Halogen fog light bulb 2020
Discussion in '3rd Gen. Tacomas (2016-2023)' started by tacos4u, Jan 7, 2023.
  1. Jan 12, 2023 at 4:25 AM
    #41
    tacos4u
    tacos4u [OP] Active Member
    Fit the same as my 64219l which says h16 19w these say h11 55w
  2. Jan 12, 2023 at 3:51 PM
    #42
    Toy_Runner
    Toy_Runner Well-Known Member
    99 4Runner SR5
    3" OME lift, heavy coils f/r 3/16" steel skids Modified Coastal Offroad diy bumper 5spd swap ('98 donor)
    They have the same base. However the H11 will not focus correctly in a lamp made for an H16, and, being significantly more powerful than an H16, will be glaring to anyone else on the road as a result. The earlier, wide-angle H11 fog lamp is not what was equipped on your truck. You can use H16 bulbs, buy a new H11 wide angle fog lamp set through a dealer (or used from someone else selling theirs), or step up to a significantly better aftermarket LED option.
  3. Mar 13, 2024 at 12:56 PM
    #43
    Braketest2
    Braketest2 Well-Known Member
    Jim
    2019 TRD Off Road
    AFE Y-pipe, 2.5 inch catback CAI 3 inch Dobinson's lift
    Does anyone know if the 2019 fog light harness on my TRD is the same whether or not you have the LED/DRL? I have the LED/DRL and I hate them. I wanted to go back to the H11 assembly and need to know if the housing I need would fit and the wiring would still support 55W. The OEM part number for the H11 would also help if anyone has it. Thanks all!
