half shaft troubles
Discussion in '1st Gen. Tacomas (1995-2004)' started by 04trd, Feb 22, 2012.
  1. Feb 22, 2012 at 6:42 AM
    04trd
    04trd [OP] Well-Known Member
    Cleveland Ohio
    2015 f150 lariat
    weather techs, 20precent tint, leveling kit, back flip bed cover, rhino liner
    hey guy i have a 2004 tacoma trd off road, i put a toytech fully adjustable front coil overs on and on the rear i put on expedition all pro 3 inch lift springs on, my question is how can i reduce the angle on the half shafts? they are pretty steep and the only thing i can think of is lowering the front of the truck down. If i do that it would look stupid,any advice would be super help full!
    thanks TW!
  2. Feb 22, 2012 at 6:43 AM
    TacoMX
    TacoMX TW's Official anti body-lift pundit
    Jonathan
    Deltona, Florida
    Front diff drop can help a lot. How high do you have the coilovers cranked to, 3''?
  3. Feb 22, 2012 at 6:51 AM
    04trd
    Cleveland Ohio
    2015 f150 lariat
    i have the front diff drop installed and they are at like 2.5 inches trying to make it level to the back but the front is still lower trying to save half shafts
  4. Feb 22, 2012 at 7:03 AM
    04trd
    Cleveland Ohio
    2015 f150 lariat
    here is a pic of the half shafts, the top part tore off of the end cause i made a mistake and extended it too much with the boot slide mod. I am waitint for the :crapstorm: about the rust, sorry guys ohio winters blow around here with all this salt! i will take care of in in spring.
    The measurement from the top of the stock tire to the fender is 10 inches
    the measurement from the center of the hub to the top of the fender is 24 inches.
    I really think the easiest way to lower the half shaft angles is to switch the leaf springs to like an inch and a half lift spring.Any information on any other ways to lower the half shafts would be great!
  5. Feb 22, 2012 at 7:05 AM
    TacoMX
    Jonathan
    Deltona, Florida
    Your only option is to lower the lift if they are bothering you. You may just have to deal with it and replace as they wear out. Thats just a part of the game.
    Not to gloat, but this is a good reason why I LOVE having manual locking hubs....No matter how bad my CV angles are...I just unlock them and I dont have to worry :cool:
    And I guess swapping to manual hubs is another option, so they dont turn all the time and only when you are locked in.
  6. Feb 22, 2012 at 7:09 AM
    04trd
    Cleveland Ohio
    2015 f150 lariat
    hmmm good idea! but i heard those are like $$1000
  7. Feb 22, 2012 at 7:09 AM
    JLee
    JLee The Man! Vendor
    Jerry
    Grass valley CA
    02 Extra cab SAS Linked front and rear
    I lost track thousands of dollars ago.
    You will never be able to get the front level with the back if you have Expos they give over 4" of lift. To get them level you would have to swap them out and lower your coils like you said. Or put about 600 to 800lbs in your bed then you would be closer to level. I have the expos on my truck and I can put 1500 to 2000lbs od steel in my bed and still have the rear about an inch high.
  8. Feb 22, 2012 at 7:10 AM
    04trd
    Cleveland Ohio
    2015 f150 lariat
    and i assume those are like the fords? when u need 4x4 u get out and turn the hubs?
  9. Feb 22, 2012 at 7:11 AM
    colinb17
    colinb17 If at first you don't succeed, don't try skydiving
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    Build thread in sig... 4-link long travel
    it looks like your inner boot tore away from the clamp? is it actually busted, or is there some kind of illusion going on here?
  10. Feb 22, 2012 at 7:12 AM
    JLee
    Jerry
    Grass valley CA
    Boot slide mod fail.
  11. Feb 22, 2012 at 7:13 AM
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    lol, took it the wrong direction.
  12. Feb 22, 2012 at 7:47 AM
    04trd
    Cleveland Ohio
    2015 f150 lariat
    yea boot slide mod fail, streached it a little too far
