Had to Drive 15 Miles Without a Radiator
Discussion in 'Technical Chat' started by BallsDeep, Mar 10, 2014.
  1. Mar 10, 2014 at 12:03 PM
    BallsDeep
    BallsDeep [OP] New Member
    First...
    2014 Tacoma TRD (OffRoad)
    5,000 miles
    Bone Stock
    Question...
    At what temperature will the aluminum block start to become damaged?
    Thanks for any comments.
  2. Mar 10, 2014 at 12:09 PM
    XXXX
    XXXX Well-Known Member
    sKiP
    05 Prius
    Never overheat an aluminum block. It's most likely trashed if you overheated it real good. Unlike ol cast iron blocks the aluminum warps like no other.
    If you ever need the engine to cool down turn the heat on max (not recirculate) and keep the rpm's down. even crack the hood if your going real slow.
    My comment to you is to delete your above post and let insurance cover it. Hopefully you did smoke the engine and it is covered by insurance. I would not admit to anything unless specifically asked. Just tell them you crashed. Sometimes to much info is a very bad thing.
  3. Mar 10, 2014 at 12:11 PM
    TJGARZA84
    TJGARZA84 Well-Known Member
    TIM
    SAN ANTONIO
    2012 TOYOTA TACOMA PRERUNNER SR5 - BLACK
    TINT - 20% FRONT - 5% REAR 3 INCH LIFT PAINT TO MATCH GRILL AND REAR BUMPER REMOVED ALL EMBLEMS
    +1,0000000000000000
  4. Mar 10, 2014 at 12:14 PM
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    Yeah it's fucked
  5. Mar 10, 2014 at 12:14 PM
    TexAggie
    TexAggie Well-Known Member
    Eric
    Houston, TX
    OME Lift
    X2, aluminum block + no radiator + mountains = dead engine
    Next time get out and walk until you get cell service or try and get a ride from a passer by. Sorry for the bad luck.
  6. Mar 10, 2014 at 12:19 PM
    TACO626
    TACO626 Well-Known Member
    Montclair, CA
    02 Tacoma 2.7
  7. Mar 10, 2014 at 12:35 PM
    BallsDeep
    How is this Spam?
  8. Mar 10, 2014 at 12:57 PM
    XXXX
    sKiP
    05 Prius
    I wouldn't worry about the guy with 97 posts calling you a spammer.
    I'd be more worried about what you said in here in writing coming back to bite you in the ass. Delete Delete Delete
  9. Mar 10, 2014 at 1:03 PM
    TrdSurgie
    TrdSurgie revised
    Oahu
    That.
