Ham radio mount
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Rich18353, Jun 30, 2021.
  1. Jun 30, 2021 at 5:15 AM
    Rich18353
    Rich18353 [OP] New Member
    Rich
    2020 TRD Off Road 6 speed manual.
    Redarc tow pro elite Expedition essentials T3pam Swithpro 9100 on a power tray with dual circuit breakers Midland MXT275
    I am planning on installing a Yaesu FTM-300DR IN MY 2020 TRD Off Road. I want to mount the body of the radio under the passenger seat and don’t want to interfere with the heat/ac vents under there. Is there a bracket that mounts to the seat frame that anyone knows about? Or how has anyone else accomplished this?
  2. Jun 30, 2021 at 5:27 AM
    Woodrow F Call
    Woodrow F Call Kindling crackles and the smoke curls up...
    Colorful Colorado
    16 DCSB SR5 4X4 "ikea furniture haulers" edition.
    I zip tied mine under the seat.
    Rich18353[QUOTED][OP] likes this.
  3. Jun 30, 2021 at 5:37 AM
    Rich18353
    Rich
    I was hoping for a bolt in application. I do quite a bit of off road and wanted the radio as secure as possible.
  4. Jun 30, 2021 at 6:42 AM
    Woodrow F Call
    Colorful Colorado
    Yaesu makes a pretty rugged radio and you can get heavier duty zip ties.
    All that said, get some steel from home depot, a punch, drill, hammer, nuts and bolts and fabricate what you need.
    Not sure anyone makes a bracket.
  5. Jun 30, 2021 at 6:46 AM
    stu8319
    stu8319 Well-Known Member
    Stuart
    Oklahoma City
    2018 Tacoma TRD Off-Road in Quicksand
    Mine is zip tied and I've done some pretty rough stuff in it. Never had an issue.
  6. Jun 30, 2021 at 8:05 AM
    MeefZah
    MeefZah -----------
    Mark
    Lexington, Ohio
    2020 GX460
    I lined the bottom of the radio with "hook" velcro and slapped it to the carpet under the pass seat. Immovable. Even off road.
    optysite and Rich18353[OP] like this.
  7. Jun 30, 2021 at 8:29 AM
    Doc62
    Doc62 Well-Known Member
    Dave
    SE Pennsylvania
    2025 Tacoma TRD Off Road i-FORCE Max, 2019 Sahara
    I did the same for my FT8900 under the passenger front seat of my Wrangler. Haven't had any issues.
  8. Jun 30, 2021 at 2:22 PM
    LongRon
    LongRon Member
    2019 White DCLB TRD Off-Road
    I screwed my icom 2730 standard bracket into the carpet under the driver’s seat with 1/2” sheet metal screws. They’ll go through the padding and into the vent plastic which gives it a bit of extra retention power if you don’t care about the 4 little holes in the duct.
    Photos are from the side (door), the mike and speaker from the side, and from the front of the seat. Excuse the dirt; didn’t feel like vacuuming before taking the pics.
    Control head, speaker, antenna, and power wiring are tucked under the center console covers; power runs from the battery through the firewall to the console. The external speaker, mic and control head are mounted with 3m Dual lock tape. Small notches in the plastic accommodate the control head and speaker wires.
    My truck spends a lot of time off pavement and I’m incapable of driving slowly; it’s held up nicely for just shy of 2 years. Velcro on the carpet should do the trick as well. There’s not a lot of opportunity for movement down there.
    MeefZah likes this.
  9. Jun 30, 2021 at 2:33 PM
    LongRon
    LongRon Member
    Forgot to mention that the flat part of the quarter panel is just big enough to punch a 3/4” hole for a NMO mount. The only issue is that this section of the quarter panel is unsupported and will flex. If someone pulls on the antenna, it will likely bend the sheet metal. In “normal use” it’s fine as is. There’s a little bit of flex, but not excessive.
    The solution (if you want that super clean effect) is to pull the quarter panel and epoxy a diagonal support brace in place. Forgot to take pics.
    Theres a little bit of outward camber, but a slight bend at the base of the whip solves that problem.
    The rg58 runs through a cutout and then an existing firewall plug on the passenger side and then under the dash to the center console where it meets up with the rest of the wires.
    No known RFI issues; I consciously kept the coax separated from factory wire bundles. The antenna is 1/2 wave on 2m and some multiple on 440 and has close to a 1:1 swr across the tx bands. While I haven’t done field strength tests, it seems to radiate pretty well in all directions. Can’t put the antenna on the roof since there’s often stuff on the rack, and I park the truck in my garage.
    Rich18353[OP] and MeefZah like this.
  10. Jun 30, 2021 at 2:44 PM
    MeefZah
    MeefZah -----------
    Mark
    Lexington, Ohio
    2020 GX460
    Or trunk lip NMO on hood...
    (shown on my 4R but same concept on the Taco)
    LongRon likes this.
  11. Jun 30, 2021 at 2:56 PM
    Rich18353
    Rich
    Thanks everyone! I’ll post pics when I get it all installed.
    LongRon likes this.
