halo projector leds not working
Discussion in 'Lighting' started by llbigdll, Jun 15, 2009.
  1. Jun 15, 2009 at 12:16 PM
    llbigdll
    llbigdll [OP] Member
    Florida
    07 PreRunner
    headlights, in dash
    i bought the projectors about 6 months ago and about 1 month into having them 3 of the 6 leds stopped working. has anyone else experienced this problem.
  2. Jun 15, 2009 at 12:49 PM
    Viet2100
    Viet2100 Well-Known Member
    Viet
    South Florida
    2016 Prius 4T
    The ones near the grille? I would check your connections, highly unlikely that all 3 would go out.
  3. Jun 15, 2009 at 12:51 PM
    DeeKay21
    DeeKay21 Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
    I've heard from many people that their LED's go out on their halo's. I don't own any but have just heard from people on this site.:cool:
  4. Jun 15, 2009 at 1:09 PM
    Fluffymonkey
    Fluffymonkey Token
    College Station, TX/ Lawrence, KS
    2013 Trd Sport DC, 07 DC sr5, 03 Prerunner
    2003: Stock 2007: Avid Offroad sliders, 30% front tint, Truxedo low-pro qt tonneu cover, aero turbine 2525 muffler w/ 8'' tip, AR25 Resonator, 16x8 Dick Cepek DC-1 w/ 265/75 Goodyear Wrangler Duratracs, 2010 headlights, ome 884 coils with .5'' top plate spacer, OME sport front shocks, bilsten 5100s rear, 2'' aal, locking gas cap, LR ucas, Viper 2-way remote start, afe drop in filter, Rocky locking bike mounts, gear chest, scangauge, pop n lock tailgate lock 2013: most things transferred over from my 07, 5100s @ .85 + eibachs, wheelers progressive aal w/ overload; compustar 2-way remote start; Antennex shorty antenna, pop n lock tailgate lock with programmable key, seat covers, Toyota's crappy all-weather floor mats (should have got Husky's or Weathertechs), TRD skid plate, led light pods mounted in front bumper valence w/ Eyourlife wireless harness and remote, led bed lights
    I've heard this as being somewhat common. I know there are a few threads about it. Search around and you might find some answers. :)
  5. Jun 15, 2009 at 3:54 PM
    llbigdll
    Florida
    07 PreRunner
    headlights, in dash
    the led wires are routed to a small transformer and i wonder if i could wire them directly to the battery and install a switch to control them
  6. Jun 15, 2009 at 8:56 PM
    Viet2100
    Viet
    South Florida
    2016 Prius 4T
    They will blow.
  7. Jun 16, 2009 at 4:19 AM
    nytmarecoma88
    nytmarecoma88 Well-Known Member
    07 tacoma
    Tonnuea Tint euro Tail lights halo head lights billet grille- black debadged black powdercaoted 17's "knight rider" mod aero turbine exhaust black bull bar multicolor halo fogs
    chances are that ur ballasts went bad, or ur connections suck. but changing leds is a breeze
  8. Jun 19, 2009 at 10:43 PM
    kraaazymike
    kraaazymike Well-Known Member
    So Cal.
    01 PreRunner
    +1. Don't do it without the proper resistor attached.
  9. Jun 20, 2009 at 5:05 AM
    nytmarecoma88
    07 tacoma
    you can even pick any color u want, be creative
  10. Jun 20, 2009 at 5:14 AM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    which ones are having the problems? The ones with the vertical leds by the grill or the other ones with leds horizontal below the headlights.
  11. Jun 20, 2009 at 5:21 AM
    nytmarecoma88
    07 tacoma
    it sounds like the vertical, the horizontal have 8 leds not 6
  12. Jun 22, 2009 at 6:26 AM
    llbigdll
    Florida
    07 PreRunner
    headlights, in dash
    the ones that are having problems are the vertical
  13. Jun 22, 2009 at 8:08 AM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    Cool....well, cool that I have the horizontal ones. Not cool that the others are having problems.
  14. Jun 22, 2009 at 8:22 AM
    nytmarecoma88
    07 tacoma
    yea mine never did work, so i just switched out all my leds
  15. Jun 22, 2009 at 10:28 AM
    llbigdll
    Florida
    07 PreRunner
    headlights, in dash
    did u have the same headlights that i am talking about
  16. Jun 22, 2009 at 6:28 PM
    nytmarecoma88
    07 tacoma
  17. Jun 22, 2009 at 8:32 PM
    llbigdll
    Florida
    07 PreRunner
    headlights, in dash
    well i tried swapping out the led but it wasnt that. 4 of the leds are working now so the 2 that are left are not getting enough power cuz u can see the led light up but barely. my guess is that the ballast is screwed up. what do u suggest i do.
  18. Jun 22, 2009 at 9:47 PM
    nytmarecoma88
    07 tacoma
    i can only tell u wut i did, i pulled out my ballasts and my leds, and i went and bought leds and matching resistors, solder them in, pretty easy to do
  19. Jun 23, 2009 at 7:18 AM
    coma09
    coma09 Senior Member. Hey, what's That supposed to mean?
    BC Canada
    2013 taco access cab 4x4
    Putco led map light bulbs, bed mat, Xiang trifecta tonneau, blackout front emblem, paint tow hoop, led bed light strip, scan gauge II, debadge, buff paint, oem fog light kit, 1000w inverter, Viair 300P compressor, Contura V dash switches, chop last L bend from exhaust, remove charcoal air filter, extinguisher, mag light, Ss side steps, kayak rack, tailgate security, bed mat security
    LEDs do not use a ballast .... you simply need a current limiting resistor in series with the feed wire. The resistor must be wattage rated.
    Roughly, a 1000 ohm 5 watt resistor would do for a series of LEDs - however I'd have to see the board.... look for heated (brown stained) board or components.
    Use a higher wattage resistor for replacement, of the same value.
    Could be a bad solder joint, or connections. LEDs either work or don't, so it's the wiring, or cct board connections. Simply re-solder the LED connections to the cct board. That's likely all that's wrong.
    Vibration related fatigue is my guess.
  20. Jun 23, 2009 at 11:47 PM
    ColtsTRD
    ColtsTRD .....
    Scott
    AZ
    2005 TRD DCSB
    I own those headlights too and I hate 'em! They look cool and all but they were a b*tch to install and the little blue LEDs don't twist lock in so when ever I go wheelin' they vibrate out of their hole! They vibrated out when I was muddin' and mud actually got inside the damn head unit :-( not so much that you notice but still...i spent 200 bucks on the damn things and they've been nothing but a headache!!!!
