Halp!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Krazie Sj, Apr 9, 2009.
  1. Dec 24, 2020 at 9:19 PM
    #361
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Old thread is old
    Island Cruiser likes this.
  2. Dec 24, 2020 at 11:09 PM
    #362
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    :laugh:
  3. Feb 12, 2021 at 2:48 AM
    #363
    Hogwild80
    Hogwild80 This is why!!
    Brock
    Bonifay Fl
    03 impulse red dcsb preunner
    So, I just stumbled upon this for the first time. It is a very old thread, but probably the greatest thread on TW. Kudos to @Krazie Sj for having the ball to post his mistake knowing he was going to get blasted. Respect.
    TreeFortRichard and wilcam47 like this.
  4. Feb 12, 2021 at 7:52 AM
    #364
    CurtB
    CurtB Old Timer knowitall
    Curt
    Kansas
    2010 Tacoma SR5
    Poor fella only has 1 ball. :(
    6 gearT444E and Jimmyh like this.
  5. Feb 12, 2021 at 7:53 AM
    #365
    WNYTACOMA
    WNYTACOMA Well-Known Member
    Clarence, New York
    09 Metalic Grey TRD OFF ROAD
    Toyota Nerf steps Bugflector 2 Tool box Weathertech floor liners Wet Okole F/R - Bk/Char
    A one gonad nomad.......
  6. Feb 12, 2021 at 3:46 PM
    #366
    Hogwild80
    Brock
    Bonifay Fl
    My bad... I'm keyboard challenged!!
  7. Jun 11, 2021 at 10:23 AM
    #367
    taccatruck
    taccatruck Member
    2006 TRD Sport
    Stumbled across "HALP" for the first time while reading up on tranny issues. Funnily enough they came after my first diy oil change.. Laughed as I realized I also drained my tranny fluid (weird that it was red, but maybe the last oil change used some red stuff, and it was a little overdue, so maybe that's why only 3qt came out but my truck needs 5.5qt of oil). Please laugh at and with me, and tell me if I can add the same amount of tranny fluid back in (through the coolant, right? jk) without having to do a full flush :help:
    Williston and TreeFortRichard like this.
  8. Jun 11, 2021 at 2:43 PM
    #368
    CurtB
    Curt
    Kansas
    2010 Tacoma SR5
    Put 3 quarts back in. What engine is in your truck?
  9. Jun 11, 2021 at 5:19 PM
    #369
    taccatruck
    taccatruck Member
    2006 TRD Sport
    It's 4WD 4L 6cyl
  10. Jun 12, 2021 at 1:45 PM
    #370
    Larzzzz
    Larzzzz Grande' Ricardo
    Larry
    MA
    '06 dclb 350+ kmiles
    Aux back up lights, Bed lights, Re-located trailer plug, Good dooby, a.k.a. jumper cable mod, Heated seats, back up camera,
    At a minimum, replace what was drained. These trucks came low from the factory, so I'd add another pint the check the level.
    It's a sealed tranny, soooooo you gotta jump through a hoop or 2 to check the level. The fluid has to be in a temperature range and the Allen wrench bolt removed from the pan to check the level.
    Ya, while the engines running.. be careful.
    There's a bazillion threads about it. Read up on it. AND, buy a new gasket for that bolt.
    Good luck
  11. Feb 11, 2024 at 3:09 PM
    #371
    Williston
    Williston Well-Known Member
    2014 Tacoma DC SB 4x4 V6 040 [SL] SR5 Trim [TO] V6 Tow Package [ED] Entune Audio Plus
    Stock (99.999%) OEM Bed Floor Mat, OEM Front Bed Rail Cargo Net and hooks, OEM Gentex Auto-Dim mirror w/Compass & Outside Temperature Display, TRD Pro Grille, Uni-Filter air pump modification, WeatherTech floor liners f/r. (winter), OEM All-Weather Floor Mats (summer).
    Almost 15 years since this thread was started and soon three years since I joined, and I only came across it just now. Hall of Fame stuff here. Not sure if they [OP] are still around, but Kudos to them for posting and sharing with us. staying with it to the end, and having a sense of humor about it. :bowdown: Don't think I would have had the guts to admit it, never mind post/share it with the world. Priceless.
    A tip of the hat to your sir! Thank you. :thumbsup: :proposetoast:
    mrkabc likes this.
  12. Feb 12, 2024 at 5:32 AM
    #372
    FishaRnekEd
    FishaRnekEd Well-Known Member
    New Orleans, LA
    2005 4.0 6spd 4x4 Dbl Cb short bed
    Hahaha, i forgot about this thread and thought someone else did this shit again (before i noticed it was the old thread).
  13. Feb 12, 2024 at 6:45 AM
    #373
    tacobp
    tacobp Well-Known Member
    Bob
    North Carolina
    09 Tacoma, 2.7 automatic
    Installed a Pop n Lock,,That's it !..Bone stock
    Holy shit ! Put this thread out of its misery !
  14. Jun 20, 2024 at 4:15 PM
    #374
    texvet61
    texvet61 Well-Known Member
    Ocala, FL
    09 Tacoma TRD Sport
    Lighting: Phillips LED headlights, BD's S2pro fog lights, LP4 pro and LP9Pro Racing LED's, Black OaK IR cubes. COMMS: Cobra WSX75 CB, Icom 7000 Ham Radio, antenna; Alpha MotoSS HF 80m-40m, CA-2x4SR tri-band 2m/70cm/ - AUDIO: ALPINE ILX-W650, KTA-450 Amp, S-A60M 300Wt mono amp, F/R door speakers, JL Audio C2-650X, JLAudio Micor 8" sub. C4 Fab Hybrid Bumper, Warn VF12000S, Locking Rear seat Gun Vault. Locking Console Gun Vault, FPV winch Camera,
    Just found this looking for something else…if it makes u feel any better, 4months after buying my 09 used, was changing oil, 4yo grand daughter wanted to watch, got distracted, drained tranny, added new oil. So no tranny fluid, and roughly 11qts of oil in engine, made it about 10 miles from house when truck let me know what I did ROFL
    henryp and gearcruncher like this.
  15. Jun 25, 2024 at 6:52 AM
    #375
    oldtimertoyota
    oldtimertoyota Well-Known Member
    New Mexico
    2009 4X4 Double Cab-1986 2wd Pickup Orig own
    I thought this was a joke at first, things like this happen to all of us, thanks to the OP for humbling yourself and sharing your experience
