Had the truck two weeks , it runs better on 89 octane
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Koolbreeze7, May 26, 2020.
  1. May 26, 2020 at 7:38 PM
    boston23
    boston23 Well-Known Member
    Adam
    Eastie
    2019 SR5 DCSB 4x4
    Dont you need less octane at altitude?
    brian2sun and JoeCOVA like this.
  2. May 26, 2020 at 7:43 PM
    BSFord
    BSFord Well-Known Member
    2018 TRD Sport 4x4
    Clazzio PVC Seat Covers Dashcam install TRD Pro Grill MESO Total Tail Stage 1 Tailgate Lock vled total interior light upgrade TRD Pro Shift knob N2 Designs Autostart w/ smart phone module
    Correct, it's why they can get away with selling 85 in the mountain states
  3. May 26, 2020 at 7:46 PM
    Silverlogic
    Silverlogic Well-Known Member
    Tyler
    San Diego, California
    2018 Silver DCSB TRDOR
    You are correct, it isn't about power content of the fuel. It's about how much the ECU retards ignition.
  4. May 26, 2020 at 7:47 PM
    Taco_Coma
    Taco_Coma That's a lovely accent you have. New Jersey?
    South NJ
    2018 DCSB SR5
    No idea how but I've been getting 26 mpg on 87. Finally off that winter gas
    BSFord likes this.
  5. May 26, 2020 at 7:55 PM
    CanadaToy
    CanadaToy Well-Known Member
    Greg
    Toronto
    17 DCSB TRD OR Alpine
    TRD Pro grille & skid, OEM tonneau and roof racks
    I'm running the OV tune with 91 octane... it is a big boost from 87 octane (with the tune). Never tried 91 on OEM tune. But i bet it would make some difference.
  6. May 26, 2020 at 7:56 PM
    mattleg
    mattleg Well-Known Member
    Kansas
    2020 OR DCSB AT 4WD
    Absolutely incorrect, NIST established the weight and measurement program that state environmental agency's follow. Each state varies on implementation. In general random samples are taken and either analyzed on the spot or sent to a lab for testing per ASTM standards. Octane is one among many tests performed. Non-compliance penalty varies, usually a notice of non-compliance and a grace period to correct the deviation. Monetary penalty come in to play for repeated or intentional non-compliance.
    The whole mix thing is generally true, although less so today with ethanol around. If they do blend at the pump they tend to error on the side of extra 91 to avoid trouble. Depending on the area and ethanol the mid grade may be mixed in the carrier tanker at the terminal so that station can offer ethanol free grades for recreational vehicles.
  7. May 26, 2020 at 7:56 PM
    Ricertruc
    Ricertruc Well-Known Member
    17 OR4B4 06 Prerunner
    ADS CO Icon UCA AAL SCS Rims KO2s Fox 2.0 CO
    I think I blew up my head gasket on my 96’ taco 3RZ-FE from 85 gas (in NM at the time) and/ or from not replacing the coolant enough. All my tacos from now on get 91 and get fresh coolant every 2 years. That’s just me and my paranoia from spending so much $$$ on rebuilding the engine. I’ll wait in line at Costco and spare some cost on premium though. It had almost 200k miles on it though.
  8. May 26, 2020 at 7:59 PM
    boston23
    Adam
    Eastie
    2019 SR5 DCSB 4x4
    I use 86
  9. May 26, 2020 at 8:01 PM
    JEEPNIK
    JEEPNIK Well-Known Member
    2020 Voodoo Blue TRD Sport
    Having made gasoline for about 20 years, and running variously modified vehicles before and since if a vehicle is set up properly octane is all about compression. If an engine is designed for 87 and you haven't made significant changes to the operation of the engine then run 87. Everything else is a waste of money. The station and refiner will thank you for using the higher octane, but that's the only benefit you'll receive.
    When I was young and dumb I used to get racing fuel at a place called SoCal racing fuel. I'd fill my '68 Nova up and take it over to Brotherhood and I swore it made the car go faster. It didn't, I probably shifted better. Once I studied chemistry and got into the petroleum industry I figured I had just wasted my very limited funds to no advantage.
  10. May 26, 2020 at 8:02 PM
    JasonLee
    JasonLee Hello? I'm a truck.
    Q322+3C Denver, Colorado
    15 TRD OffRoad
    TRD Supercharger and more.
    85 works best in my truck.
  11. May 26, 2020 at 8:09 PM
    DevilTaco4
    DevilTaco4 Well-Known Member
    Folsom, CA
    2017 SR Access 5MT
    typo - I’m so baked.
    less peak cylinder pressure (lower engine compression) At elevation = lower min. Octane required. I use 87 heading up the hill, 91 around town.
    Science says 91 shouldn’t feel more “smooth,” but it does seem smoother considering my driving style = shifting at 3-4rpm 24/7. Placebo? Sure.
  12. May 26, 2020 at 8:10 PM
    ericvega
    ericvega Well-Known Member
    Eric
    2019 MT TRD OR DCSB
    Magnusson Supercharger Kit RCI Skids C4Fab Sliders CBI BedRack Bilstein Bypass Shocks Icon RXT Leaf Pack
    3-4 rotations PER MINUTE? Boy, no wonder you're feeling a rough ride ;)
  13. May 26, 2020 at 8:11 PM
    mattleg
    Kansas
    2020 OR DCSB AT 4WD
    Well there's your problem, you forgot the part where you twist the distro cap to advance the timing. You should have taken engine theory from the mechanicals.
    Hank Heel likes this.
  14. May 26, 2020 at 8:12 PM
    JEEPNIK
    There was a time that if a station had a Chevron sign on the building they had to sell Chevron gas. Not so much any more.
    But here's the real kicker. Let's say refiner A has contracts for X amount of gasoline. But he's short. So he borrows some for refiner B. And that blend of what ever ratio ends up in the stations tanks. Later refiner B is short so he gets some from refiner A as payback. They do the same thing with crude oil, diesel and any other distillates.
    Then you can and the fact that in many places Refiner A and Refiner B use the same pipelines. Now depending on whats going through the pipe on consecutive pipeline movements they may or may not put a plug, usually water, in the line between the movements.
    An example of how much of it is marketing is the old Shell gasoline with "Platformate". Now every refiner reforms gasoline (increases the octane by altering the molecular structure). But most called it just that reformate. It's all done with a platinum based catalyst. Shell just trade marked the name for what everyone was doing and spent a fortune advertising how much better it was. It was a good ad campaign as lots of folks would insist on Shell gasoline.
  15. May 26, 2020 at 8:19 PM
    #35
    mattleg
    Kansas
    2020 OR DCSB AT 4WD
    Are they pushing biodiesel on the pipe lines much yet. I deal with fuel contracts for emergency equipment and avoid it at all costs. Not a big fan when the FAA caved on it. It getting harder to find sources that test bio free.
  16. May 26, 2020 at 8:20 PM
    #36
    JEEPNIK
    No, I pretty much had figured out timing by them. But dwell so illusive.:rofl:
  17. May 26, 2020 at 8:25 PM
    #37
    Bryanccfshr
    Bryanccfshr Well-Known Member
    2018 Trd OR , 2018 TRD Pro 4Runner
    Meh, the direct injection can actually lower the octane requirement. 87 is fine.
  18. May 26, 2020 at 8:31 PM
    #38
    Beancooker
    Beancooker Alea iacta est
    The middle of Arizona
    2021 Jeep Wrangler Rubicon
    Lots, straight from the factory.
    87 clear gas (ethanol free). Altitude ranges from 3000 to 4500 above sea level. Truck drives great.
  19. May 26, 2020 at 8:39 PM
    #39
    Cudgel
    Cudgel “Tonka”
    Live in: An Ocean of Plastic Trash
    2017 OR DCLB
    ICON8 Lift -285s. upTOPoverland rack.
    Does it knock? That is the point of octane ratings at 600/900 rpm tests. If you are getting a noticeable difference you might need a tune up or maybe you are on summer mix?
  20. May 26, 2020 at 8:49 PM
    #40
    Phich
    Phich Porkchop Express
    San Antonio
    2017 TRD Off Road tuned to KDMax perfection
    Six Demon Bag
    Octanes and elevations are a strange thing. Basically at sea level, the engine makes a certain amount of HP, generally higher than at higher elevations. Take that same engine with the same octane at 8000 feet and the HP can diminish by as much as 10-15%.
    I live in San Antonio at 700 ft. I just did a job outside Denver at 6000 feet. I was up there for almost two weeks and drove about 300ish miles during that timeframe. I got better mileage in Denver around town with Colorado 90 octane fuel (highest available there) than I do back home in SA with Texas 93 octane. Similar driving habits, highway and city. I run premium because I run an OVTune 91 octane tune.
    All in all it seems like the variables from truck to truck, driving style to driving style, fuel brand to fuel brand, location to location, etc..., are too many to categorize into any kind of system that one could truly compare with any sort of accuracy or continuity.
