Halo 9 Backup Camera Issue
Discussion in 'Audio & Video' started by npiatek, Dec 12, 2018.
  1. Dec 12, 2018 at 10:47 PM
    npiatek
    npiatek [OP] Member
    Just installed the Halo 9 in my 2015 Tacoma, everything works great except the backup camera. I assume it triggers on the EDIT REVERSE light lead (Maestro Purple White to Orange White), but nada. Just seeing if anyone else has had this issue.
    I've searched the forum, but haven't come across anything. I could have sworn I've see something on here. But any ideas would be appreciated.
  2. Dec 13, 2018 at 12:36 AM
    mctechhweng
    mctechhweng Well-Known Member
    Matthew
    2015 TRD Sport V6.
    Audio: Focal PC165, Focal KX2, JL VX800/8i, Pioneer AVIC-8200.
    Why would a reverse camera trigger on a brake light? It can trigger on the reverse lights, but you have to make sure it triggers using the correct polarity.
  3. Dec 13, 2018 at 4:48 AM
    npiatek
    npiatek [OP] Member
    It's callled writing that post at 2am haha. I meant Reverse light... ha. Yeah I'll double check, just seeing if anyone else had an issue on the 15's
  4. Dec 13, 2018 at 9:26 AM
    mctechhweng
    Matthew
    2015 TRD Sport V6.
    Are you sure you have it set to trigger on the right voltage level?
  5. Dec 13, 2018 at 7:05 PM
    destin_meeks
    destin_meeks I used to fix people's crappy stereos
    Destin
    Tuscaloosa, AL
    2017 SSM DoubleCab TRD Off-Road 4x4
    Just to double check a few more things
    Is the camera setting turned on in the radio?
    Is the camera RCA plugged into the radio?
    Is it plugged in to the correct spot on the radio?
    After those 3 things, you’ll want to grab a multi meter for further steps
    Meter the purple/white - orange/white wire while in reverse to make sure you’re getting +/-12v
    If you get power there, move on to the maestro blue/yellow in the camera harness (not to be confused with the same color wire in the steering wheel control harness.) Should be getting +/-6v on this wire
    If none of these clears it up, I might re-flash the module and try it again
