Ham Radio Antenna Install
Discussion in '3rd Gen. Tacomas (2016-2023)' started by cheuer, May 18, 2016.
  1. Jan 10, 2017 at 7:05 PM
    #41
    cheuer
    cheuer [OP] Well-Known Member
    Utah
    2016 DCSB TRD OR 4x4 Blazing Blue Pearl
    Leer 100XR, Mobtown Offroad Sliders
    No worries man, it's good to see options. I stayed away from lip mounts specifically because my brother has one and doesn't like it very much (he loves my setup and is getting a hood hinge bracket for his t4r now), but it's a much cheaper option.
    If I was going to do it again I would put it on the driver's side instead (I bought a new bracket and moved it since creating this thread), and I might go with a bracket other than relentless' that gets it more out of the way.
  2. Jan 10, 2017 at 7:06 PM
    #42
    cheuer
    Utah
  3. Jan 11, 2017 at 12:47 PM
    #43
    Duckman
    Duckman n00b Extordinaire
    Somewhere on the River
    17 White TRD ORDC TECH 4X4
    Shampoo.... also.
  4. Jan 19, 2017 at 7:25 PM
    #44
    MattAK
    MattAK Member
    Utah
    As the aformentioned @cheuer brother who had a lip mount almost identical to this one, I wouldn't use it. I had it on a 3rd gen T4R for a couple of years and when I took it off to replace it you could see where this mount had scratched the paint on the hood along the sides. I think it was from the antenna swaying back and forth and putting slight pressure along the long edge of the mount against the hood. YMMV but I'd say stay away from this type of lip mount unless you like to scratch the paint on your shiny new Taco.
  5. Jan 19, 2017 at 7:31 PM
    #45
    MeefZah
    MeefZah -----------
    Mark
    Lexington, Ohio
    2020 GX460
    I've never had this issue over several years of use on other vehicles, though I will readily admit that I buy my vehicles to use and don't care in the least about scratches, or even dents. Good advice for someone else who may be more OCD than I, but again, I never had that issue.
  6. Jan 19, 2017 at 7:35 PM
    #46
    MattAK
    MattAK Member
    Utah
    Could have something to do with how flat the surface you have it on is possibly, who knows. Just relaying my experience with this type of mount. I don't mind some trail rash (I have plenty of scratches in my not-even-a-year-old T4R already) but if I can avoid putting in scratches deliberately, I will.
  7. Apr 20, 2017 at 5:58 AM
    #47
    kalikraven
    kalikraven New Member
    2016 SR5
    TRD Intake, TRD Cat Back Exhaust, Navigation System Upgrade, Homelink Mirror, FLIR PathfindIR
  8. Apr 20, 2017 at 12:58 PM
    #48
    cheuer
    Utah
  9. Sep 3, 2017 at 3:56 PM
    #49
    Reluctanse
    Reluctanse Granny shiftin, not double clutchin
    Sam
    Newberg, Oregon
    '17 Tacoma DCSB Inferno TRD OR 6MT
    OVTuned, Grabbers, 5100s, Bakflip VP
    excuse the n00b question, but what tools are needed to attach the coax to the NMO mount? Thanks,
  10. Sep 3, 2017 at 4:39 PM
    #50
    OnHartung'sRoad
    OnHartung'sRoad -So glad I didn't take the other...
    Somewhere in the Mojave Desert...
    2017 Tacoma OR 4x4 (formerly a 1998 SR5 PU, 2002 OR 4x4, 1995 4x4 4Runner, 1985 4x4 Toy PU) ... and RIP’s (rust in pieces) to a Bronco II 4x4 & S10 Blazer 4x4
    Mounting to the windshield wiper? I wonder if it makes his signal strength modulate when he turns on the windshield wipers? :)
    All nice mounting examples here... I just went with a mag mount and put the coax in through the rear slider with some weatherstripping foam to seal up the window. It runs behind the rear seat split, under the rugs and mats up to the center console cubby where I keep my radio. Power comes from up front under the plastic console edge to the existing hole in the bottom of the cubby. Out of sight 100% except for the antenna.
  11. Feb 28, 2018 at 1:08 PM
    #51
    TACO271
    TACO271 Member
    william
    2017 Tacoma TRD 4x4 OR
    Stocko taco
    Has anyone mounted off of a ditch light setup? I like the hood hinge setup BUT I plan to mount the ditch lights. Rago fab has a nice bracket that goes to the rear on the tailgate but, thats some distance for the coax and only comes for CB antennas and not the 3/4 hole for an NMO mount. I'm at a loss and my kenwood 710 wants to be put back in service...
  12. Mar 1, 2018 at 9:10 AM
    #52
    cheuer
    Utah
    There's plenty of different mounting options. You could get that rago fab bracket and drill it out to 3/4 I bet.
    Check here for more ideas: https://www.tacomaworld.com/threads/clean-vhf-cb-radio-installs.415584/
  13. Apr 5, 2018 at 5:16 AM
    #53
    BraskaTaco
    BraskaTaco Well-Known Member
    Midwest
    2013 Tacoma TRD OR
    Is this mount still working well for you? Looks so clean.
  14. Apr 5, 2018 at 6:50 AM
    #54
    cllowe24
    cllowe24 Well-Known Member
    Mid Tennessee
    2015 access cab
    Billstines with 885 coils 2”aal Lce header, pro dry drop in filter, charcoal filter removal, light bar in grill, ditch lights, yaesu dual band radio, and a bunch of other junk
    Yes still works perfect.
    BraskaTaco[QUOTED] likes this.
  15. May 23, 2018 at 7:43 PM
    #55
    sig916
    sig916 Well-Known Member
    Noob questions: I'm buying a Midland microMobile GMRS radio pretty soon and want to know if cb antennas are interchangeable? This will be my first time installing a radio.
  16. May 25, 2018 at 7:50 AM
    #56
    cheuer
    Utah
    I don't really know anything about GMRS or CB, so you'll have to find another thread to ask this in, sorry.
  17. May 25, 2018 at 9:43 AM
    #57
    cllowe24
    Mid Tennessee
    2015 access cab
    Put my new mfj 1750 up today. It works really good. I am hitting repeaters I couldn’t now. Seems better than my j pole.
  18. May 25, 2018 at 10:07 AM
    #58
    synaps3
    synaps3 Wag more bark less
    Dave
    Los Alamos, NM
    2017 White SR5 4x4 DCLB
    SOS armor, ARE MX walk-in, Fox coils, Dakar leafs, etc
    No, they're completely different.
    GMRS is FM and UHF, CB is AM and a much lower frequency. Your SWR would be atrocious and you could blow up the radio if you transmitted.
    I'm not a HAM, so someone who is feel free to correct me if I'm wrong... I'm pretty sure you need licensed to transmit GMRS in the US. You more than likely won't get in trouble for general use, but you probably should register and learn about your radio so you don't accidentally cause interference and get fined by the FCC.
    sig916[QUOTED] likes this.
  19. May 28, 2018 at 5:09 PM
    #59
    EightGodzillas
    EightGodzillas Scales of Justice
    Lake Norman
    2018 Tacoma TRD OffRoad
    You need a license for GMRS but it's easy to get. And yea, the antenna is completely different and yea, you can fry your radio.
