoir a couple of times a year and drain the fluid. Refill with fresh Dexron and roll. Do this a couple of times a year and it keeps the fluid pretty fresh. My truck is a 2014 and the fluid looks and smells new.
    O'DubhGhaill and jackn7 like this.
  12. May 29, 2025 at 5:53 PM
    JohnDoeFasho
    JohnDoeFasho St Petersburg, FL
    St Petersburg
    2009 TRD Sport Crew Cab Long Bed
    OTT Tune
    It’s like $40/new sensor at Costco. Great deal relative to most places but surely not free.
    You don’t replace TPMS sensor batteries. You replace the whole sensor… I feel like some of you are from the pre-Google era.
    O'DubhGhaill and RockinU like this.
  13. May 29, 2025 at 6:06 PM
    azzwethinkweiz
    azzwethinkweiz Well-Known Member
    Tucson, AZ
    2013 4x4 DCSB V6 6-Spd, TRD OR, Tow Package
    Damn $40 bucks per sensor is a great price. Discount Tire by me charges $62 per sensor. They do warranty them for 5 years which is good since they tend to fail again within that time period. I am guessing they use the cheapest possible for the most profit.
  14. May 29, 2025 at 6:36 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Blows my mind how many shops will give their time away for free, and how many customers will happily go there and then have zero faith in the answers they're getting
    The inspection might be free but you can't trust it so what's the value?
    O'DubhGhaill and Jimmyh like this.
  15. May 30, 2025 at 7:26 AM
    Rougarou680
    Rougarou680 Swamp Lurker
    Lousyana
    2006 Tacoma 4.0 Prerunner, 2013 & 2014 Tacoma 4WD 4.0L
    Leveling kit, hydro dipped rims & skid plate on 2013, 6” pro comp lift & color matched rims on 2006.
    I also get free lifetime inspection from dealer I bought truck from, along with lifetime free oil changes. When I needed TPMS sensors, I bought Denso online & had dealer sync them. They charged $75 total. I had already paid a tire shop to install them.
  16. May 30, 2025 at 7:57 AM
    fatfurious2
    David
    Ashburn, VA
    2010 TRD OR Access Cab
    Check engine light is definitely a fail in VA.
    But TPMS sensor light on is not - mine has been on for 8+ years since I deleted my sensors. The bulb will just not burn out
  17. May 30, 2025 at 8:04 AM
    IndianTrash
    IndianTrash Member
    2004 Prerunner 2.7L
    Lol just the other day I had my dads van at the Toyota dealer for an alignment. Service advisor came out a couple hours later to come and get me. She said the inspection went well but there were a few things to address. First, the valve covers were leaking, not a problem I already knew this since it's inevitable at 420,000 miles. What was weird was that she claimed both valve covers were leaking and leaking oil into the spark plug tubes. I know for a fact they didn't pull the plugs. Next thing she claimed was the front pads were at 30%, I changed them two years ago with OEM pads so I know they did not wear 70% after 20,000 miles. But the thing that confused me the most was that my rear brake material was apparently also low. I have drums... I have a buddy at this dealer who is a master tech, otherwise I would not give them my business, they've always had a bad reputation around here.
