Halogen Projection Retrofit 04 Tacoma
Discussion in '1st Gen. Tacomas (1995-2004)' started by DestroyerLite, May 20, 2015.
  1. May 20, 2015 at 7:01 AM
    DestroyerLite
    DestroyerLite [OP] Well-Known Member
    DFW
    04 Tacoma SR5 V6 4X4 Auto
    So as the title says I would like to see about retrofitting some halogen projectors on my 04 Tacoma. I don't want HIDs since I like (I know I am weird) the DRL feature and don't want to disable or relocate that. Also in my head a halogen is cheaper and easier to replace if it gets broken.
    I tried to search online for retrofit kits but all I find is HID as I suspected. My parents Camry has H11 projectors I believe but I am not the super creative type that will be able to just put those in the tacoma housing.
    Anyone have any info if I can even accomplish this?
    Thanks,
    Dan
  2. May 20, 2015 at 10:24 AM
    NightProwler
    NightProwler Well-Known Member
    Harlan
    Maricopa, Az
    '01 Prerunner, '16 trd4x4, '03 cbr954rr, '03 rc51
    Don't think there's any available. Unless you get some oem and retro them in somehow. And hids do not interfere with your dtrl. Your headlights are on a separate circuit. And hids last much much longer than halogen bulbs. And are no harder to replace. Don't mean to burst yer bubble. Just sayin.;) if I were you I'd do a basic hid retro with nothin fancy so that only the bulbs are the serviceable item.
    SixthSnail likes this.
  3. May 22, 2015 at 5:36 AM
    DestroyerLite
    DFW
    I thought since the DRL work on a lower setting that the ground is pulsed so the HIDs would strobe when the DRL circuit is activated... am I mistaking here?
    --Dan
  4. May 23, 2015 at 8:58 AM
    04yota
    04yota Well-Known Member
    Angelo
    Central New Jersey
    04 ext cab supercharged 5speed
    Look into the retrofit source, i installed the mini d2s in my 04 and it is wayyy better than stock. IMO i think it is worth the upgrade. I Installed those led rings and use those as DRLs.
