had paintless dent repair done today
Discussion in '2nd Gen. Tacomas (2005-2015)' started by skiergd011013, Mar 2, 2015.
  1. Mar 2, 2015 at 7:18 PM
    skiergd011013
    skiergd011013 [OP] Well-Known Member
    2010 TRD Offroad 4x4 AC SSM
    I had a small dime sized dent on my passenger side access cab door. I also had a larger dent above my passenger side rear wheel. I had a local used car business who also does pdr fix it. you cannot even tell anything was there. hopefully this doesnt happen again but its nice knowing this guy is in town incase it does. I highly recommend this for annoying dents.
    SH10151 and AR15xAR10 like this.
  2. Mar 2, 2015 at 8:38 PM
    Vantage
    Vantage Well-Known Member
    Luke
    Vancouver BC
    2015 Titan Pro 4x
    I ran my fender into a tree and used paint less dent to fix it. It looks 99% like stock and was $2400 cheaper than a body shop quoted me.
    I couldn't believe how well it turned out either
    SH10151 and steelcity2 like this.
  3. Mar 3, 2015 at 1:27 AM
    RKCRUZA
    RKCRUZA Well-Known Member
    Bob
    Placerville, Ca
    2015 TRD Pro in the Garage!
    Had some work done here in Ca by the dentless folks....$100 instead of $1200 and got about 99% of it....if you don't know where to look you will never see it....great way to fix things if the local guy is good and the paint is still intact....
    SH10151 likes this.
  4. Mar 3, 2015 at 10:56 AM
    docbrown
    docbrown Well-Known Member
    Tampa, FL
    05 Tacoma SR5 4X4
    Doug Thorley Long Tube Headers, Eclipse 6620 AVN GPS/DVD, K&N Drop-in Air Filter, Hose clamp mod, Redline Quick Lift Elites, Bilstein 5100's at .85, Firestone Ride Rite Air Bags, Weather Techs front and back, Bug Guard, and Factory Bull Bar, Wet Okole's up front, Bed Mat, LED interior lights, Fumoto Oil Valve
    Buddy of mine does PDR and took out a dent on my roof a year ago. You could not tell it was even there when he was done.
  5. Mar 3, 2015 at 1:45 PM
    hotrod53
    hotrod53 Well-Known Member
    Lynd
    Pittsburgh, PA
    ‘14 DCLB Sport, ‘18 TCH, ‘13 TCH
    Weathertech floor liners moded to hold OEM floor mats, weathertech vent visors, Toyota bed mat, LEER 100XL cap, hood gasket mod to stop whistling.
    Had it done 3 times on 3 vehicles, these guys are amazing.
  6. Mar 3, 2015 at 3:13 PM
    Canufixit
    Canufixit Well-Known Member
    People ask me "CANUFIXIT"!
    New England
    2020 Red SR 4x4 Taco
    "Access" Tonneau cover. Bed Mat. Hitch, Timbren SES
    :worthless:
    I'd love to see some pics ???
  7. Mar 3, 2015 at 3:17 PM
    1eyedclyde
    1eyedclyde Well-Known Member
    CJ
    New Castle,CO
    15 DCLB Limited, 01 AC V6
    I have heard of pdr rusting from the inside out. Has anyone actually seen this happen?
  8. Mar 3, 2015 at 3:24 PM
    Fonzi25
    Fonzi25 Well-Known Member
    Jaime
    Sparks, NV
    2011 Tacoma TRD
    I'm going to do this soon have good size dent from someone hitting me on the bottom part of my rear passenger door but no crease on it so should be able to get it out with a PDR just need to find someone near me or I'll wait till i go home again and do it there
  9. Jun 6, 2015 at 9:35 AM
    Dropitmore
    Dropitmore Panda Man
    Andy
    Downey, CA
    2013 TRD McDouble Cab
    Mall Crawler Edition
    I accidentally put some weight down on my roof just now trying to strap things down to my roof rack. My palm left a small nickel size dent. Need to hit these guys up! Good info.
  10. Jun 6, 2015 at 10:18 AM
    Pigpen
    Dan
    Northwest Montana
    In need of PDR... [​IMG] Both sides look like that from my Yakima rack. My fault, not the rack.
  11. Jun 7, 2015 at 2:58 PM
    Monkeybutt2000
    Monkeybutt2000 Well-Known Member
    Wow,I'm a PDR tech and dents that size are rough. They can be fixed though.
  12. Jun 11, 2015 at 9:42 AM
    Dropitmore
    Andy
    Downey, CA
    $100. These guys are magicians. Instead of dropping the headliner which would've cost me more. He went thru the 3rd brake light?!!
    Not the best pictures but I am very happy with the results.
  13. Jun 11, 2015 at 10:20 AM
    TacomaMike37
    TacomaMike37 Well-Known Member
    13' DCLB MGM
  14. Jun 11, 2015 at 10:33 AM
    08WhiteTRD
    08WhiteTRD Well-Known Member
    Ben
    Rocklin, NorCal
    2008 White 4x4 TRD Sport
    Fox Suspension 2.5 Front and 2.0 Rear, All-Pro Skids, BAMF LCA Skid, Leer 100R, Scangauge II, WeatherTech Floorliners, WeatherTech window visors, Satoshi grill with HomerTaco mesh, Sockmonkey Tailgate Decal, BHLM, Center Console lock, ImMrYo Rear-view bracket, Rally Armor mud flaps, Crawford Eco-Block, USA-Spec PA-15
    I had a dent on my roof and just used my GoPro suction cup attachment to pull the dent up. Went right back to normal with very little effort.
    ridefreak likes this.
  15. Jun 25, 2015 at 10:05 PM
    NM Lance
    NM Lance Well-Known Member
    My 2014 was hit by hail before my first oil change... it is absolutely destroyed now, but at least the glass didn't break. Do you think paintless dent removal would fix it? It looks like I drove through a golf driving range. Thousands of dents, literally.
  16. Jun 26, 2015 at 5:06 AM
    TacomaMike37
    13' DCLB MGM
    Are the dents nice and smooth, meaning no creases? If so, they can.
    Hoping it isn't thousands of dents though! You might want to take it through an insurance claim as it will get pricey. Any pics?
  17. Jun 26, 2015 at 5:57 AM
    6xchamps
    6xchamps Well-Known Member
    Fuquay Varina NC
    2015 AC
    They did pdr on my Nissan when I got caught in a hail storm. Same thing as yours. Literally thousands of dents. Hood, roof, pillars. I filed and they did pdr to fix it
  18. Jun 26, 2015 at 6:02 AM
    AR15xAR10
    2013 TRD Sport 4x4 V6 ACLBFTMFW
    I recently had every single dent in my truck (mostly from the previous owner) removed by a paintless dent removal specialist. The work is absolutely phenomenal! Not a single wave even in the body lines. I don't know how he did it but i am very pleased
  19. Jun 26, 2015 at 6:06 AM
    skiergd011013
    I know for most of them, they get behind the dent and use special tools to very carefully massage it out. I have also seen videos of them using an array of fluorescent lights/mirrors to use the reflections to achieve perfect results.
    AR15xAR10[QUOTED] likes this.
  20. Jun 26, 2015 at 6:11 AM
    AR15xAR10
    I'll post pictures later
