Hammer Down...What are your RPM's durring shifts?
Discussion in '1st Gen. Tacomas (1995-2004)' started by a31gun, Feb 8, 2008.
  1. Feb 8, 2008 at 6:22 AM
    a31gun
    a31gun [OP] Member
    Norman, OK
    01 SR5 4x4
    3", Blisten 5100's, Leer shell, Deckplate w/ K&N, Hella 500FF's in grill, 265 BFG AT's,
    I'm running the 3.4 with manual Trans. I feel like I'm being hard on my yota when getting on the interstates to and from work (very short on ramps). I was just currious to what your auto trans shifts at through 1st, 2nd, 3rd, and 4th with the pedal to the floor?
  2. Feb 8, 2008 at 10:26 AM
    007Tacoma
    007Tacoma I dub thee malicious!
    Mark
    San Antonio, TX
    2015 4Runner Trail Edition Premium
    Cloaking Device
    You are really comparing apples to oranges. The gear ratios on the automatic gears are very different from the manual gears. The shift points won't be the same no matter what. You really can only compare manual to manual (same exact transmission).
    Floored, most auto transmissions will go to redline before they shift. Anything below that is too hard to quantify due to differences in user input.
  3. Feb 8, 2008 at 11:49 AM
    a31gun
    a31gun [OP] Member
    Norman, OK
    01 SR5 4x4
    I get what your saying. Basicly what i'm getting at is how high are your RPM's when the truck shifts? 4000? 4200? 4500?....etc. I run my RPM's up to 4200 before I throw the next gear. It just seems like a bit much you know.
  4. Feb 8, 2008 at 12:33 PM
    2003greenbean
    2003greenbean Carolina Alliance Costal Div
    socaste,sc
    03 trd
    cold air intake, step bars, custom grill, 3in lift,12 in audiobahn sub, 285/75/16 procomp tires, 20% tint,
    that does seem high but i never look to worried about going faster than the truck i am pulling out in front of
  5. Feb 8, 2008 at 4:36 PM
    concrete jedi
    concrete jedi Well-Known Member
    Rochester N.Y
    06 Tacoma 4 door indigo blue
    Broken and scratched tailgate, cracked rear tail light lens, coffee stain in driver seat.
    I try to keep my shifts around 2000-2200, I dont drive hard, as a matter of fact... mine has never seen 4000 :D
  6. Feb 8, 2008 at 5:09 PM
    JKarp
    JKarp Active Member
    08 4x4 4 banger
    My four banger seems happiest shifting around 3K.
  7. Feb 11, 2008 at 3:44 AM
    007Tacoma
    Mark
    San Antonio, TX
    Cloaking Device
    On my manual tranny, I normally shift between 2,800 and 3,400 to get on the highway. Otherwise, I am down about 2,200 to 2,700. Of course, our engines, trannies, and weights are completely different though.
  8. Feb 11, 2008 at 9:37 AM
    DefyInertia
    DefyInertia Saratogian
    Nate
    NorCal
    '05 DCLB 4x4 SR5#8 (white)
    Toytec Ultimate: ~3" up front via coil overs, LR UCAs, and SB delete; 2+ out back with AAL and new shocks. Leer cap, padded sleeping platform in bed
    Just look at a dyno curve and thay should tell you where to shift. I pretty much just shift by feel (2,000 to 3,000 perhaps) but I believe when I'm hammering it my shifts come around 3750.
    At what indicated RPM does the rev limiter kick in?
  9. Feb 11, 2008 at 3:28 PM
    a31gun
    a31gun [OP] Member
    Norman, OK
    01 SR5 4x4
    Not sure on the rev limiter, i really don't want to find out in my truck though...
  10. Feb 11, 2008 at 6:20 PM
    2000Tacomer
    2000Tacomer Member
    2000 Maroon, V6, Extended Cab Tacoma
    I drive a manual, but I keep mine at between 2,700 and 3,000. My old truck needed at least 4,000 to properly get up to speed. When I did that the first time in this truck (out of habbit) I pushed in the clutch and felt this vibration in the pedal from the engine. Seemed like I was reving too hard, so I keep it lower now. Around 2,700 is my sweet spot I think.
  11. Mar 6, 2011 at 8:42 AM
    TacomaNC
    TacomaNC Active Member
    NC
    borla exhaust tintind windows
  12. Mar 6, 2011 at 8:52 AM
    tacomakid96
    tacomakid96 Lions Not Sheep
    Phil
    Out n' about
    1996 Tacoma / 2000 4.7 Tundra TRD
    I feel all manual trannys should be shifting around 3k rpm, 4 is way to much IMHO
  13. Mar 6, 2011 at 9:09 AM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    1990 Chevy Siveraydo
    getting on the freeway, 3,500 to 4,000 (very steep and short on ramp) but normally around 2000 - 2500. Highest I've ever taken it was 4,500 and it didn't break a sweat.
  14. Mar 6, 2011 at 9:44 AM
    twfsa
    twfsa Well-Known Member
    Tom
    Omaha Ne
    04 TRD 4X4
    881 Front coils, Bilstien 5100's all the way front set to "0" Icon Dynamic's mini leafs in rear, stock tires.
    Don't red line it!
  15. Mar 6, 2011 at 11:20 AM
    Tacomadude89
    Tacomadude89 Well-Known Member
    Austen
    On mine when I'm at like a freeway on ramp meter light and then have to get up to speed quick for example, I'll shift out of first at 3k, second about 2.8K, third 2.7K, and then fourth into fifth is usually around 2.5k rpm's.
  16. Mar 6, 2011 at 8:38 PM
    MowTaco
    MowTaco Well-Known Member
    Kansas
    16 Chevrolet Silverado
    Forgive me if I'm out of line... but isn't a rev limiter there to prevent damage from over-revving? I guess I don't see a problem with bouncing it off occasionally.
    (It's 5500 btw :cool:)
  17. Mar 6, 2011 at 8:54 PM
    glamis3000
    glamis3000 Well-Known Member
    Brant
    Cottage Grove OR
    '96 toyota tacoma 240k miles
    3in lift, 31x10.5x15 toyo mt, tinted windows,
    if im on the gas and got it to the floor ill run my rpms above 4-4.5 but if im just driving normal i shift around 3-3.5.. and my trucks a 96 with 241k.. gotta keep them cob webs out of the engine... lol
  18. Mar 6, 2011 at 9:38 PM
    Tacomadude89
    Austen
    Lol, when I think of 'hammer down', Cummins diesel immediately comes to mind...
  19. Mar 6, 2011 at 9:43 PM
    98_Mud_bug
    98_Mud_bug 98_mud_bug
    lucedale Ms.
    98 tacoma sr5/ 06 x-runner
    3 inch suspension lift, night shades corner and blinkers projector headlights with halos and 3 led's 18 inch kmc xd rockstar wheels,275/65/18 kelly safari tsr's, bush whacker fender flares 7 inch touch screen, 2 kenwood 12's, Magnaflow exaust single in dual out,
    my 98 redlines before it shifts if im into it strong, in the x runner i shift between 2000 and 3000 in traffic, but occasionally i will set it in the floor just for fun lol. when i run it on the track i bounce the rev limiter once when i shift most of the time. sometimes i will shift it about 5200 though.
  20. Mar 6, 2011 at 9:55 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    :eek: Holy thread revival batman!
