HAM & CB antenna ground
Discussion in '2nd Gen. Tacomas (2005-2015)' started by kai38`, Apr 13, 2013.
  1. Apr 13, 2013 at 3:37 PM
    kai38`
    kai38` [OP] Well-Known Member
    I'm installing both a HAM & CB this weekend. I have antenna mount tabs on the side of a bed rack
    Since the rack sits on the plastic bed rail and is mounted with the OEM tracks in the bed I don't think mounting the antennas will be grounded.
    What do I need to do to install them?
    Thanks for any help
  2. Apr 13, 2013 at 3:52 PM
    LUSETACO
    LUSETACO Here for the Taco Pron
    Dennis
    South Central Pee A
    2005 PIMP MOBILE
    Yes
    Some say the bed rails are grounded. You have a lot of metal there so you should be ok. Install them, test them and add a ground wire if need be. Sorry that's all I got.....
  3. Apr 13, 2013 at 4:36 PM
    kai38`
    Thanks, Should I ground under the antenna mount or run a screw into the bed rack and run a ground to the frame from there?
    I don't want to key the mic and maybe fry the radios if its not grounded correctly.
  4. Apr 13, 2013 at 4:43 PM
    LUSETACO
    Dennis
    South Central Pee A
    2005 PIMP MOBILE
    Yes
    Ground the mount to the frame with as little wire as possible. I think you will be ok though. You have an SWR meter to check?
  5. Apr 13, 2013 at 4:44 PM
    kai38`
    I have access to a meter
  6. Apr 13, 2013 at 4:47 PM
    LUSETACO
    Dennis
    South Central Pee A
    2005 PIMP MOBILE
    Yes
    Hook up the meter, key it up and take it from there. Good luck!
  7. Apr 14, 2013 at 4:05 PM
    BarefootBandit
    BarefootBandit Well-Known Member
    TC UCA OME 884 5100 TSB+AAL 4.10 V6 6spd 285/75/16
    Running a ground strap directly to the rack should work.
    Just be sure that the antenna mount touches bare metal and isn't insulated by paint. Same with the connections for the ground strap.
    Best way to check is to take a multi-meter and ohm it out. In the end you should see continuity between the antenna connector's ground and the frame.
  8. Apr 14, 2013 at 4:39 PM
    charles leandro
    charles leandro Well-Known Member
    north alabama
    08 perrunner dc sr5
    none
    cb or sw lw requiees 208 lin ft ground for signel
  9. Apr 14, 2013 at 5:08 PM
    LUSETACO
    Dennis
    South Central Pee A
    2005 PIMP MOBILE
    Yes
    Wut?
  10. Apr 14, 2013 at 5:12 PM
    blake5995
    blake5995 Well-Known Member
    Blake
    Truckee, CA
    98 Tacoma SR5 4x4 2.7L
    X2
  11. Apr 14, 2013 at 6:59 PM
    TXPROMAN
    TXPROMAN Well-Known Member
    Martin
    NY
    2012 TX PRO TACOMA
  12. Apr 14, 2013 at 7:10 PM
    RevAdam
    RevAdam Impressive Member
    Adam
    Upstate SC
    11 TRD OR 4x4
    Icom 5100 radio, Baja Rack, Kenwood 6980, ARB Bull Bar, Lightforce HID lights, Warn winch, LED lights, 5100s, Switchbacks, Redarc TowPro
    Antenna "ground" isn't an electrical ground as most people think of it... Just mount the antenna to the rack and you'll be good.
    Make sure the shield side of the antenna mount has a good connection to the rack and then the rack acts as the counterpoise or image plane (ground plane) for the antenna.
    Dcsleeper408 likes this.
  13. Apr 14, 2013 at 7:12 PM
    RevAdam
    Adam
    Upstate SC
    11 TRD OR 4x4
    ...Looking at where your antenna tabs are, it's going to do interesting things with a U/VHF antenna.... Loading coils don't like being beside metal.
    But it'll work....
  14. May 2, 2013 at 9:08 PM
    kd8bao
    kd8bao Well-Known Member
    Henry
    Cleveland
    2000 Excursion 7.3L - Ex '11 Taco DCSB
    They do make what's called ground plane independent antennas. The ground on an antenna is the ground plane. Typically the ground plane would be the roof of the vehicle as it helps to direct and radiate the signal. The GPI antenna is designed different.
    Good luck.
  15. Jun 18, 2013 at 6:03 PM
    ZeroKingCobra
    ZeroKingCobra Member
    Moises
    San Francisco/Ventura
    2002 Tacoma PreRunner Crew Cab
    What's the name of that sweet looking rack? I'm surprised no one commented on it.
  16. Jun 18, 2013 at 6:25 PM
    kai38`
    The bed rack was made by http://anbcustomfabrication.webs.com/apps/webstore/
    They also make one that's shipable
    They will soon be making a rear bumper with dual swing outs for my Tacoma
  17. Jun 18, 2013 at 7:07 PM
    ZeroKingCobra
    Moises
    What Version is yours bolts or welded, is the middle vertical pole slightly located more to the rear of the truck, if so I like that.
    I wonder with abit of ingenuity it can be place onto a 2002 Tacoma or fab to it fit it.
    Thanks for The Reply.
  18. Jun 18, 2013 at 8:55 PM
    kai38`
    Mine is the welded version, I had it made a little taller then he usually makes them so my RTT would clear the roof
    The bars are evenly spaced but he can adjust it for your needs
