Halp!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Krazie Sj, Apr 9, 2009.
  1. May 8, 2009 at 4:14 PM
    #141
    Krazie Sj
    Krazie Sj [OP] Resident Jackass
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    Borla Catback Exhaust, Snorkel, 33s on either 16's or 18's, ARB Bumper, All Pro LT w/Walker Evan Shocks front and back, All Pro expedition leaf pack, 10,000lb Superwinch, Intake Manifold Spacer, Bed Rack with ARB RTT, Rotopack and Hi Lift mounted, Husky Liner mats and an air freshener from 1995.
    Truck runs good now. $150 for the Transmission shop to drain it after my mechs couldn't fix it and refill it properly again. (One of my Mechs retired and they got a new guy in.)
    Ah, but I see you didn't apply the 3M velco to the floorboard and underside of the Gas pedal. Fool.
  2. Aug 24, 2009 at 6:17 PM
    #142
    ArmoredDozer
    ArmoredDozer Member
    New Bern, NC
    07 Prerunner X-SP Double Cab
    Color matched bed cover, vent visors, Sirius plug N play custom install
    Holy crap, I just found this thread. Thank god I found this thread though, I just said to myself the other day, that I thought it was odd that the coolant is pink in my Tacoma I just got.
    To add on with my own stupid oil change stories and to re open old wounds (sorry Krazie): Back when I'm 15 years old, my dad tasks me with changing the oil on my Mom's Explorer. First oil change on that new vehicle. I had done a few oil changes by now for the old man and didn't want to let him down, so I went right to it. Everything went smoothly. I drained it, took the filter off, put on the new filter (even put oil on the gasket) and put the plug back in. Filled it up with oil, according to the book capacity, checked it, and was ready to go. So Mom's in the yard when I start it up. I hear this odd FWOOSH sound coming from somewhere underneath. Mom is jumping up and down and freaking out speaking in tongues. Well I shut it off quickly and jump out to see whats going on. :confused:
    Oil is spraying out from under that explorer all over the place. It looks like an overhead fire sprinkler in a building, just oil everywhere. Lesson learned: The factory often does not use oil on the gasket for the filter when assembling a vehicle. So on that first oil change, when you take the filter off, make sure the old gasket comes off with the filter and does not stay attached to the engine. I mated the new filter on top of the old gasket, so I only had gasket to gasket contact and that pressure blew out oil everywhere. I think it took me three hours to wipe down every square inch of the underside of that car, not to mention the driveway. :)
    Next story: Fast forward to when I am an adult. I am changing the oil on my 04 4Runner. Didn't live with Mom and Dad anymore, so had to buy my own supplies. Went and got me my filter, oil, a shiny new floor jack (to rotate tires while I was at it), and even a new drain tub for the oil. The fancy kind that are sealed except for a hole in the top and a side opening with a cap for draining the oil. So I get to work. NOTE: I was very sure to pull that little shipping plug out of the center of that new drain pan. First thing I did I pull the drain plug out, like I had done many times by this point in my life. I carefully drop the plug onto my chest where I had placed a nice thick rag and I use that to wipe my two fingers off of oil (cat like reflexes you see kept me from covering my hand in it) and to clean the plug. I roll to the side and prepare to get up to let it drain for 30 minutes or so and then come back.
    All of sudden something doesn't seem right. I says to myself, "man that oil pan sure is filling up fast". Then my wife runs outside as I start screaming the f-bomb about 20 times in a row. I am screaming obscenities because my cat like reflexes that I mentioned before caused me to freak out and try to sit up under the vehicle, smacking my head on the frame (literally dead on the frame rail). So now I am simultaneously fumbling trying to get the drain plug threaded back in the hole and snugged down and trying to not pass out, while oil is running down me and all over the driveway. Lesson learned: When you buy a shiny new drain tub, make sure that the factory didn't screw you with a defect where they never punched out the hole in the lid so the oil could drain inside. Otherwise that 5 quart or more tub will only hold about a 1/2 quart on its surface before overflowing its new lessened capacity. I very angrily cut a large hole in the top of the tub with a box cutter to solve that problem but not before having a huge mess to clean up.:mad:
    camaro322hp and DustStorm4x4 like this.
  3. Aug 24, 2009 at 6:27 PM
    #143
    squad314
    squad314 Thinks he's Steve McQueen
    Marc
    Into the mystic....(foggy Saint John, NB)
    2018 TrD Sport Upgrade
    "Hello Kitty" steering wheel cover.
    Ha!...Great stories Dozer and welcome to TW.I think you're going to fit in just fine.:D
  4. Aug 24, 2009 at 6:36 PM
    #144
    Veccster
    Veccster bass turds
    Eric
    Pittsburgh - The City of Champions
    2020 Pro
    Great read...thanks for the stories Dozer. Welcome to TW.
    I was just writing about my new Fumoto Drain valve in the Ultimate Oil Change thread. It's well worth the cost. Attach a small tube to the nipple and open the valve with a small lever. You can run the oil right into the storage container (old laundry container). It cost me $26 but will save in rags, oil pans, cleaning supplies and frustrations.
    Check it...http://www.quickoildrainvalve.com/ProductDetails.asp?ProductCode=F103N
  5. Oct 15, 2009 at 9:09 AM
    #145
    mjp2
    Milton Juevo Portimous II
    NJ
    Current: '21 Bronco Badlands. Previous: '06 TRD Access Cab, v6, 6-speed
    I think everyone could use a good laugh today. Bumpin' an old thread to the top! :D
  6. Oct 15, 2009 at 9:39 AM
    #146
    JDMcQ
    JDMcQ Well-Known Member
    The Mushroom Capital of the World
    One of my favorites. Thanks Mike.
  7. Oct 15, 2009 at 10:20 AM
    #147
    fishshooter
    fishshooter Well-Known Member
    Northwest Florida
    09 Super White TRD Off Road 4X4
    Stock
    Thanks dude, I needed that!
  8. Oct 15, 2009 at 10:27 AM
    #148
    aces2
    aces2 Senior Arshole
    Cody
    Hampton, VA
    08 SR5 RR AC 4x4
    Flowmaster 40, K&N CAI, RED brake light bulbs, BHLM, Rear dif breather line, Factory Skidplate painted BLACK, DRL's, YELLOW bulbs in Fogs Turn Signals and Marker lights, Custom "Toy Machine" center emblem, Sockmonkey "Nor-Cal" decals all BLACK, Redline tailgate damper and hood sruts, Painted steering wheel emblem BLACK, 12V always on, Foglight mod, 16" Pro-Comp 7089 rims BLACK powdercoated acorn lugnuts, BFG KM2's 285-75-16, Painted exhaust pipe BLACK, BLACK emblems all the way around, Rear BLACK bumper from base model, Radical RED "sport" grille-surround, Factory Toyota Bed extender, RED maglight mounted on each seat's side, TRD ball-type shift knob, Custom mounted Scangauge II under stereo, Aftermarket HU, Hardwired Garmin GPS 260W, TSB w/AAL and 2.5" 5100's, Weathertech floor liners, Removed front mud flaps, 95-04 "4WD" rear mudflaps, 3rd Brake light "TACO", BLACK front lip
    :D ...I'm now happy
  9. Oct 15, 2009 at 10:34 AM
    #149
    Canadianboy
    Canadianboy Taco love in East Van
    James
    Vancouver, BC
    09 TRD Sport S/B 4x4 Auto in Mag Grey
    Icon Stage 3, Goodyear Duratracs and KMC Addicts!
    Lol geez what a bad day!
  10. Oct 15, 2009 at 10:37 AM
    #150
    MAXTacoma
    MAXTacoma Well-Known Member
    Lexus GS 350
    This just made my day! Everyone at work is staring at me because I have been laughing for the last 20min and no one can figure out why... THANKS...
  11. Oct 15, 2009 at 10:58 AM
    #151
    Krazie Sj
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    Good times. Now it takes me 20-30 minutes tops flawless with no spills.
    Doghouse61 likes this.
  12. Oct 15, 2009 at 11:09 AM
    #152
    mjp2
    NJ
    You found a no-drip pump that reaches from your transmission to your radiator?
  13. Oct 15, 2009 at 11:10 AM
    #153
    Dark Knight
    Dark Knight Well-Known Member
    Jeff
    NC/SC
    4Runner Trail, 88 pickup, Tundra Platinum
    A few bolts are different.
    I hear Krazie is lookin for some blinker fluid....
  14. Oct 15, 2009 at 11:11 AM
    #154
    Dark Knight
    Jeff
    NC/SC
  15. Oct 15, 2009 at 11:22 AM
    #155
    Afwrestler1986
    Afwrestler1986 Well-Known Member
    Johnstown, NY
    01 trd 4X4 ex cab manual
    Gray wire, Some lights in the bed area, and some character marks throughout.
  16. Oct 15, 2009 at 11:23 AM
    #156
    Afwrestler1986
    Johnstown, NY
    This is pretty good stuff, I use it on my rig. cheaper than the high-end brands, but just as effective.
  17. Oct 15, 2009 at 11:42 AM
    #157
    leg killa
    leg killa Well-Known Member
    AMERICA
    06 SBDB SR5 4x4
    TRD Hood/ Color matched grill/ De badged/ BHLM/ Viper remote start/ Pioneer AVIC Z-130BT/ BFG MT KM2/ MT Classic II/ OME Lift/ LR UCAs/ Pop and Lock
    this is by far the funiest thread ive seen on any forum..made me laugh so hard..should be a sticky..how to not change your oil
    but hey shit happens..we all had to learn some how
  18. Oct 15, 2009 at 11:48 AM
    #158
    Dark Knight
    Jeff
    NC/SC
    you have not read the hootas thread...
    edit: Cant find it....
  19. Oct 16, 2009 at 5:40 PM
    #159
    Krazie Sj
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    If I get the chance, you realize I'm going to crap in your nose right?
    I mean seriously, there's going to be some celery string shit-glued to some half digested corn in your nasal cavity. You thought smelling dung was bad? Wait to you catch a whiff of my decaying bog corpse stench being absorbed through the mucous membranes of your nasopharynx.
  20. Oct 19, 2009 at 3:04 PM
    #160
    mjp2
    NJ
