Halogen to led DRLs
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Spencer9797, Feb 15, 2018.
  1. Feb 15, 2018 at 7:33 AM
    Spencer9797
    Spencer9797 [OP] Well-Known Member
    Spencer
    2017 Long Bed Tacoma SR5 Double Cab
    I’ve got a 17 Tacoma SR5 that came with factory halogen running lights. I bought the Spyder headlights as a replacement and I can’t run them because my truck didn’t come Factory with LED running lights. Does anyone know of a harness or what wires I tap into in order to have the led capability of other Tacoma’s? I’m sure the wires are there, it’s just a matter of finding them
  2. Feb 15, 2018 at 7:34 AM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    2021 TRD Poser Pro Manual.
  3. Feb 15, 2018 at 10:34 AM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Welcome! Do you have a link to the lights you bought? Spyder does not list any headlights for 2016+. Maybe you mean Xtune?
  4. Feb 15, 2018 at 2:26 PM
    Spencer9797
    Spencer
  5. Feb 15, 2018 at 2:59 PM
    ratcityrain
    ratcityrain Well-Known Member
    Seattle, WA
    2017 Double Cab Off Road
    OEM Running boards |oemassive headlights | winjet tail lights | led lighting | hid headlight & fogs | oem tri-fold Bed cover | Custom dual JL Audio 10tw3-d4 sub box and custom amp rack | black off road wheels | painted oem grille | jbl door speakers |
  6. Feb 15, 2018 at 6:11 PM
    scBryan7
    scBryan7 Well-Known Member
    Santa Cruz, CA
    2019 Cement Tacoma TRD OFF ROAD V6 4X4 ACLB
    SHELTON PAINTING
    Ooh I was gonna do the same thing, let me know how it goes! THOSE LIGHTS ARE DOPE!
  7. Feb 15, 2018 at 6:34 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    I think Carid might have the brand mislabeled, unless they came in Spyder packaging?
    Regardless, TacomaBeast says those lights won’t work in SR models.
    https://tacomabeast.com/collections...headlights-w-sequential-turn-signal-light-bar
    The Retrofit source has a great collection of OEM light socket adapters. You could find one for your DRLs and build a custom harness that plugs into your OEM DRL and build something to connect it to the new lights.
  8. Feb 16, 2018 at 5:12 AM
    Spencer9797
    Spencer
    I had to return them cause they aren’t made for SR5 or lower. You gotta have Factory led DRLS in order for all plugs to be used and have everything work right. Other than that though, they look awesome on the truck which makes it that much harder to send them back. If you already have LED DRLS I’d say go for it cause it’s awesome
  9. Feb 16, 2018 at 5:21 AM
    Leathermatt
    Leathermatt Well-Known Member
    Boston, MA
    2016 SR MGM ACLB 4x4
    255/85/16 Cooper ST Maxx 33s Midland CB Radio w/ A-Pillar Mount KB Voodoo Mid-Rise Bed Rack Bedrail-Mounted Headache Backrack OEMassive LED Sequential Headlights Tail Light Guards w/ VHT Niteshades Tint 50" Curved LED Cree Lightbar w/ MCM Fab Brackets 3" LED Front/Rear Lower Cube Lights (OZ Pods) 2" LED Fog Light pods (OZ Pods) MBRP Ditch Light Brackets w/ 2" OZ Pods Bushwhacker Bolt-On Style Fender Flares Rear EVO3 Bumper Guard Plasti-Color Flushmount Mudflaps Rear Cabin mounted Survival Bag/ Medical Kit Black 3" Access Cab Nerf Rails Black Powdercoat Fine Mesh Grill (Customgrills.com) Black Metal Grenade Grill Emblem Insert 2" Black Receiver Hitch w/ Pintle Hitch or D- Shackle Black Aluminum 21" Toolbox Interior Black Leather Seat Covers Weathertech Window Visors Weathertech Hood Bug Deflector
    Yes, I have an SR and have posted a brief explanation of what I did as well as a short YouTube video in the thread mentioned above. I got the white DRL ring to light up while the headlights are on, while the DRL switch on our SR/sr5 will illuminate the yellow ring, not the white ring. I actually like it better this way. The turns signals work beautifully
    ratcityrain likes this.
  10. Feb 16, 2018 at 5:30 AM
    Spencer9797
    Spencer
    Can you link me to that video?
  11. Feb 16, 2018 at 5:35 AM
    Leathermatt
    Boston, MA
    Cut the plug off the DRL on new housing, cut the plug from stock wire harness, spliced together. Did a wire tap off of the blue DRL wire, ran it to the brown wire of the fifth plug(also pulled that plug out and cut it), and did another wire tap on the black/white DRLwire and ran it to the blackwirecoming out of the fifth plug. Everything is already taped up, so you can't see my side ring but I try to explain what's going on
    https://youtu.be/RTury7OX-fo
  12. Mar 18, 2018 at 8:24 PM
    scBryan7
    Santa Cruz, CA
    SHELTON PAINTING
    Sounds like you coulda pulled it off after all uh?
  13. Mar 19, 2018 at 1:45 AM
    Spencer9797
    Spencer
    It seems like I could have if I was willing to cut the factory harness to shreds, but I had already sent them back by the time I got the video link so it's probably for the best. I more than likely would have burned the LEDs with faulty wiring anyway hahaha
  14. Mar 19, 2018 at 3:09 AM
    Kirbstomp1287
    Kirbstomp1287 @MilSpecTaco
    17’ Inferno SR5 V6 DCSB XP
