Had to argue with mechanic about fluid temp for trans fluid check
Discussion in '3rd Gen. Tacomas (2016-2023)' started by TheCount420, May 12, 2022.
  1. May 12, 2022 at 7:32 AM
    TheCount420
    TheCount420 [OP] Well-Known Member
    Rich
    New York
    Had my 6 year exchange done, mechanic went back and forth with me for nearly a day essentially ignoring the fact that Toyota specifies the temp range to check the fluid. Finally found the listing in the service manual and emailed it to him and had him recheck it at 100 degrees. Spec I found was 95-113. Was I wrong? If the fluid expands when hot, checking it at 185 would in my mind make for a lower level as more would drain out with the heat expansion.
    TacoManOne and Otterstuff like this.
  2. May 12, 2022 at 7:39 AM
    brian2sun
    brian2sun Well-Known Member
    California
    ‘21 TRD OR DCSB ‘17 4Runner Limited ‘97 4Runner SR5
    Find a new mechanic who values following correct procedures.
  3. May 12, 2022 at 7:39 AM
    JoeCOVA
    JoeCOVA Well-Known Member
    Joe
    Colorado Springs
    Its more important to check in warm than cold but think you are overthinking this.
    pmoore4321, vicali and auskip07 like this.
  4. May 12, 2022 at 7:42 AM
    TacoSupremo19
    TacoSupremo19 Well-Known Member
    NJ
    2019 Black Tacoma TRD SPort DCSB
    Brushed Copper Blaze 10 Rims | 265 70 17 Toyo Open Country A/T III tires | Bilstein 5100 w/ Eibach Coils 2.5" lift | Blackhawk UCAs | ICON Rear 3 AAL |TRD Skid Plate | TRD CAI | OEM Rear Bed Lighting | OEM rear Tailgate lock | RC Bed Molle Racks | Custom Blacked out OEM LED Headlights | MESO V4 Mirror Turnsignals | MESO Interior trim blackout | TG DMM dash mount | TRD Shift Knob | OEM SR5 interior door handles | Upgraded Stereo including Alpine 700W Amp Alpine Type R Components & Hertz speakers 12" Sub | Custom Clazzio Seat covers | Mobtown Sliders | Front Camera
    Sure he’ll check the temp now….with an IR gun on the trans pan lol. The level of incompetence out there is astonishing. Just mount and balance my tires and align my suspension please I’ll take care of the rest.
  5. May 12, 2022 at 7:45 AM
    TheCount420
    Rich
    New York
    Luckily it was done after sitting over night and idling to 100 monitored on a scan tool.
    TacoSupremo19[QUOTED] likes this.
  6. May 12, 2022 at 7:46 AM
    TheCount420
    Rich
    New York
    I suspect it was in fact low as I wasn’t charged for all the back and forth and he’s just saving face.
  7. May 12, 2022 at 7:48 AM
    TacoSupremo19
    NJ
    Is that what he told you or did you witness it? I mean it really is an easy procedure. He spent more time arguing when he could have just done it the right way in 10 minutes. Geez.
    Otterstuff and JJ Diablo like this.
  8. May 12, 2022 at 7:48 AM
    TheCount420
    Rich
    New York
    Seems to me if the engineers spec 95-113 that and call out maintaining that range, even if it means turning the truck off to get back to it, too much would be lost with heat expansion if checked at 185 which is where he originally went for it.
    Otterstuff likes this.
  9. May 12, 2022 at 7:49 AM
    TheCount420
    Rich
    New York
    Pride does some shit to people man
    cryptolime and skeletron like this.
  10. May 12, 2022 at 7:53 AM
    auskip07
    auskip07 Well-Known Member
    Skip
    Atlanta, Ga
    2019 TACOMA SR V6 SC , 4X4, AUTO, 4.88, 265/75 r16
    how much do you think the fluid expands? 1/10 of a quart with an 85 degree difference?
    b_r_o likes this.
  11. May 12, 2022 at 7:58 AM
    TheCount420
    Rich
    New York
    Idk man I’m not an transmission engineer. If it wasn’t important it wouldn’t be specified in my eyes
  12. May 12, 2022 at 8:08 AM
    TA2016
    TA2016 Well-Known Member
    Oregon
    2016 TRD Sport AT V6 4x4 ACLB P&T Package Red
    Just curious, is the Tech at a Toyota dealer service dept. or an independent shop?
  13. May 12, 2022 at 8:10 AM
    TheCount420
    Rich
    New York
    Independent transmission shop. I was polite and respectful as the guys been doing this a long time but it was like pull teeth even after I said listen man I don’t want anything for free I just want this done to Toyota spec.
    Otterstuff and cryptolime like this.
  14. May 12, 2022 at 8:16 AM
    JoeCOVA
    Joe
    Colorado Springs
    You have to realize that transmissions are typically checked at normal operating temperatures which is around that 185 degrees. Do you know how long it takes to actually get the temperature up to 185 degrees.
    Think about it, how much time and labor is wasted waiting for a trans to get to temp when it can be checked at 95 after a few minutes of idling.....toyota takes this into consideration when determining maintenance.
    Wulf and auskip07 like this.
  15. May 12, 2022 at 8:18 AM
    TheCount420
    Rich
    New York
    I’m not sure what side of the fence your landing on here, I mean it seems to me if the procedure was followed by the book to begin with it would have saved both of us a lot of time
    xxTacocaTxx and Skydvrr like this.
  16. May 12, 2022 at 8:21 AM
    JoeCOVA
    Joe
    Colorado Springs
    I think the thread and your argument with the mechanic are both moot. Why bring it to a mechanic if you already have the answers.
    Chew, mic_sierra, b_r_o and 2 others like this.
  17. May 12, 2022 at 8:24 AM
    TheCount420
    Rich
    New York
    Don’t have a lift. A proper scan tool to monitor temperature. I don’t mind paying a professional but I also expect the job to be done correctly
    xxTacocaTxx likes this.
  18. May 12, 2022 at 8:25 AM
    JoeCOVA
    Joe
    Colorado Springs
    At the end of the day, he checked it at 185 and 100, what the the difference in results?
    If you want something done correctly, then you need to do it yourself. Not even Toyota does things correctly or "by the book"
    Chew and tcjacado like this.
  19. May 12, 2022 at 8:27 AM
    TheCount420
    Rich
    New York
    Remains to be seen. I pick it up later today. I would suspect it required more fluid and that’s why I wasn’t charged more for the time he spent after seeing in print what the specifications were.
  20. May 12, 2022 at 8:29 AM
    JoeCOVA
    Joe
    Colorado Springs
    Let us know.
