Halo head lights
Discussion in '2nd Gen. Tacomas (2005-2015)' started by tmboston, Dec 8, 2012.
  1. Dec 8, 2012 at 5:45 PM
    tmboston
    tmboston [OP] Member
    Todd
    New Hampshire
    Blacked out 09 Tacoma TRD SR5
    what do people think of the double halo head lights?
  2. Dec 8, 2012 at 5:47 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    Junk.
    eBay projector output is horrible and the pattern/cutoff sucks.
    Install drop-in HID and they suck a little less, but they are still not as good as the OEM housings.
    A few members like the look, and have retrofitted decent projectors into the housings, but it's not an easy project.
  3. Dec 8, 2012 at 5:57 PM
    Spoonman
    Spoonman Granite Guru
    Jamie
    Alberta
    If you're going to get some, get someone to do a custom retrofit. No ebay.
  4. Dec 8, 2012 at 6:04 PM
    JTrean
    JTrean Well-Known Member
    Retrofit all the way. Lightwerkz is a good company to go through for a retrofit.
  5. Dec 8, 2012 at 6:17 PM
    wing103
    wing103 Well-Known Member
    Boston
    Tacoma TRD Sport / Dark Gray
    Grill Craft upper & Lower Grill WetOK Seat Cover, Devil Horn, Bug, Windows Deflector, Side step Bar, HID 55W 8000K Headlight, HID 35W 4000K Foglight, Fog Light Mod, Interior LED Map Light Mod, Electric Tail Gate Lock, Leer Cab, Key ring light, Bed LED lights Mod, Kenwood DNX5120, Signal Mirror with Heat
    I have retrofit, but I still did not like it, I rather use the regular headlight housing plus HID will be much brighter...........
  6. Dec 8, 2012 at 6:22 PM
    tmboston
    Todd
    New Hampshire
    what do you mean by retro fit?
  7. Dec 8, 2012 at 6:29 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    Illegal and unsafe. Please do not install PnP HIDs into housings designed for halogen lamps.
    Install proper HID projector units into the stock housings.
    I didn't do halos, but they are available for these shrouds.
    Legally, they're still not exactly legal, but they are safe, do not blind other drivers, and I've never heard of anyone getting a ticket for them.
    Installing the $100 HID kits into standard reflectors causes extreme glare and is very hazardous to other drivers.
  8. Dec 8, 2012 at 6:40 PM
    jtav2002
    jtav2002 Kenny Fuckin Powers
    Josh
    Reading, PA
    2013 Tundra DBL Cab TRD OR
    Definitely do a retrofit if you have the time and a little extra cash. Look better than eBay lights IMO and ate better than just dropping an HID kit into your stock housing's which will not perform as well.
