Ham Radio Install
Discussion in 'Audio & Video' started by mparker, Feb 2, 2011.
  1. Feb 2, 2011 at 4:07 AM
    mparker
    mparker [OP] Member
    I searched, but everything vie seen was kind of dated..
    What does everyones ham install look like, where did you mount to radio?
  2. Feb 2, 2011 at 6:40 AM
    Jimmyjohn
    Jimmyjohn Well-Known Member
    Jim
    Big Sky Country Montana
    06 SR5 4x4 DLB CAB
    Smitty Blt Bull Bar& Skid Plate, PIAA 525SMR lights
    I have an Icom 2720 Dual Dand that I mounted under the Drivers seat with the face plate double side tape just under the heater/air switches. My antenna is mounted on the left front fender and the coax comes in through the fire wall. then under the inner panel the door sill and under the seat. I always try to have as little coax showing as I can. There is nothing like a clean install. My SWR is Flat trrough both bands. Good Luck 73
  3. Feb 2, 2011 at 6:56 AM
    gfiber
    gfiber Well-Known Member
    Gary
    Seattle, WA
    2017 Black TRD Sport Access Cab
    TRD sport pkg, Towing Pkg, Ham radio installation, bed lights, front 32 inch LED Bar behind the grill.
    I have 3 rigs so far mounted along with a High Sierra Screwdriver type antenna, 1.2 GHz whip, 900 MHz whip and a 144, 220, 440 MHz whip. The 900 MHz rig is waiting to be installed. Have an IC-7000, Yaesu FTM-350 and Icom ID-1 in the 2009 Toyota Tacoma right now. I removed the plactios behing the seat on the drivers side and replaced it with some 1/4 inch ABS sheet to mount two radios onto.
    I get some photos up loaded by this weekend. I will be changing the control head mounting so its a bit more stable using bit and parts of a laptop mounting system in a few weeks once it arrives the mics need a home too.
  4. Feb 2, 2011 at 12:49 PM
    barlowrs
    barlowrs Well-Known Member
    Robert
    So Cal
    06 Toyota Tacoma Sport 4x4
    Build Thread: http://www.tacomaworld.com/forum/builds/74926-barlowrs-06-taco-expo-build-thread.html OME Lift, FJ SE Wheels, 255/85 KM2, Allpro Plate Bumper, 8K Winch, Synthetic Line, Yaesu FT-8800R, Custom Sliders Sockmonkey bedside decals, BHLM, base model grille, TRD offroad (black) trim
  5. Feb 21, 2011 at 9:43 PM
    gfiber
    Gary
    Seattle, WA
    mparker,
    I have not forgot you. I just installed a modified RAM laptop mount to hold my radios control heads. Actually bought the floor mounting, telescopic poles and a different pwice other than the laptop tray seems to be pretty sturdy and does not impede my lady friends legs when she rides along. If it did then she would tell me to go play with my radio and not her :( that would be no good.
    I want to change out the ABS the heads are machine screwed onto and dress it up a bit. I'll get some pictures here. One thing I did was to purchase a remote controled relay. Thats way with the press of a key fob i can turn on or off the radios. I have that remote controled relay switch two 40 amp relays which provide power to the rigs. http://www.allelectronics.com/make-a-store/item/RC-10/KEYCHAIN-REMOTE-CONTROL-12VDC-6-AMP//1.html
    More to come.
  6. Feb 21, 2011 at 9:53 PM
    Ridgerunner
    Ridgerunner Well-Known Member
    Frank
    San Francisco
    2001 prerunner doublecab limited
    2001 with; cat-back twin exhaust,elbow mod, Westin bullbar with Hella550's, Snugtop XTR camper shell, TRD off-road 2x4-black beauty.
  7. Feb 22, 2011 at 8:17 AM
    barlowrs
    Robert
    So Cal
    Take a look at the writeup, that is just the face, it does not produce heat..all the guts are under the seat (now in a sealed box incase I get water in)
    Justinogo likes this.
  8. Feb 22, 2011 at 9:20 AM
    PreRunnerSeth
    PreRunnerSeth Well-Known Member
    Apex, NC
    15 Black DC OR Prerunner
    I had a remote face system with the main body mounted behind the driver side rear seat. If you search you will find some pictures of my install.
  9. Feb 22, 2011 at 9:31 AM
    Ridgerunner
    Frank
    San Francisco
    Yeah I know it's "just the face" that's why I called it "the head"-what I was thinking about is the blazing heat from the sun beating down on the roof just behind that head. I assume you removed some insulation to set it in there. Even if you didn't I would at least try to shield the back of that head from heat. You know how hot that roof can get?
  10. Feb 22, 2011 at 9:36 AM
    barlowrs
    Robert
    So Cal
    Ohh I see what you are saying..ok....essentially, the mount that I made holds the face about an inch and half off the roof, so there is a large void of air between any radiated heat from the roof and the back of the radio. I also did add some insulation between the mount and the roof. This also act so pad the radio if I hit the head line too hard and push it up into the roof (haven’t done it yet, but it was a concern I addressed during the build).
    The radio has been there for quite a while in the so cal sun and still works like a champ, so I think it is ok. Good question though.
  11. Mar 3, 2011 at 5:27 PM
    Ridgerunner
    Frank
    San Francisco
    Sweet and clean-and ya manned up and drilled that hole:D I don't have the nerve...yet
  12. Mar 3, 2011 at 6:08 PM
    DevL
    DevL Well-Known Member
    There is no insualtion behind the head liner. I installed some 1/8 closed cell foam to correct this. Gotta say that install is the cleanest I have ever seen. Hope to copy it one day.
  13. Jun 20, 2014 at 8:03 PM
    ET2 SW Moose USN
    ET2 SW Moose USN Member
    Kenny
    Connecticut
    2014 Tacoma Sport
    Where do you guys hook in at? my Taco has a 24v battery and my Kenwood TM 281 takes 13.8 at 15 amps. my old ford focus had convenient posts to put some eyelets on but my new truck just has the big ol battery posts.
  14. Jun 20, 2014 at 8:39 PM
    RND2
    RND2 Well-Known Member
    In my head swimming around
    12 DCSB
    RCD 4"
    24V?
  15. Jun 21, 2014 at 4:55 PM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    Your battery is 12 volts hook it on the bolts that hold the cables on.
