Haltech Stand alone ECU supercharger 3.4, SILVER BULLET TUNE www.snpspeed.com
Discussion in '1st Gen. Tacomas (1995-2004)' started by 1997tacomav6, May 27, 2021.
  1. Jul 28, 2021 at 11:57 AM
    treyus30
    treyus30 70% complete 70% of the time
    Trey
    Mesa / AJ, AZ
    '99 5VZ-FE Twin K03s w/Haltech
    Historic plates and 2 bar
    Oh I know a standalone is the way to go. The timing on these trucks leave a lot to be desired. I wouldn't be surprised if even fuel economy could be improved by 50%. Megasquirts are like a quarter of the price though, but they don't tune themselves.
  2. Jul 28, 2021 at 12:52 PM
    1997tacomav6
    1997tacomav6 [OP] V6 5sp,RegCab,TVS1320 Supercharger,Haltech, 800k
    Denver
    The tech guy that I meet today has a twin turbo Haltech 3.4 setup in fort Lupton, PFI speed,
    I’m sure he could give you the pros and cons, the why and why not answers
    Milor likes this.
  3. Jul 28, 2021 at 2:31 PM
    treyus30
    Trey
    Mesa / AJ, AZ
    Haltech has always been the Cadilac of aftermarket ECUs to me. I think I'd shell out if I were completely redoing the valve train and internals as well. Then you'd actually use more than a third of the RPM/PSI map. (I'm sure they tune off VE). It's just an internal/mental debate on pragmatism here. Sounds like you drive yours exponentially more than I do mine, so I get why you're chasing the smooth as butter vibes.
  4. Jul 29, 2021 at 10:36 AM
    1997tacomav6
    Denver
    Appreciate the info, I have a full tune scheduled for the 12th, he has done the 3.4 haltech before
    Digiratus likes this.
  5. Jul 29, 2021 at 10:42 AM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Brent? I know Jaime has a twin turbo 3.4 4 runner
  6. Jul 29, 2021 at 10:42 AM
    Speedytech7
    I can't wait to watch the video of your tune!
    1997tacomav6[OP] and Digiratus like this.
  7. Jul 29, 2021 at 11:28 AM
    1997tacomav6
    Denver
    Yes, I talked to both of them and about his twin turbo 3.4,
    He did have to remove the AC and hood latch in order to get the intercooler in there.
    He was impressive with mine having 670,000 :))))
    They all were actually hehe
    Speedytech7[QUOTED] likes this.
  8. Jul 29, 2021 at 11:32 AM
    1997tacomav6
    Denver
    The only down side is it probably will not be a good as it could be because it’s pushing 90 plus degrees now but it will be great once the summer temps come back down
  9. Jul 31, 2021 at 6:30 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 SCv6 AutoTrans With Lots of Mods ADS COs w/Compression Adjusters Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Kartek 7" Limit Straps Plastics Guy Front Bumpstops Total Chaos Sprindle Gussets Custom Alcan Springs +800 lbs +3" ADS 10" Stroke Triple Bypass w/Resi Rear Shocks Custom Rear Shock Relocate All-Pro U-bolt Flip w/Timbren Bumpstops 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Black 17x8 Konig Countersteer Type X 285/70r17 Falken A/T3w Gunmetal 16x8 SCS Ray10s 255/85r16 Maxxis Bighorns Limited Edition (Relentless) Elite Front Bumper Smittybilt X2O 10K Winch Diode Dynamics SS3 Sport Selective Yellow Fog Lights in the Bumper Diode Dynamics SS3 Pro 4,000 Kelvin SAE Driving Lights with Clear Lenses on the Bumper Morimoto D2S Projectors XB35 Ballasts + 4300K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Dometic CFX 55im Fridge/Freezer Alpha II Hardshell RTT Badland Custom Bed Rack Denso 210-0461 105 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Haltech IC-7 Display with Mako Dash Insert Haltech Elite 2500 Standalone ECU Magnuson MP62 Supercharger w/URD 2.2" Pulley Denso 650cc Fuel Injectors Aeromotive Stealth 340 Fuel Pump TransGo A340F Reprogramming Shift Kit Doug Thorley Headers 2.5" Magnaflow Hi-Flow CAT Magnaflow 18" Muffler w/Vibrant Resonator 13WL Brake Calipers Braided Steel Brake Lines Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Midland MTX275 GMRS Radio w/Roof Mount Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
  10. Jul 31, 2021 at 6:44 PM
    Speedytech7
  11. Jul 31, 2021 at 7:25 PM
    Shortman5
    Shortman5 Well-Known Member
    Supercharged TRD
    TRD S/C, ADS coilovers.
    Wow. Surprised that he only runs a FMU. I guess the stock ECU handles turbo powerband better than a supercharger.
    And I wonder how much of a difference it would make to move those filters somewhere pulling outside air rather than inside the engine bay
    Milor and 1997tacomav6[OP] like this.
  12. Jul 31, 2021 at 7:35 PM
    1997tacomav6
    Denver
    Yeah, he is NOT running a Haltech,
  13. Jul 31, 2021 at 7:39 PM
    Shortman5
    Supercharged TRD
    He said in the video he’s only running the FMU. I think he just went after a single to double swap and/or or a new waste gate spring.
  14. Jul 31, 2021 at 7:52 PM
    Shortman5
    Supercharged TRD
    Now I’m down a bit of a rabbit hole. TRD used to include FMUs with kits early on. Then they stopped. Maybe after they realized they could just reference the boos pressure with the factory regulator and it’s 1:1.
    Now im curious why FMUs aren’t more popular. It’s a cheap way to avoid things like the 7th or even FIC. You can get FMUs that have a much larger delivery than 1:1.
    This dude seems to be running turbos at 9psi and stock pump and injectors and is fine.
    Now I’m wondering if you could get the same exact outcome as a 7th by just using a larger FMU. Instead of 1:1 use a 3:1 or so on….
    @Speedytech7 what are your thoughts?
    Speedytech7 likes this.
  15. Jul 31, 2021 at 8:00 PM
    #35
    Speedytech7
    I've wondered this myself but I can't get a guinea pig... The least aggressive FMU you can buy that isn't a hokey adjustable one is 8:1. But 10 and 12:1 are more common. That said, if you find the right ratio the potential for success is clearly there. @1997tacomav6 has an old one with the FMU and @BartMaster1234 bought an old trd FMU, be nice to know what the ratio is. Shawn is a nice dude, if you ask in the comments he might reply. It's a bandaid, but so is the 7th... Hell @1997tacomav6 likely won't need his with the Haltech and some spicier injectors.
  16. Jul 31, 2021 at 8:06 PM
    #36
    Shortman5
    Supercharged TRD
    1997tacomav6[OP] likes this.
  17. Jul 31, 2021 at 8:09 PM
    #37
    1997tacomav6
    Denver
    I have to keep the methonal kit to control the heat under control in boost.
    There is no other way to keep the heat in check under boost
    Milor likes this.
  18. Jul 31, 2021 at 8:11 PM
    #38
    Speedytech7
    You can keep using meth, or just water... We were talking about the extra fuel pressure regulator that you have on your truck. You should bring that up to Brent or Jaime before you have em tune. They may want to disconnect it. And maybe just bring some fresh water for the meth kit, you may no longer need anything but water which would be nice. The major upside of the Haltech is removing bandaid solutions like these in favor of better more precise ecu control where possible.
  19. Jul 31, 2021 at 8:25 PM
    #39
    1997tacomav6
    Denver
    I can get away without methonal on a 2.1 pulley with the stock FMU.
    2.0” and 1.9 pulley I have to run methonal tho
  20. Jul 31, 2021 at 8:25 PM
    #40
    Speedytech7
    Yeah, but you're about to get a real tune on a real computer, you can throw all that out the window.
